Question about Coleman Powermate Powermate 5000W Generator
Diesel generator Hour meter is been tamper , how to recoginise it
Power pannel of ACME shows reading when DG is running at full load
but DG Hour meter ( machinical) shows reading when DG is also running on idle condition.
How can one check is the Hour meter is been tamper or not???
Is their any loop to keep a track on it??
4 Suggested Answers
  • 211 Answers
SOURCE: coleman 5000 generator will not idle up under load
Hi
You have to find the governor linkage.There is a spring adjusting by a screw to increese speed to get more power.Try to locate it.
best regards savumihai71
Posted on Feb 03, 2009
protek480
  • 1714 Answers
SOURCE: generator starts but gives no 220 volt electric
This is a frequency issue 50 hertz for Europe, 60 hertz in US. It's speed related. Faster RPM for 60 Hz
Posted on Jun 26, 2009
  • 449 Answers
SOURCE: generator engine runs fine but only 2 volts show
check the voltage regulator
Posted on Sep 15, 2010
My generator is a Kubota DG 7500 and it wont stay on high idle while running
diesel ?
clean fuel filter ..check pump is ok
adjust governor
or twig up idle a bit
Nov 02, 2016 | Electrical Supplies
Preglow diesel
The glowplug is designed to heat the diesel fuel prior to cranking. Typically you energize the glow plug for 10-30 seconds then hit the starter. If the battery is weak or it is very cold, you may have to run the glow plug a little longer.
Apr 15, 2014 | Electrical Supplies
Generator wont start up unless i spray starter fluid into it
This sounds like a dirty carbureator. Just bad enough that it won't start cold.
Mar 29, 2014 | Electrical Supplies
8kw onan genset wont keep running whrn it tries to take on the load, will run forever if i kick the breaker switch to off.
What is the Spec number?
Also can you read a fault code on the start switch?
Do you know how to read the codes and post? if not let me know
Nov 17, 2012 | Onan Cummins 8.0 HDKAK/1046 RV QD 8000...
Need adjustment procedure for a Generac Centurion generator, carb and regulator under full load
Before you adjust anything, suggest you verify gas line for proper pressure and importantly volume. Pressure for gas should be 5 to 7 inches and propane 11 to 14 inches W.C. Also make sure the line to the generator is sized properly and the gas meter is a high volume unit (if NG). 90% we find the problem with generator sunder load that otherwise are fine are fuel related. Good luck.
Sep 19, 2012 | Generac Power Systems Centurion by 16000...
I HAVE A POWERMATE 5000 THAT SHUTS DOWN UNDER LARGE LOAD . I THINK I NEED AN IDLE CONTROL MODULE.THERE IS A 2 WIRE MODULE IN THE START CKT. #21009XA IS THIS IT AND WHERE DO I GET ONE .
Idle control comes into play when there is no power draw forcing the engine to idle with an electro magent. If you feel that the electro magnet is interfering with governor, temp remove the wire to the solenoid. Usually the idle control will not effect how the engine /gen output power. An overloaded condition will cause the engine the go the full throttle as the internal governor of the engine will try to maintain 3600 rpm. Overloaded condition will greatly shorten the life of the generator/engine. Try to use only about 80 % of rated power. Large motors can draw three times running amps. A compressor using 12 to 18 amps to run can draw over 40 amps to start.
If your generator could handle the load in the past, check the engine for loss of power, or the generator for faulty voltage regulator or capacitors out of range. Easy to check. Connect digital volt meter to plug /load and look at volt reading while running with no load and loaded. Voltage should stay between 110 to 120 under load and with no load (unless goes into idle mode). Good luck
Sep 06, 2011 | Coleman Powermate Powermate 5000W...
I have a G-235 generator that has a computerized starting system. As soon as I start it, it revs up really high without any electrical draw on the generator instead of idling. Can you give me some...
Your generator should be running @ 1800 rpm if its diesel . I have a 40 kw diesel generator and it starts up and runs a full 1800 rpm with no load . Thats how there designed because they have a 4 pole alternator. Hope this helps.
Mar 16, 2011 | Ingersoll Rand Electrical Supplies
Black max 7kw generator high voltage output
Those voltage readings MAY be normal.
The AC waveform may cause your meter to read inaccurately. You would need to use a TRUE RMS meter to accurately read the voltage.
The siple meters actually read the AVERAGE voltage and then are calibrated to mulltiply it by the "form factor" for a sine wave. OFTEN these generators don't produce a clean sine wave. A square-ish wave will read higher on the garden variety meters.
Compare the brightness of a lamp comparing to when run on your utility.
The frequency depends on engine speed ... yours is running a bit fast...check it under at least half load and if off, adjust the govenor slightly.
May 01, 2010 | Briggs & Stratton Power Products 5,550...
Yamaha 6500 watt diesel runs but usually shuts
First thing to monitor is the fuel solenoid power. See if it is the thing that goess away to cause shutdown.
Tracing this back there is only a few things that control this: The battery, the low oil shutdown switch, and the run switch, and associated wiring.
If I were to ventture a guess, I would put money on the low oil shutdown switch.
Aug 24, 2009 | Taylor Skid Mount Diesel Generator Set 30...
My "KDE19STA3" Kipor generator keeps showing fault "L&H Freq.What could be responsible and what can i do? It shuts down about 30seconds after dispalying the fault.
this is telling you that the power frequency is above or below the safe limit and so shuts down.
do not run a load but
press the function button and hold then switch on but dont start keep holding until ph2 or similar is displayed then start read the frequency and adjust the engine speed until it reads correct then try will full load and adjust accordingly 1 or 2 hz either way will be ok
Jun 16, 2009 | Kipor Electrical Supplies
Coleman Powermate Powermate 5000W Generator Logo
212 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
