Microsoft Windows XP Home Edition
Disk Partitioning on Windows XP
shared by 2 users
posted by shobhit78 on Dec 20, 2007
I have a dell laptop which has only 1 partition - c:\
All my data is on C: (as there is no other drive).
For security of data against disk failures, I want to create another drive (D or E), which will be different from my system drive and I will use it to keep all my data there.
Can I please get a step-by-step process for doing this partitioning, without loosing any of the present data on C:
(steps right from backing up the present data, then partitioning, creating a new drive and finally moving all the C: data to the new drive)
Thanks,
Comment posted on Dec 21, 2007
Thanks nkprl,
But Partiton Magic
is quite costly....
Any thing else available for cheap/free? OR just a step-by-step process will do without any software...
Thanks
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by marlonr6 on Jun 01, 2008
i tried to create new partition but as i hit add/remove prog. i can not see the start up disk so that i can proceed to create disk
Solution #1
posted on Dec 20, 2007
Thanks for Trying (70)
nkprl
Rank:Guru Guru
Rating: 86%, 57 votes
download partiton magic and the procedure is very simple without loosing any data
partition magic its the most safe utility
download it from here
http://rapidshare.com/files/68651905/Partition_20Magic_208.rar
Rating Locked! (?) shobhit78 has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Disk Partitioning on Windows XP:
I don't want to Accept this solution
Can you Help with these Operating Systems problems?
Operating Systems
how can i found project in visual basic
Operating Systems
a spring is helled vertically and when a load is attached...
I've had internet access, but suddenly can't seem to get...
i have support from yogi and they said i could play my...
object refrence not set to an instance of an object.
Loading problems.
Repair Service
Find Operating System Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
