This is my sencond DSLR-A100. Second because the first one was faulty. It had the same problem!. I am surprised no one mentions these since this is my second DSLR-A100 and it developed exactly the same problem.
The issue is that most of the times the images are not centered. For example if I center a spot through the viewfinder, the picture will not show that spot centered but at the right or left of the center. Also one side of the picture will show dark corners (maybe because since the CCD has moved it is not sensible at that corners). Can someone explain or help? Also, I tried SONY support for the first camera and their support is very bad, I had to buy this new camera. It is sad I am having the same old problem.
If it's done it on two different bodies than it may be a lens issue(slim chance). Try another lens on your body. Sony also uses a movable ccd instead of moving optic for its image stabilization and may be a bad design and really prone to screw up. I would lean toward a super steady shot problem and the ccd is not lined up right. Personally I've not been impressed with anything sony for a long time, when it comes to DSLRs the only real choices are Nikon or Canon. They own the market and have all the experience and product lines to back it up. In recent years build quality has leaned toward Nikon. I would make sony fix it and then sell it asap before it does it again, then buy something more reliable. Just something to think about.
Was this helpful?
Yes
No
Popular Solutions for Sony Alpha DSLR-A100 Digital
the access lamp on my sony a100 will hang up intermittently preventing the photo from righting to...
(More)
the access lamp on my sony a100 will hang up intermittently preventing the photo from righting to the memory card. i first had the problem with a brand new card so i changed the card and am still having the same problem. is there a setting that i have inadvertently hit? the camera has done well for over three years and giving me no problems until this. if you can help thank you, if you cant help thank you for taking a look.
The auto focus on my Sony A is not working. It makes a fast clicking sound when the camera is turned...
(More)
The auto focus on my Sony A is not working. It makes a fast clicking sound when the camera is turned off or on. It sounds like some type of "gears" are stripped? No matter the setting all shots are out of focus. I have removed the battery and replaced, I have removed the lens and replaced it, no improvement. Thanks, Kay
