Kenmore 80 series washer not spinning
PLease Help!!...This washer is 2 yrs old and started to spin intermittently during spin cycle. After washer completed full wash cycle, we could switch to spin cycle and it would work, but problem got progressively worse. I inspected coupler between pump and gear box by removing it. It's ok. Lid switch is fine also. I then bypassed lid switch and set to spin cycle. clutch housing turns, but basket does not. I noticed a little bit of oil splattered on inside of panels, but I do not think it's enough to be worried about. I called Sears for repair and tech told me I need a new gear box & timer.If I need a new gear box, I wouldn't think the clutch housing would spin. Also wouldn't think I need a new timer if gear box goes into spin mode.
  • 88ply Dec 21, 2007
    Why would I need a new gear box if clutch housing is spinning?
  • 66 Answers
You need the gear box not the timer.
Posted on Dec 21, 2007
  • sohail anjum Dec 21, 2007
    when the washer has load it wont spin. when it is empty it will spin,
Washer wont spin in the spin cycle.Washer was full of water and making a buzzing noise.If you have any suggestions what it might be that would be great. Kenmore 80 series washer about 11 years old.
sounds like the lower bearing on the trans mission shaft is seizing up on you. had a frigedair that did the same thing. i took it apart to replace, but could not buy separate. it only came with a purchase of a new transmission,which ran $175- 275. so i junked it out. washer was only 5 years old.
May 29, 2009 | Kenmore Washing Machines
Kenmore washer 80 series misses spin during wash.
You may need to replace the motor coupling between the pump and motor...
Apr 07, 2009 | Kenmore Washing Machines
Kenmore washing machine will not drain
Replace the timer.
This is a neutral drain machine. If there is no natural pause in the timer at the end of the rinse cycle the timer is bad.
Mar 13, 2009 | Kenmore Washing Machines
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer stopped during unbalanced spin cycle
lid switch is broke lever probley broke off or screw holes broke out due to off balance load forcing tub over against switch lever
Apr 29, 2008 | Kenmore 20172 Top Load Washer
Your transmission is not engaging thats why the speed changes your making will sometimes get it to work.Honestly any machine after the 10 year age mark is not worth the cost of replacing the transmission.
Apr 15, 2008 | Kenmore 24032\24036 Top Load Washer
Intermittent spin cycle on Kenmore 90 Series washer
You may try the speed selection switch.....Ive had problems with these.
Jan 23, 2008 | Washing Machines
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Washing Machines Logo
519 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
