Question about Lexmark W820 Laser Printer
Lexmark w820--915 fan service error - intermittent!
This error occurrs after having *** with the printer. Please refrain from this activity
Posted on Mar 07, 2011
915 service motor error
The error means that the printer is detecting that there is Fuser cooling fan failure. Check if the fuser cooling fan is installed properly. If it is, check the fuser cooling fan for operation. Follow the steps below:
1. Enter Diagnostics mode.
2. Select MOTOR TESTS.
3. Select Fuser cooling fan.
Does the fuser cooling fan RPM increase? If yes, perform a print test, and if the error continue, replace the printer engine card assembly. If no, check the fuser cooling fan for proper connection.
Nov 30, 2012 | Lexmark W840 Printer
Marca error 922 service fuser lexmark t520
922 Fuser Error messages indicate that the fuser unit failed to reach the standby temperature.
  • If this is the first time you have seen the error, turn the printer off and on. Leave the printer off for at least 10 seconds before turning it back on. This gives the printer's engine board a chance to reset.
  • If this is an intermittent error, you may want to check how the printer is plugged in, even if it has worked on this surge device for months. Make sure the printer is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer which can trigger a false fuser error.
  • If this does not help or if this error appears every time the printer is powered on, you will probably need service on the machine. I suggest you contact Lexmark Technical Support.
  • Aug 23, 2011 | Lexmark T520 Laser Printer
    MY OPTRA SE 3455 IS SHOWING THE FOLLOWING: 921 SERVICE FUSER ERROR
    A 921error indicates that the fuser unit failed to reach the standby temperature.
    • If this is the first time you have seen the error, turn the printer off and on. Leave the printer off for at. least 10 seconds before turning it back on. This gives the printer's engine board a chance to reset.
    If you need further assistance please contact Lexmark Technical Support or any Lexmark authorized service provider.
    Aug 12, 2011 | Lexmark Optra Se 3455 Laser Printer
    All lights flashing on E232 Lexmark Printer. No fan coming on when on switch.
    Light sequence means that the printer has a service error. Turn the printer off and back on. If the lights are still blinking, contact Lexmark Technical Support.
    Jul 21, 2011 | Lexmark E232 Laser Printer
    Lexmark T644 920.16 Service Fuser Error What do I need to do to repair this problem?
    Lexmark gives the following list of all fuser errors and recommends what action you should take (Lexmark Knowledge Base). that the fuser unit failed to reach the standby temperature.
  • 920 Fuser Error message indicates that the fuser unit in the printer is below the proper temperature for printing.
  • You may need to replace the fuser: watch this video:
    http://www.youtube.com/watch?v=RjQkR4x9fqw
    Click on this link or copy and paste the complete link into your browser.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
    Jan 24, 2011 | Lexmark T644 Laser Printer
    Error code 917.00
    Step Action 1 Turn off the printer and let the printer sit, powered off, for one minute. 2 Power the printer back on. 3 If the 917 error does not return on power-up, try printing a few pages. If the error does not return during printing, this may have been an isolated incident. Continue using the printer as before, but pay close attention to it for the next few days to see if the error returns. 4
    If the error returns on power-up, as soon as you try to print, or re-appears at a later time, inspect the transfer roller. (Click the links in the steps below for images.)
    1. Turn the printer off.
    2. Open both the lower front cover and the upper front cover of the printer.
    3. Remove the toner cartridge and place it aside.
    4. Look at the transfer roller. Make sure nothing is stuck on the roller or wrapped around it. If you find any obstruction, try your best to remove it without damaging the transfer roller or knocking the roller loose.
    5. Make sure the transfer roller is not loose or damaged. If the roller is damaged, the roller will need to be replaced. Please contact Lexmark Technical Support or a local authorized service provider for further assistance.
    6. Spin the transfer roller. Make sure it spins freely.
    7. If the transfer roller appears to be fine, reinstall the toner cartridge and power the printer back on.
    8. Try printing again to see if the error message returns.
    If the 917 error still will not clear, or if the error continues to occur intermittently, the printer will likely require service. Please contact Lexmark Technical Support or a local authorized service provider for further assistance. See Contacting Lexmark below for more information.
    Jan 11, 2011 | Lexmark T642 Laser Printer
    T642 Laser Pinter
    This is a call for service message generally requiring professional repair.
    There are generally only four reasons:
    No power, Check fan power leads as one may have slipped off it's fitting
    Jammed: Either too dirty or a shred of paper may be blocking the blades, pull free and clean off with compressed gas(no more than 25ft/lbs)
    Dead fan: Call a repair man or call lexmark and give them the exact code,they will identify the fan and can sell you the part.
    Dead controller board: as with above call a repair man or lexmark with code and order spare part.
    The only bad news other than you may need a repairman, if you order the fan or controller board it may be the other and no way to know ahead in some cases.
    The good news, if you're still under warranty, lexmark has good repairmen and fast response times in most areas.
    Either way, Hope this helps FixYa,
    Chris
    May 10, 2009 | Lexmark T642 Laser Printer
    Lexmark T642 Laser Printer error message922 02
    Service fuser error requires a maintenance kit, this is approx $1000 + installed, if this is new, I would be taking it back because it shouldnt have this error. You possibly might be able tto fix it by replacing the fan in the back but thats only worked for me in approx 1 out of every 10 times.
    Jan 13, 2009 | Lexmark T642 Laser Printer
    Re: 4037 5e lexmark laser printer printer is showing 921 service what does this mean and how do i fix it
    Here's some info:
    921 Fuser Error and 922 Fuser Error messages indicate that the fuser unit failed to reach the standby temperature.
    Oct 16, 2008 | Lexmark Office Equipment & Supplies
    913 Service Fan Error
    your printers power section does not work properly
    Jan 25, 2008 | Lexmark C510 Laser Printer
    Lexmark W820 Laser Printer Logo
    935 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
