Question about Jabra BT250 Consumer Headset
Headset won't go into pairing mode
When I turn on the headset, even when I hold the button down for 15 to 20 seconds it goes from flashing fast to flashing slowly and never just stays on solid to pair.
  • 3 Answers
Power off the device and do not turn it on before holding down the botton to put in Par mode. Once it is off, then hold down the button usually takes about 5 to 10 seconds to turn solid and enter par mode. If this does not happen you may have a defective unit and may need to return for a new one.
Posted on Dec 20, 2007
I can't connect with my phone
Please follow the detailed instructions below for the proper pairing of the headset with your phone.
CHARGING
Before using, you must first charge your headset.
20 minutes = minimum charge
2 hours = full charge
Light is solid red when battery is charging.
NOTE For the best user experience, keep your headset fully charged.
CAUTION Do not use headset while charging and do not connect the charger while the headset is in use.
POWERING
Press the control button for 2 seconds to power on. Press the control button for 3 seconds to power off.
PAIRING
Step One:
Prepare Phone- Turn on Bluetooth For most phones, go to Settings/Tools menu and select Bluetooth or Connectivity and select "On."
Step Two:
Prepare Headset- Pairing Mode Begin with headset turned off. Turn headset on (hold call control button for four seconds until the light flashes blue) and it will automatically go into pairing mode, flashing red and blue.
Step Three:
Pairing- Add Headset to Phone For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device, then Select "220Plantronics." For passkey enter
0000. Headset will flash blue when paired successfully. It is now powered on and ready to use.
NOTE: Normally you only need to pair the headset and handset once. If headset has been previously paired with another device, follow pairing instructions below.
If headset has been previously paired with another device, please follow these instructions for pairing a second time. Be sure the headset is fully charged.
1. Press and hold down the call control button for 8 seconds until the headset status
indicator begins to flash blue then red.The headset is now in pairing mode for the next 120 seconds.
2. While the headset is flashing,use the phone menu to search for Bluetooth devices and select "220Plantronics."
3. When prompted for a passkey, enter 0000. Headset will flash blue when paired successfully.
NOTE: The headset can pair to multiple Bluetooth devices, but will only connect to one device at a time. The headset will automatically connect to the last device to which it was connected.
Please don't forget to rate me if satisfied.Thanks for choosing Fixya.Good Luck.
Jun 11, 2011 | Plantronics Explorer 220 Bluetooth Headset...
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
I have a Nokia E75 and am unable to pair my Plantronics Explorer 210 with the phone. I tried to hold the big button down for quick pair mode. When I try to pair, it says unable to create bluetooth...
hello,
Step One:
Prepare Phone-
Turn on Bluetooth
(Or see the user guide for your
phone.)
Step Two:
Prepare Headset-
Pairing Mode
Step Three:
Pairing-
For passkey enter 0000. Headset
and ready to use.
for 2 seconds until the light flashes
and blue. hope it works
regards
shaun
Oct 10, 2010 | Plantronics Explorer 220 Bluetooth Headset...
I have a motorola blue tooth and I need to pair it to my htc evo.... How can I do that?
Ok, I'll give you a default procedure to put a blueetooth headset in pairing mode: starting with it turned off, press and hold the call button as if you were turning it on, but keep pressing the button until the indicator light is either steadily lit, or flashing rapidly, sometime in more than one color. This is usually achieved by holding the button down for some 6 to 10 seconds. Then, make your phone's blueetooth application search for new devices. After a while, your headset should appear on-screen. Make the application connect to it. If a pairing code (or passkey, or PIN), is requested, enter '0000' (four zeros). If the pairing process is successful, your headset's indicator light should flash some times, and enter the stand-by mode (normally flashing every couple of seconds). Your phone should also indicate that a headset is connected. However if the pairing process fails, after a couple of minutes your headset will quit the pairing mode, Turn it off, by pressing the button until the light goes off, and start the whole process again, firstly trying '0000' one more time, then changing it either by '1234' or '8888',
Hope you are able to sort your problems out soon, but, please, let me know if you further assistance.
Regards, Carlos
Sep 14, 2010 | Motorola Mobility Bluetooth Hands Free...
Headset does not flash red/blue so I can pair it with my phone
To get it into pairing mode (flashing red and blue) turn the headset off.  Hold the main button down until the light goes red and then off.  Then push and hold that same button and keep holding it even after the blue light comes on.  It will now go into pairing mode, flashing red and blue.  Set your cell phone to find it and it should work.
May 09, 2009 | Plantronics Discovery 925 Bluetooth...
Plantronics 520 will not pair
"Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue."
Dec 04, 2008 | Plantronics - Bluetooth Headset Plus Base...
Trying to pair BT150 but it won't go into pairing mode
I had the same problem. The many instructions available don't have quite the right details. This worked for me:
1. Turn off the BT150 by holding down the answer button about 5 sec. until the blue light goes off and is not flashing.
2. Turn on the BT150 by holding down the answer button about 5 sec. until the blue light flashes.
3. Keep holding the answer button, and press and hold the volume + button for another 5 sec. until the blue light comes on solid.
Nov 12, 2008 | Jabra BT150 Wireless Headset
How?
Place the headset in pairing mode so your phone will find it.
To place the 320 Explorer in "pairing mode"
Note - the passcode or pin is 0000 by default
Jul 03, 2008 | Plantronics Explorer 320 Wireless Headset
Motorola H350 User Manual
On your bluetooth headset, hold down the power button until the light stays on steady. (it will blink when you initially power it on, but continue to hold for another few seconds for the steady light!) Your headset is now in pairing mode.
On your RAZR, press Menu > Settings and Tools > Connections > Bluetooth > Handsfree > Look for devices. Your phone will then scan for any bluetooth devices that are in pairing mode. When your headset pops up on the list, highlight it and press ok to connect.
If the device asks permission to bond with the phone, select yes. It will then prompt you for a pin code. The pin will be 0000 .
Jan 08, 2008 | Motorola Mobility Bluetooth Hands Free...
Won't go into pairing mode no matter how long I hold the answer/end button. Yes, I start with the device powered down, hold the a/e button, blue light flashes every few seconds but never goes solid. Any...
You need to turn it on so you get the intermittent flashing blue light then hold down the + button and answer button at the same time until you get a solid blue light. Then get your device to search for the headset etc......
Nov 27, 2007 | Jabra BT350 Bluetooth Headset Headset
Jabra BT250 Consumer Headset Logo
113 people viewed this question
Top Jabra Radio Communications Experts
Greg Cann
Greg Cann
Michael Vincent Cruz
Jerry Greenberg
Jerry Greenberg
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
