Question about Maytag Dryers
Making constant squeaking noise - Maytag Dryers
  • 73 Answers
That would be the berring located in the rear of the dryer only accessable by removing the drum.
Posted on Oct 02, 2009
My 2001 xterra started making a weird sound between 20 and 35 mph. It sounds like there is a leak in some pressure system.
Common Car Noises and Their Likely Causes Noise More Details Likely Cause Fixing It Clicking noise while turning Starts faint, gradually becomes more noticeable until very loud Failed outer CV joint (constant velocity joint) due to torn boot (most likely) or old age Replace either the whole axle assembly (recommended) or the outer CV joint Water pump noises Difficult to diagnose because of water pump's location Noise usually caused by damage to the bearings in failed water pump Only cure is replacing it. If possible do it at the same time as a timing belt replacement to cut down on labor costs Squeak or squeal from an engine belt Loud, high-pitched squeak or squeal Belts either need adjustment or replacing If belts only squeak when damp, they probably just need adjustment. If they squeak constantly, they probably need to be replaced Exhaust heat shield noises Rattle that you hear when car is idling Damaged heat shield Replace heat shield
Sep 28, 2016 | 2001 Nissan Xterra
Why my 2010 Venza drive on sometimes while driving it sound like the transmission is in neutral
Sep 28, 2016 | Cars & Trucks
Fan squeaks when on, what can I do
the bushes on the armature shaft are dry
there is a small felt pad around each bush and if you can get the motor then a few drops of machine oil on that felt will stop the noise.
May 27, 2015 | Dryers
Weird squeaking noise from under hood started from sitting an hour after being driven ,noise goes away when accelerating but comes back when not ,when parked noise is constant a type of squeaking noise
You should have your belts checked for proper tension. If they're squeaking when the engine is at a low RPM then they are most likely loose and need to be tightened. However, that squeak may also be an indication that one of the tensioners in the belt's line may be wearing down. If that is the case the tensioner will need to be replaced since the bearing inside is worn down beyond the point where lubrication would be useful.
Mar 05, 2011 | 1988 BMW 3 Series
My car makes a humming noise when excellerating and is especcially noisey when turning steering wheel to the left. there is also a continous squeak. my husband put WD40 on the bolt on power steering box...
If WD-40 got on belt, and squeak went away for a while, it may just need a new belt. The humming noise sounds like a worn wheel bearing that should be checked and replaced if needed. If squeak goes away when you push slightly on brake pedal, it may be rotor on same side as wheel bearing making the noise due to slight shifting of rotor because of worn bearing.You can try swapping tires on front from one side to other to confirm it isn't tire problem as well. If noise shifts to other side, then it's a tire.
Dec 03, 2009 | 2003 Pontiac Grand Am
Severe squeaking noise coming from the undercarraige....shocks? bushings?
Both the shocks and bushings can cause the squeaking noise. It is very common in those vehicles, and the best bet for figuring out which one is this: put some brake fluid in a squirt bottle, and put a small amount(don't get overzealous with it, as it will remove paint) on all the rubber bushings, and drive it around a little to get it worked into the joints. Brake fluid is designed to work as a lubricant in brakes without degrading the rubber parts, so it is excellent in lubricating the rubber suspension parts. If your squeaking remains, then it is probably the shock. This diagnosis, of course depends on if the squeak is that really obnoxious rubber squeak noise that comes when you push down on the front end and make the suspension travel. If the squeak is the high-pitched one that is constant when driving, and doesn't change except with speed, then it is your brakes telling you that they need new pads.
Oct 21, 2009 | 2001 Chevrolet Blazer
I have a performa dryer which was making an
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
sdfhjyt
Sep 24, 2009 | Maytag Performa PAV2200
GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
May 17, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
49 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
