Question about Canon imageRUNNER C6800 Copier
How do you replace the waste toner on the c6800?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 153 Answers
Its on bottom right hand side of machine is standing in front of machine just undo 2 screws slide out the waste container empty it and put it back in the machine.
goto into service mode and clear the count
Posted on Oct 02, 2009
Where is the tonor waste canon
TONER WASTE IS LOCATED AT BACK OF MACHINE, NEAR TO THE POWER SUPPLY. OPEN FROM SCREW DRIVER
Jan 15, 2014 | Canon imageRUNNER C6800 Copier
The machine has been stopped and show error code E000013-0001
this is explaining on the book
e000013
-0001 The PLL lock isreleased because waste toner motor is locked up, etc.-0002 The micro switch employed to detect clogging of waste toner isactivated.
-0003 The waste toner case is detected full
May 30, 2011 | Canon imageRUNNER C6800 Copier
Error code E000013-0001
getfile.asp?rid=1258 February 2, 2005 getfile.asp?rid=3215 Product : imageRUNNER C5800 / C6800 Title : E013 code and Waste Toner Full message Question :
The copier shows an E013-0001 and "Waste Toner Full" message. The Waste Toner Bottle has been emptied and SW1 is operating properly but the code and the message are still appearing on the display.
Answer :
The counter for the Waste Toner Bottle needs to be reset back to zero in Service Mode.
Enter Service Mode level 1 by pressing * 2 8 *, select Copier > Counters > MISC, then highlight WST-TNR, press Clear - the counter will zero out.
Power off the copier, turn the copier back on, the Waste Toner Full message on the display should clear out.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
Dec 22, 2010 | Canon imageRUNNER C6800 Copier
How to change color toner on Canon C6800
Open front door, you will another blue cover in the centre, colour that neds changing will be exposed.
Jul 25, 2010 | Canon imageRUNNER C6800 Copier
Replace waste toner tank Does it mean that the toner is already used
Open your user manual.
Or get one - go to google or samsung.
The life of the waste toner container unit is approximately 1,250 pages for full color 5% image printing or 5,000 pages for black printing. When the life span of the waste toner container has expired, Replace/Install Waste Toner Tank appears on the display of the control panel,
indicating the waste toner container needs to be replaced. Otherwise your printer stops printing.
To replace the waste toner container:
1 Turn the machine off, then wait a few minutes for the machine to cool.
2 Open the front cover.
3 Pull the waste toner container out of the machine using its handle.
--- above from manual, following is my paraphrasing due to lack of pictures ---
4. remove the container cap from the back side and cap the opening
5. take the new waste container out of its package
6. install the new waste toner container.
___________
You may wish to TRY EMPTYING the waste toner, but you will find toner is the messiest and possibly dangerous (inhallation, etc) stuff you've worked with. it is an extremely find powder and can cause an awful mess and is best disposed of by capping and replacing the container with a new one (shop around to find them).
DO NOT attempt to vacuum up toner - just my personal opinion - I suspect many vacuums may not have fine enough "bags" to capture this intentionally very fine dust. BUT Toner vacuums do exist and some "may" work.
Jul 17, 2009 | Samsung CLX 3160fn All-In-One Printer
C6800 error code E000020-01a9
I don't have the manual for this machine, but if Canon is consistent then you problem is a fuser unit (the device that melts the toner to the paper) that is not heating up for some reason.
Possible causes are:
Blown fuser lamp
Defective thermistor
Defective AC Driver Board
Jan 21, 2009 | Canon imageRUNNER C6800 Copier
Canon c6800 waste toner
I am not 100% sure, but if it not in the front when you open the front door. It should be on the right side of the copier towad the rear of the copier right under the Main Power switch. The pannel is about 3" wide by 16" long and it is held in by two screws, the waste toner bottle should be behind the pannel.
Jan 19, 2009 | Canon imageRUNNER C6800 Copier
Waste toner
right hand side lower right bottom cover 2 scrrews remove cover bottle behind it . then you need to clear counter in service mode in this order touch add func key then 2 & 8 at same time then add func key again screen should change to serv mode then in this order touch copier / counter/ misc/ waste toner/ clear key/ ok turn off then on
Toner Replacement
The cyan and magenta go into the machine through the same aperture as the yellow toner cartridge. The machine will automaticaly rotate the toner turret to the correct position when toner replacement is necessary for that particular cartridge.
Nov 14, 2006 | Canon imageRUNNER C6800 Copier
Canon imageRUNNER C6800 Copier Logo
135 people viewed this question
old marine
old marine
