Question about HP DeskJet 970cxi InkJet Printer
The ink warning light flashes, and won't go off, even after I've put a new cartridge in. I've unplugged the printer, turned it off and on, plugged the cable back in, and it won't go off.
    Guru:
  • 1,049 Answers
A blinking orange light means an empty or incorrectly installed ink cartridge. Ensure that the cartridge is not empty or dried out. Also be sure you installed the number 45 black and number 78 tri color cartridges. The 41 tri-color, for example, looks the same but would generate an error. Also, check that the panel in the back, or duplexer if you have one, is seated firmly in the printer as this can generate odd errors.
Posted on Oct 13, 2009
Carriage for the ink cartridges is stuck, the carriage wont move to the middle so i can change the ink. i turned off the power & then turn it on , the carriage just move a little from the right and...
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 30, 2011 | Lexmark X2600 InkJet Printer
When opening my printer to get to the cartridges, they are stuck inside the printer and won't move. The on/off button is flashing.
Aug 26, 2011 | Lexmark Z2320 InkJet Printer
We have just put a new black ink cartridge in our printer and now it won't print. The computer says it is error# 5200 and to see the user guide. The manuals don;t have any info to help. I have tried...
Error 5200:
Start with printer powered off
1. Open cover of printer and verify that the ink cartridge carriage is not in the center of the printer. Leave cover open.
2. Unplug the electrical cord from the printer and wait 30 seconds.
3. Plug electrical cord back in, when ink cartridge carriage moves to the center of the printer quickly unplug the electrical cord again. This should leave the ink cartridge carriage in the center of the printer so you can get to it.
4. Lift up the gray arm that surrounds the ink cartridges.
5. Remove the entire ink cartridge holder (not just the ink cartridges). It will lift out easily as a unit. Lower the gray arm that you lifted to remove the cartridge holder.
6. Close printer cover. Plug electricity back in.
7. There should be a message about checking the ink cartridge on the display (I can
Jul 10, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I replaced the color ink cartridge. Now there is an "E" flashing alternately with a "5". The alarm light is on steadily, and the black ink and color ink lights are flashing. How do I...
E5 is a Cartridge cannot be recognized error.
Reinstalling the cartridge could clear the alarm.
If this does not work,
Removed both ink cartridges.
Turn off printer and unplug fron electrical outlet.
Wait at least 5 minutes.
This will let the printer reset itself.
Plug printer back in and turn on.
Printer will cycle and an E5 will appear.
Installed back ink cartridges.
Jan 26, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Under Attention, orange lights are flashing for black and white and color. I have put new ink cartridges in turned on and off and still flashing orange. Wher it says Start/Copy, a big E is flashing. ...
I would try to remove both ink cartridges.
Close cover and turn off printer and unplug from outlet.
Wait at least 15 minutes, this will let printer to completely reset.
Turn on printer and wait for printer to stop.
Install both ink cartridges.
Jan 09, 2011 | HP Deskjet F4180 All-in-One InkJet Printer
I have a "Lexmark" X6150 Scanner/Copier/Printer.It list a an error as being "Cartridge error 50c" I put in new cartridge & it still won`t print a "Alingment Page" The Cartridge before didn`t last very...
Unplug the printer/copier from the main source of electricity, make sure it is a full ink cartridge, wait 10-20 seconds, plug it back in. Sometimes it takes unplugging it from the computer and doing the same.
Sep 21, 2010 | Lexmark Office Equipment & Supplies
All the lights are flashing. I have put in a new cartridge, unplugged and turned off the machine, I cleaned it with the air duster. It will not work
Try the following tricks:
Disconnect any USB cables attached to the printer and remove any memory cards from drive bay. Restart the computer. Unlock the ink cartridge locking clips. Remove all ink cartridges. Lock down the ink cartridge locking clips. Close the main printer door Turn the printer off with the Power button and wait for the printer to shut down. Unplug the printer AC adapter from the printer and the wall outlet or surge protector. Wait approximately fifteen to forty-five seconds to allow all current to dissipate from printer. Re-plug only the AC adapter into the wall outlet then into the printer, but do not plug in the USB cable. Wait for the appropriate missing ink cartridge error to verify that printer can recognize this error. Re-insert one ink cartridge only, to minimize confusion in case one of the cartridges is defective, and print an internal test page. If no errors are found, insert the other ink cartridge(s) and ensure that they are functioning by performing internal test pages or calibration pages. If an error occurs due to a defective cartridge, perform the appropriate steps for Resolving Ink Cartridge Rejections. After returning to the main Windows screen, reconnect the USB cable to the computer then to the printer. Good luck. Thanks for using FixYa.
Jun 01, 2010 | HP LaserJet 1012 Printer
Loaded a new black ink cartridge, getting flashing yellow light and won't operate.. reloaded many times.. no luck... help plz?
Hello sir; Turn power on, open the cover, UNPLUG the power cord, loading the cartridge, put cover down, plug in the power cord, it should reset.
Dec 24, 2009 | HP DeskJet 882c InkJet Printer
I have epson DX7450 tells me ink out replaced all but still ink out report have don eall the books operation guide please help regards B D
Check whether cartridges is placed properly ?
Unplug the unit for 30 minutes and plug back the power chord to the unit .
Nov 01, 2008 | Epson Office Equipment & Supplies
Re:Canon Multipass C3500ex
Don, have you unplugged the printer for a few minutes? first the power plug, see if that clears it. If not, unplug it from the computer, reboot the computer, then plug printer back in. If not that,when an ink cartridge is refilled (depending on the model) the printer needs to be tricked into thinking a "new" cartidge is being installed. They make their money from the ink, not as much the printer. You may need to check the owners manual to see if the is the case. I have had to use tape to block off certain contacts, then remove the cartidge and block off another section of contacts, then remove tape all together and re-insert the cartridge.
Jan 27, 2007 | Canon MultiPASS MP370 All-In-One InkJet...
HP DeskJet 970cxi InkJet Printer Logo
405 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
