LG TROMM 4.0 cu.ft. Ultra Capacity Front Loading SteamWasher , WM2688H
Problem for LG TROMM 4.0 cu.ft. Ultra Capacity Front Loading...
Error LE
By fairyfrog on Oct 01, 2009
Error LE. The tub is having a hard time turning.
When there were clothes in it, the tub did not turn at all. After removing the clothes and some of the water the tub did turn.. but it was having a hard time.
Best Solution
posted on Oct 01, 2009
Very Helpful)
canbruce75
Rank: Guru  Washers & Dryers  Expert
Rating: 92%, 821 votes
This error code indicates "locked rotor error". This can be caused by loose or corroded electrical connections at the motor or control board or by a faulty hall sensor. Unplug the washer. You can start by unplugging and reseating the electrical connections at the motor to make sure there is good contact and to clean off any corrosion build-up. Do the same for the connections at the control board. You need to remove the rotor and stator to access the hall sensor. When you get ready to install the rotor after replacing hall sensor it is best for a helper to hold the drum in place when you push the rotor onto the shaft or the drum may move forward, making it hard to replace the bolt. The drum also need to be kept from turning while the bolt is tightened. I will attach a photo of the hall sensor for reference. Remember to try and check the electrical connections first, before considering a faulty hall sensor. Pay particular attention to the connection on the main control board. It should be a red colored connector. Really sorry for your trouble and I hope this helped. Best wishes.
Comments:
Oct 01, 2009
- If you have any doubts then I would suggest contacting a qualified appliance technician for assistance. Best wishes.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for LG TROMM 4.0 cu.ft. Ultra
Questions and Unsolved Problems for LG TROMM 4.0 cu.ft. Ultra
Do you recommend LG TROMM 4.0 cu.ft. Ultra Capacity Front Loading SteamWasher , WM2688H?
Answer
Answer
it is a lg tromm and it has a crack in the drum .....now it is loud has a thumping noise is there a... (More)
Answer
The spin cycle has now started to have loud vibrating like the drum is out of balance.... (More)
Answer
Vibrates severly when on spin cycle Put levels on machine and bubbles are centered
Answer
my machine stopped in cycle with water in it--lights flash machine won't spin or drain water
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing... Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
