Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Panasonic projection tv
When I turn the power on, it starts to come on and you hear the sound, then the power shuts off and the red power button starts to blink. I also detect a slight burnt smell.
  • whalejack Dec 22, 2007
    How do I get a diagram to show where these parts are and how to replace? Or how to test what might be wrong.
    Problem Solver:
  • 10 Answers
Ladywinn: I'd don't believe your solution is correct. Which school you study electronics? Please see my solution below.
1. If the set keep shutting down whenever it's power up, the first place I would begin to look for is in the Deflection area. Check the horizontal output transistor, check in the vertical stage. check all yoke, as well as the fly back.If all the component mention above check good.
The Convergence IC's could be bad. Most Panasonic Projection screen always have shuting down issues.
And 75% of the problem cause from the Convengence ICs,
Good luck.
Was this soultion help full? Show your appreciation by rating it :
Posted on Dec 29, 2007
  • Panasonic Master
  • 5,138 Answers
Panasonic is well known for two capacitors 1200pf 2k volts, also it has been known to short out the mosfet transistor, it sounds like you only need to replace the caps.
Posted on Dec 21, 2007
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic tv power button blinks 5 times
Probably the power supply is failing.
Jun 30, 2017 | Panasonic Televison & Video
Panasonic PT-51HX41 51 inch
the blinking power indicator is actually a error code. How many times does it blink as I can assist you if you let me know how many times the led blinks
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
When the power button the red button flashes but nothing else hap
the red light flashing means the set is in auto shut down, could be a power supply problem or a convergence IC problem. tech should first check all diodes and caps in power supply then replace convergence IC's
Jan 11, 2009 | Panasonic PT-53WX42 53" Rear Projection...
No picture
This set is a projection tv with 3 tubes red,green,blue more then likely 1200pf 2kvolt capacitor,hori output transistor.
Dec 06, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic pt53wx42f
WHEN POWER IS FIRST TURNED ON I HAVE A SOLID RED LIGHT BUT NO PICTURE. THEN YOU HEAR THE TV CLICK OFF. THEN RED LIGHT STARTS TO BLINK IN SET OF (3) TIMES.
Jun 25, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Power button flashing red
stk convergence packs may haqve failed in the dead short mode stk392-110 removing them from circuit may allow the set to turn on again good possibility do you know how to solder?
Dec 07, 2006 | Panasonic PT-53X54 53" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
71 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
