Question about Technics SA-AX730 Receiver
SA-AX7 I have a panasonic DVD-A360EC player. There is a "digital coaxial audio output socket". I want to connect to my SA-AX7 receiver. How can I do this. What is a digital coaxial output connector? Thanks for reply, Best regards, Jan jloopuyt@yahoo.com
    Problem Solver:
  • 11 Answers
Its the orange input on the back of the amp left side of it from the fan says coaxial either above the input or below im not 100% if that will work for you i would suggest you use rca cable.
Posted on Sep 09, 2010
Is there a docking device for connecting iphone with panasonic receiver
There are lots of docks, but they all connect via USB
https://www.google.ca/search?q=iphone+6+plus+dock+connector&rls=com.microsoft:en-CA:IE-ContextMenu&biw=1366&bih=643&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjMh9Hpg97QAhVPVWMKHVosD3kQ_AUIBigB#tbm=isch&q=iphone+6+plus+dock
Your receiver only has s-video.
Total Harmonic Distortion 0.7% (6ohms) (at 20Hz-20kHz)
  • S-Video Inputs/Outputs 5 inputs, 1 output
  • Video Inputs/Outputs 5 inputs, 1 output
  • Video Rec Outputs 1 output (with S-Video)
  • Front Audio Inputs 1 input (S-Video)
  • Digital Inputs/Outputs 4 in (3 optical, 1 coaxial)
  • Audio Inputs/Outputs 6 in, 1 out
  • VIERA Link™ HDAVI Control 3
  • HDMI Input/Output 3 in, 1 out
  • Dimensions (H x W x D) 6 1/4'' x 16 15/16'' x 13 11/32''
  • Weight 11 lbs
    Panasonic SA BX500 AV Control Receiver with High Quality Amplifier Decoder...
  • Dec 05, 2016 | Panasonic Audio Players & Recorders
    I have the panasonic SC-HT400 receiver which I've connected to a bluray DVD player using an digital coaxial cable mainly because I have no other outputs on the blue ray dvd. As you know the Ht 400 does...
    Press the SFC MODE switches at the same time to enter the "settings".
    Change these settings to suit the connections you have made to the three digital input terminals, COAX, OPT1 and OPT2, so that the correct source is selected when you turn [INPUT SELECTOR].
    The factory settings are: CD: COAX
    DVD: OPT 2
    TV: OPT 1
    If you are allowed change them all to Coaxial. That should solve the sound problem.
    Jun 30, 2017 | Panasonic Audio Players & Recorders
    Panasonic sa xr25
    Is the signal connected to coaxial- a digital spdif? If you are dealing with analogue audio connect them to RCA's. Hope this will help.
    Nov 16, 2013 | Audio Players & Recorders
    Adding another device to the system
    Well, if analog works for you connect the CD player's analog RCA cables to the VCR inputs.
    Can you imagine why you NEED to have the TV audio coming into the receiver from the TV? Are the TV's audio system or speakers superior to the audio section of every other source of TV-related programming? We hope not. Does the TV receive any programming that the receiver can not? Maybe games. I imagaine this MIGHT justify running analog TV audio back to the receiver.
    Your cable box and your DVD player have both digital and analog audio outputs. The gray area is what your TV has for audio inputs. It could survive with simple RCA analog audio in from both and none to or from the receiver. Then you could watch Lo-Fi cable and DVD's without the receiver turned on.
    That would free up the TV analog audio input for other things.
    I imagine your DVD player is using one of the digital inputs on the receiver. If you have one each optical and coaxial audio output among your DVD and Cable Box you could place them in the two available diigital inputs.
    Now, what about the CD's digital output? For stereo music you're not likely to be able to hear any difference between it and the analog input BUT it can still be connected digitally IF it has a coaxial output. Coaxial digital inputs can be shared.
    Get an RCA-splitter and join the two units entering the coaxial audio input just before they enter that connection. Either will work just fine if you TURN THE OTHER ONE OFF when you want to us it.
    Mar 19, 2010 | RCA RT2760 System
    When connecting hdmi out from my panasonic blue-ray player to the dvd input in my yamaha rx-v365 there is not audio or video,why?
    There are several video and audio inputs named DVD. For video you have HDMI, component and composite. For audio you have standard analog stereo and digital coaxial spdif input.
    You need to configure the receiver to use the correct inputs - that means HDMI and coax. Also you need to connect the BD player via coax spdif cable to the receiver, because rx-v365 doesn't support audio via HDMI. If BD player has only optical output, use DTV/CABL HDMI input and DTv/CABL Optical input on the receiver.
    Nov 23, 2009 | Yamaha DVD-S661 HDMI DVD Player
    Technics SA-AX7 OVERLOAD problem
    hello there are 2 big capacitor behind the metal heatsink see if one has swelled up if so change them both then check the output chip to see if there are any dry joints then when you've check all and still the same then you may have to change the output transistor g ood luck
    shaun
    Oct 01, 2009 | Technics SA-AX7
    Technics surround sound system
    Use whatever TV sound output conforms to your receiver's input. If an optical or coaxial digital sound output is available, that is the way to get 5.1 surround sound through the SA-DX1050. But you have to assign the correct input (COAX, OPT1 or OPT2) to the selector (TV, DVD, CD). See pp 12-13 of the operationg instructions for D-Input instructions. If you don't have the manual you can download it at Panasonic.com.
    Dec 29, 2007 | Technics SA-DX1050 Receiver
    Digital optical from DVD player produces no audio
    Hi, It sounds like your receiver is still looking for audio on the coaxial connection, rather than the optical.
    1. Make sure the optical connection is between your DVD player and the LD/DVD Optical In on the back of your receiver.
    2. If you have a monitor connected to the receiver to show the on-screen display, click Setup from the main menu, click Input Mode, then, next to LD/DVD choose Optical. It may be set to coaxial, analog or auto.
    Alternatively, choose the input source on the front of your receiver (LD/DVD), then press Input Mode button (bottom right, near the input selector) till it displays Digital Optical.
    If all else fails, reset the receiver by:
    1. Turn off the receiver
    2. Hold down DISPLAY and PANEL UP/DOWN buttons and press power.
    3. All Clear should appear on the screen.
    Use caution, however, as this will erase all the settings in your receiver.
    Nov 28, 2007 | Sony STR-DA90ESG
    KLH R7000
    Nope. That's the coaxial digital audio input. Thats the one to use for your dvd players digital audio output.
    Jan 29, 2007 | KLH R7000 Receiver
    Technics SA-AX730 Receiver Logo
    213 people viewed this question
    Top Technics Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Ben Armstrong
    Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
