Question about Kenmore Dryers
My dyer heats and tumbles, but doesn't dry
My dyer heats and tumbles, but sometimes doesn't dry clothes--leaves them wet.
    President:
  • 1,489 Answers
I'd check first for clogged vent hose or clogged lint filter or clogged vent flap on wall (outside).
If that's not a problem, it may be a faulty thermostat. Heating element is probably okay if it heats some of the time.
More info, let me know.
Charlie
Posted on Oct 01, 2009
  • 2,006 Answers
Is your blower working? If the blower isn't blowing the hot air into the dryer drum, it would not dry the clothes effeciently.
Posted on Dec 26, 2011
Water coming from under appliance
Maybe your dryer is not drying!!!!!!!! Is it getting hot? Heat element ok? Maybe the washer is not doing a good enough job during the spin cycle and leaving clothing excessively wet.
Sep 08, 2017 | Refrigerators
E15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
Clothes not drying
Clothes not drying? Thats it? Does the dryer turn on at all? Does it tumble the clothes but doesn't get warm? If it turns on and tumbles but takes a long time to dry, then your heating element is not working. There is a thermal fuse right before the heating element that will open up if the vent becomes clogged and its gets too hot. The thermal fuse is not resettable and will have to be replaced. If the thermal fuse is o.k. then your heating element could be burned out. These two items almost require an electrical meter to read continuity to check them. Make sure the dryer is unplugged before checking these items.
Dec 21, 2011 | Zanussi TC7114W Electric Dryer
The dryer isn't providing any heat
Try Resetting your Breaker, even if the dryer is tumbling. Sometimes one breaker on a double pole trips. Also check the vent to be sure there is air flow. A clogged vent system will leave clothes wet.
Feb 27, 2011 | Whirlpool LER7646E Dryer
Put the cloths in the dryer like usuall and waited for peep to let me know its dry. but when i heard the peep assumed the cloths will be dry, the cloths were just like i got out of the washer, wet. it is...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 02, 2011 | LG DLGX8388 Gas Dryer
Dryer tumbles the clothes not drying it leaving it wet
heatman101
Jan 30, 2011 | Estate TEDX640JQ Electric Dryer
Dryer is running longer than usual, it's tumbling,
no make listed here...I would pull the hose off the back of dryer and see if a lot of air is blowing out of vent. if not, heres your answer a clogged filter area ..if air blowing out leave vent hose off and dry clothes with vent off for one cycle. if clothes dry with vent hose off..you have a venting issue and need your vent cleaned out...
May 15, 2010 | Dryers
Wed9200sq0 heats, tumbles but does not dry at any heat setting
You are correct. Pull the dryer out and disconnect your venting from the back of the dryer. Turn your dryer on and check to make sure your dryer is blowing air out of the dryer duct. If it is then leave your dryer out at least 2 ft from the wall and run a load of clothes through the dryer. If it dries your clothes normally then you have a venting restriction. Check to make sure your venting is clean, not kinked or smashed, make sure your outside vent is opening an doesn.t have something blocking it. Check your lint screen filter by running water through it. If water is not flowing through it, you have a build up of fabric softener on your screen, blocking air flow. Scrub your screen off and test again. Good Luck, Appliance Specialists
Dec 30, 2009 | Whirlpool WED9200SQ Electric Dryer
Dryer not heating leaving the clothes wet
First, you need to be sure if really the dryer is not heating. Sometimes the vent is clogged and doesn't dry the clothes regardless the drying is heating.
Be sure the exhaust pipe is not clogged and try to operate the dryer again.
Dec 18, 2009 | Dryers
Dryers Logo
340 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
