Question about Dell Inspiron 1300 Notebook
Dell Inspiron 1300 - When I re-open the lid,Screen stays Black !
Dell Inspiron 1300 - When I re-open the lid, the screen remains black even if the laptop is well ON, tried closing & re-opening but the screen is not turned on. Display settings..i've got..never turn off the display both on battery and when plugged in. Only solution is a HARD Reboot !!!
Any suggestions ?
Regards
--VEER--
    Scholar:
  • 135 Answers
Your laptop either goes to hibernate or sleep mode when you close the lid. Then, when you open the lid up, the screen is still off because your pc already hanged/froze and could not wake up at all (usual problem in vista). Off course, hard shutdown would fix it. But actual fix is under power options on your control panel. Check your current scheme and edit it. There are options there that you can select to "do nothing when closing the lid"
Hope this helps
Posted on Oct 01, 2009
  • Christian Fernandez Oct 01, 2009
    Hope this helps
Problem with magnetic switch. Sometimes when I
in the control panel power options chnage the setting to never for sleep options and dim display options
Sep 03, 2013 | Dell Inspiron Computers & Internet
RE: DELL Inspiron 1300 Hello, Would a 14" screen
NO! it will fit in the opening but it will not have anything holding it in. So while yes it technically will "fit" it wont work as the screen will fall out every time you close it!
Sep 17, 2011 | Dell Inspiron 1300 Notebook
When i close the lid on my dell inspiron E1505 the screen goes black and when i open it back up it stays black
The cable for the back light inverter board may have come off on the mother board side or on the screen side.
2) Failed inverter board.
3) Failed lamp.
Apr 02, 2010 | Dell Inspiron E1505 Notebook
My Dell Inspiron 2650 screen goes black after start up. It is still working, its just a black screen. I can close the lid, re-open it, and it will stay on for about 5 seconds. Whats the problem, and how...
This problem is caused by a bad inverter. You can find one on Ebay for a decent price. That's where I get most of mine from $8 to $20. Your inverter is located on the bottom front area of your LCD just under the plastic, and it is very easy to replace.
Here is a step by Step Video to help you with most common Dell screens (Copy and paste in your address bar)
http://www.youtube.com/watch?v=l_FtMr_40-w
Here is a list of the most recent prices and sellers:
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+2650+inverter&_sacat=See-All-Categories
Mar 10, 2010 | Dell Inspiron 2650 Notebook
On opening dell inspiron 1300 screen stays blue mess
2 things, reseat the video cable (Under keyboard), and tighten all screws in and around the hinge assembly (LCD Grounds through the hinges)
Sep 23, 2009 | Dell Inspiron E1505 Notebook
Static noise and black screen
hi..
Based on what you are stating, could be power supply problem. Try replacing power supply adapter that Dell supplies. Go on Dell support page using your computer number and you can see if there are any manufacturers recall on the computer or the power supply...
Aug 18, 2009 | Dell Inspiron 6400 Notebook
My Dell Inspiron 1300 wont start
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 09, 2009 | Dell Inspiron 1300 Notebook
Screen stays black after closing and then opening Inspiron 6000
you try pressing the power button once?  or maybe even pressing any keys.
also try adjusting your power management
vista) start. control panel. power option.  Edit plan settings.
xp) right click anywhere.  properties.  screen saver tab.  power management.
Mar 09, 2009 | Dell Inspiron 6000 Notebook
Screen will not stay on
The first thing to check is the LCD or Screen inverter. It is a small board that at the bottom of screen. You have to open up the plastic part of the screen or LCD. Usually this part goes bad.
I am sending you a link of a sample from ebay,
http://cgi.ebay.com/NEW-DELL-Inspiron-1300-B120-B130-LCD-INVERTER-CARD_W0QQitemZ170147223708QQcmdZViewItem
I hope that can help you.
Feb 28, 2008 | Dell Inspiron B130 Notebook
Dell Inspiron 1300 Notebook Logo
905 people viewed this question
Alun Cox
