Question about Sylvania SRC22134 13 in. TV/VCR Combo
Cannot change channels or control tv with remote. Lights come on for the remote so I think something in the TV is broken?
How can i retune my built in free view please
Posted on Oct 01, 2009
I'm using a Time Warner remote as a universal for my TV but when I go to change channels, it just lights up the CBL button and doesn't change the channel. Can I program it to my TV or will it
Hi, you need to de-activate the "programming channel control lock" option. You can see instructions in the manual for the remote. They are as follows:
  1. On the remote control, press CBL once; It will blink once, Press and hold SETUP until the CBL key blinks twice.
  2. Enter 9 7 3. The CBL key will blink twice.
  3. Press CH- once. The CBL key will blink four times.
    Now the remote control will provide TV and VCR channel-control capabilities while in the TV mode.
for any other information with programming this remote:
Download the 1056B01 operating manual with codes for free.
Nov 30, 2012 | Televison & Video
If the remote sensor inside the tv stops working...is there something i can get....a box or something to change channels with another device..some tv cable can go thru before to tv so if tv is on a certain...
Check your remote control for its proper working first. Then think of the remote sensor inside your TV. To get more details about how to check remote control, click this link.
If remote control is Ok, replace the infrared sensor, which can be located just behind the infrared sensor window of your Tv. You have to open your TV, and desolder it out and solder a new one in position. The infrared sensor will look like these. There are sevieral types, and just confirm which type is used in your TV. Picures of some types are attached.
6_14_2012_6_34_32_am.jpg6_14_2012_6_35_11_am.jpg6_14_2012_6_35_33_am.jpg6_14_2012_6_35_53_am.jpg6_14_2012_6_36_17_am.jpg
Jun 13, 2012 | Samsung TV Set Top Box Remote Control
Menu keeps flashing remote control wont work, cant change channel or volume.when i hold down channel up andmess with remote sometimes it changes channel. channel down button is only one that doesnt change...
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
Nov 29, 2009 | Insignia IS-LCDTV32 32 in. Television
TV keeps shutting off and changing channels
hide all your remote controlls and put some tape over the front cover of the tv where you think the remote control reciever may be , if this fixes it then it means something is amiss with a rogue remote , most likely batterys..could even be sunlight ??
Jul 03, 2009 | Philips Magnavox 27MS343S 27" TV
Bought universal phillips remote to replace broken one and can't find code for Daenyx
couldnt find the type of tv you have but i found something that might help you can try these
0005, 0017, 0047, 0050, 0062, 0103, 0146, 0156, 0486, 0237
or you can try doing a code search with the remote below is how to do it
Manually turn on the device (TV, VCR, etc.) to be
controlled.
2. Press and hold the CODE SEARCH button until the
red indicator stays on, then release the CODE
SEARCH button.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to
300 times) until the device to be controlled changes
channel. The red indicator blinks off with each
button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button
to backtrack through the library until the device
changes channel. Pressing CHANNEL UP changes
direction to forward again.
5. Press and release MUTE to install the code.
May 29, 2009 | Universal Remote Control URC-6131N Remote...
I was able to program my Comcast remote to control the volume of my tv, but was unable to get it to change channels. Is there something else that I should do?
Controlling the TV power and volume is probably all you'll be able to do with that control. The Comcast remotes are meant to be used with their converter boxes, and normally people want to change channels on the box while the TV stays on the box output channel (usually 3, sometimes 4). The remote's channel up and down buttons and number keypad only send out the codes recognized by the converter box. You'll need to fall back to the TV remote if you want to control more than power and volume.
May 04, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Remote Control wont Work
I cant seem to program my RCA universal remote to my emerson tv
May 28, 2008 | RCA Universal Remote Control
SHARP T.V. not responding to remote, but remote isn't broken
Same thing happened to my Sharp 29 inch. Stopped responding to original remote the first time, but a universal worked fine. Eventually it stopped responding too all universal remotes. The remotes are good, they work with my VCR, DVD player, and Receiver. It's a nice TV, but having to get up and adjust the volume every commercial break got old a few decades ago! If anyone has any other possible solutions aside from getting the sensor replaced...would be great to hear it.
Oct 29, 2007 | Sharp 32C-240 32" TV
Sylvania SRC22134 13 in. TV/VCR Combo Logo
116 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
