Question about Husqvarna Garden
HUSQVARNA CYLINDER & PISTONS 575XP where can i buy them
    President:
  • 2,220 Answers
IPL for a 2009-04 pn 537 25 41-02 575XP (complete) here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Bailey's P&C only $351.28 + shipping
http://www.baileysonline.com/itemdetail.asp?item=537+25+41+02&catID=383
HTH
Lou
Posted on Oct 01, 2009
One cylinder bends push rods
Sounds like you're timing is off this unit have a timing belt or timing chain it might've jumped to the valves may be opening two early or too late hit in the Pistons
Sep 10, 2014 | Husqvarna 23hp Briggs & Stratton 48-inch...
Seized husqvarna 575xp chainsaw
Your muffler is clogged,look on line or call your local dealer for part.Here's a link to the parts.
Dec 11, 2012 | Garden
I have a scored piston in my Husqvarna 51 chainsaw. Can I hone out the cylinder and still use it?
You can do that. But it would not run as good or as long as it would buying both the piston and the cylinder housing. You either have to buy both or the try installing a new piston with new rings in it. It should give you enough compression to start it up. But it can't be guaranteed to last too long.
May 29, 2012 | Husqvarna Chain Saw Models 51, 55
Need repair manual with schematics for a Husquavarna 575XP
The workshop manual is not available yet, is there anything specifice you need to know, i am quite up on this model and the the replacment 576xp
Apr 23, 2011 | Husqvarna Garden
On top of the piston there is an arrow with the letters AB what does this keen?
just looked at a couple of pistons not sure what the letters mean ,,,but when installing the piston make sure the arrow always points to the exhaust port of the cylinder
Mar 29, 2011 | Husqvarna Chainsaw Piston Kit for 61...
Tuning of 575xp
The H jet needle controls full speed operation and L controls idle operation. Turn both screws CW to stops (lightly), then back out each CCW 1-1/2 turns. This should allow the engine to start and run. Make sure the fuel filter, air cleaner, and muffler are not plugged. Check the fuel lines for decay or damage. Make sure the carburetor fasteners are tight including the hardware that holds the carburetor to the cylinder. Start the engine and allow to warm up, then pull the throttle full on. Turn H needle CW until the engine starts to speed up--proper setting is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Allow the engine to idle and adjust L CW so that the engine runs fairly well, but allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Jun 21, 2010 | Husqvarna Chain Saw 20" Bar
I have a husqvarna 255r brushcutter, my son put wrong mix when petrol changed to unleaded and the 2 stroke oil, we have it 5 yrs used on 4 TIMES oooh ...but anyway told pistons gone, son and h/band not...
Unless really trashed you can simply replace the piston, and re-bore/resleeve the cylinder, that will cost much less.An competent motor bike, or lawnmower repair shop should be able to do that for you, that way you could get a "Kit" online, and simply do that.
http://www.instructables.com/id/How-to-Repair-a-Lawn-Mower-Engine./
http://www.repairfaq.org/samnew/lmfaq.htm
http://www.bbssystem.com/manuals/Small-Engine-Repair-Ebook.pdf
May 26, 2010 | Husqvarna 28cc Gas Line Trimmer
Hard to start.
My Husky 359 workshop manual says on Appendix A (USA) says "H" 3/4 turn CCW from lightly seated. "L" 1.5 turns CCW from lightly seated.
Page 36 (every other nation on earth) 1 turn CCW from lightly seated for both the "H & L" needles.
There is no recommended initial "T" setting. (from manual) "The idling speed is correctly set when the engine runs smoothly in all positions and there is a clear margin to the speed at which the chain starts to move". I wager your manual would be similar.
These are initial settings and the saw needs to be adjusted for performance. Start with a clean air filter and a fresh fuel mix @ 50:1 per Husky (1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil).
This explains performance carburetor adjustment better than I can:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
I hope you found this post helpful.
Lou
Jan 17, 2010 | Husqvarna Chain Saw 20" Bar
Garden Logo
212 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
