Question about Brother MFC-8460N All-In-One Printer
I can not send or receive faxes on my Brother MFC
  • 186 Answers
SOURCE: I cannot send nor receive faxes.
Make sure the phone cord from the wall is plugged into the port marked"line" and not "phone".
Posted on Jul 10, 2007
  • 286 Answers
SOURCE: receiving faxes
First make sure your line cable is plugged into the correct place. Most Brother machines have a plug for Line and a plug for Extension (EXT), make sure it's plugged into "Line".
Go into the menu on your Brother machine and select Fax, then Setup Receive and then select Easy Receive. This will usually solve most recieve problems.
Brother machines come with s default of 4 rings before they will answer, make sure none of your other devices (such as an answering machine) are set to a lower number of rings or the fax machine will never grab the line.
If you have distinctive ring, make sure you have it set up in the machine. There is a section in the owners manual for setting up discinctive ring.
If the machine grabs the line and goes through the motions but nothing comes out on the page (no black print) then make sure you are using a Brother ink cartridge (not refilled or generic) and print out the test page using the "ink" button. Allow the machine to clean a few times and see if the test page prints out correctly. If you are using refills or a generic black, you might have premanently damaged the print head. In this case take it to a service centre to have the head tested.
Posted on Dec 29, 2007
SOURCE: Pc-Fax Receiveing problams.
buy a different printer brother sux
Posted on Mar 18, 2008
SOURCE: Brother MFC 8860DN: Send Problems
Update the firmware and it does support SMTP-AUTH
Posted on Apr 15, 2008
  • 8064 Answers
SOURCE: How to fax (face up or face down)
If you put the document on the glass surface, your document should be face down. If instead you use the automatic feed on top of the machine you should place your document face up and the top of the page inside he feeder.
Hope it helps.
Posted on Aug 28, 2009
Testimonial: "Thank you for such a speedy response."
Brother 7340 not sending or receiving faxes line busy
sounds like the modem on your printer has failed depending on how old it is most likely it would be cheaper to buy a new printer
Mar 24, 2014 | Brother MFC-7340 All-In-One Laser Printer
Brother (MFC-7340 FAX, Scan, Print) - Can send FAX...
Be sure to have a noise filter on the ADSL line so the line quality is good enough to send and receive faxes.
May 20, 2010 | Brother MFC-7340 All-In-One Laser Printer
Brother MFC-240 will not receive faxes...
I cant get my MFC-290 to receive incoming faxes
Sep 21, 2009 | Brother Multi-Function Center MFC-240C...
My fax BROTHER MFC-215C does not print after RECEIVING. it also does not send fax after scanning.
The solution, finally, was very simple: To disconnect the mains voltage, for several days, from BROTHER MFC-215 .
After that, I was successful to receive and print the incoming faxes.
Thank you very much for your willing to help.
jacobr05
Mar 27, 2009 | Brother Multi-Function CenterĀ® MFC-215C...
Brother MFC 440CN - How to receive a fax
yes. you have to change to tel/fax mode.
manual (installation and manual) can be downloaded from www.brother.com (choose your country and your mfc). read faq, too!)
Apr 24, 2008 | Office Equipment & Supplies
Cannot Send or Receive Faxes
here you might find an answer:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc240c_all
Mar 29, 2008 | Brother Multi-Function Center MFC-240C...
Nov 04, 2007 | Brother MFC-8860DN All-In-One Laser...
Apr 29, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-8460N All-In-One Printer Logo
51 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
