Question about Emerson LC320EM9 32 in. LCD HDTV
I have an AT&T U-verse receiver that connected to it, but it will not turn on unless i disconnect the HD cable and reconnect it - have you heard of this problem before?
Change the cables to RCA audio cables, do not use the HD Cable (Disconnect it) plug the RCA cables directly into the color coded slots.
As the technician stated to me, their is no standard to the cable manufacturing, so the wires are sometimes not connected properly when part of a harness attachment. Do not use the Harnessed cables!
Posted on Oct 02, 2009
I have a pioneer vsx 816 receiver and the power standby button flashes and nothing work I pressed the enter and advanced surround buttons down amp err can I fix that
This sounds like your receiver is in protection mode. This is often caused by a short circuit of some kind (e.g. speaker wire cores touching the chassis of the receiver).
Disconnect and reconnect all the connected cables one by one (begin with disconnecting the power cable and don't reconnect that until you're done with all the other cables).
Aug 20, 2017 | Pioneer Audio Players & Recorders
I have a Pioneer VSX D412 S receiver with my Pioneer surround sound system The system SUDDENLY STOPPED RECEIVING SOUND SIGNAL FROM MY HD TV
  1. Turn the TV and receiver off and back on. This is called "power cycling" the devices.
  2. Check the menu settings to make certain the TV is still sending a sound signal out to the receiver.
  3. Disconnect the cable, blow both ends out, reconnect, and see if the cable was partially disconnected or has dust or lint interfering with the connections.
  4. Change the cable for another cable that you know to be working.
  5. Use a different source for the TV: DVD, Cable, different channel, etc.
  6. Connect the receiver to another TV.
Dec 16, 2015 | Pioneer Audio Players & Recorders
Onyko tx nr616 receiver keeps shutting off. Only stays on for approximately 3 seconds. Can you help?
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Sep 30, 2014 | Onkyo Tx-nr616 7.2 Thx Certified Network...
How do i check to see what is causing my receiver to shut off
Sep 25, 2014 | Onkyo Audio Players & Recorders
Onkyo ht-rc180 standby light blinks will not start.i tryed factory reset, still blinks
Sep 24, 2014 | Onkyo Ht-Rc180 7.2-Channel A/V Surround...
Upgraded older HD TV to a Sharp 70" smart TV & Home Theater Receiver (Yamaha RX-V575. Have AT&T U-verse HD Cable box. What is the connection sequence using HDMI cables. Searched Yamaha and AT&T sites and...
I dont know about your particular hd hookup , but I take the hdmi cable out of my dish reciever/dvr [digital video recorder] and run it straight to the hdmi input #2 in the back of my apex 40 in lcd-hd-tv
I think take the hdmi output from the at&t u-verse cable box and plug it into the hdmi input of your 70 in sharp smart tv
that will get the input signal from your cable box ,both video & audio, into your tv set.
on the back of your tv set
there should be audio outputs for home theater audio systems that would plug into the audio inputs of the home theater system.
prehaps i am wrong because you say that your yamaha is a home theater* reciever.* is the yahama more than a home theater audio system? What does it recieve?
Idea-- the salesman that you bought it from should be willing to help tell you how to hook it up.
also consider that there are many different ways to hook up vcr's and then dv recorders and dvd recorders and external 2 tera bite hard drives into my tv & dvr . I got that all hooked in & a rats nest of wires. so i can record in hd or sd,on vhs or dvd or dvr
point is that you cant hurt anything by plugging the wrong plug into the wrong jack, as long as the same type of plug goes into the same type of jack.
If its right,it works, if its wrong, it wont work until you plug it into the proper jack.
im sorry ,im 65 am not into knowing all the latest and greatest cutting edge tech ,but i am begining to catch up on my hobby, movie recording tech.
Oct 08, 2013 | AT&T UVerse
Yamaha RX-797 Amp not working
You have too much power being ran to the amp and it's overheating.
Lower your wattage.
Aug 18, 2012 | Yamaha RX-797 Receiver
We hooked up our LCD HD 19" TV up to our HD
Try to disconnect all the connection cables and reconnect again. If still don't receive any sound, your HDMI cable is faulty.
Nov 07, 2010 | Sharp LC19A35M 19 in TV
Vizio Model#:L37HDTV10A After unpluging the HDMI cable & reconnecting it back, I don't have no more HD picture. The Component cable & HD antena works but no HD brodcasting with HDMI connection....
Is the HDMI port 2 work? Try to turn it off and turn it back on. If it is still not working then the HDMI ports have gone bad. You will need to replace the main board.
May 11, 2009 | Vizio L37 Television
Need to know how to hook the 2 together and then to a hd tv
Connect the dvd player to one of the video inputs of the tv. Connect the left and right audio outputs from the tv to an input of the receiver. aux, or whatever you choose. Simple.
Apr 23, 2009 | Televison & Video
Emerson LC320EM9 32 in. LCD HDTV Logo
49 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
