Question about Electrical Supplies
The generator starts up then dies?
I have a Honda ex 4500 generator it starts right up and idles for a minute then dies?
    President:
  • 1,714 Answers
Check the oil pressure switch. It will shout you down like that if it doesn't sense oil pressure.
Posted on Oct 01, 2009
  • 370 Answers
It sounds like the carburater float is stuck and the cause is when fuel overtime turns into varnish remove the carb and clean with aerosol carb cleaner then let cleaner evaporate completely from carb then start up generator
Posted on Mar 31, 2016
Generator's motor continues to run butb generator stops supplying power after 10 minutes.
this model has an electronic voltage regulator this might be your problem sometimes when gen sets are left outside the little critters and such get in there and build there homes on top of something and that makes it get hot when we finnaly use the gen set , this overheats the part and hence we need to replace the part , if left outside I take fine mesh screen and cover all the air gaps in my stuff cus this has got me in past more than once
May 19, 2014 | Winco WC5500H - 4500 Watt Portable...
Why is my 2000 honda civic ex keep shutting off when it gets over 4000 rpms
After 14 years I think it would be reasonable to have bad catalytic converter. Is there some reason your not accepting this?
May 04, 2014 | 2000 Honda Civic
Engine won't accelerate past low idle
It could be the low oil cutoff check the oil level and add oil if necessary. See if that solves the problem. Hope this helps
Jan 06, 2014 | Honda EU3000i Handi Super Quiet Generator
1994 honda accord ex starts and dies
Well if the check engine light is on, have you had it scanned for codes ???
Jul 02, 2012 | Honda Accord Cars & Trucks
Honda gx 140 will start but dies right away wont keep running
check the oil level and top it up its most liky low and low oil shutdown is kicking in
if it still wont run try checking main jet , then try cleaning out carb and replacing plug
then check for tight in / ex valve s
cheers
Sep 07, 2010 | Multiquip GA25H 25kW 120V Honda GX160
Doesn't always start, dies as I'm driving
sounds like you need a new fuel pump.
Oct 02, 2009 | 1998 Honda Accord
1992 accord replaced the main relay now stumbles and dies
Could be a problem with the ignitor inside the distributor. common problem. beware of aftermarket distributors, like from AZ they are JUNK
Sep 17, 2009 | 1992 Honda Accord
Generator Armature Removal Honda EMS 4500
Sorry, I don;t have a solution but do you have a good coil from one of those you would like to sell?
Nov 27, 2008 | Kitchen Appliances - Others
Electrical Supplies Logo
1,259 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
