Question about Canon PIXMA MP150 All-In-One InkJet Printer
My mp150 wont let the paper feed into it & the b & c lights are continually flashing any ideas
    President:
  • 787 Answers
The ink cartridges are empty.Replace them or press
consistently button for black copy and button for color copy.This will disable the function of the printer to show ink levels and you will continue printing so long as the ink finally over.
Posted on Oct 01, 2009
MP150 paper feed not working on left hand side
Check your paper feeding roller, first clean them
Apr 30, 2012 | Canon PIXMA MP150 All-In-One InkJet...
When we hit the print button to print a page the paper will not feed into the body of the printer and the sign flashes for us to remove jammed paper and hit start button, when we do this it just keeps...
Paper jams
85% of paper jams are caused by worn rollers Chances are, when your tech arrives, he'll tell you that the jams were caused by worn feed rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
MP150 reset:
Feb 11, 2011 | Canon PIXMA MP150 All-In-One InkJet...
E2 error showing
This might be a paper feed error. Try to get a thicker paper onto the feeder and check if it takes it. Try also to check the printer inside for loose parts or loose objects.
May 16, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Paper will not fee, printer will not print
two cartridge inks at end continually flashing so is this why the paper wont feed?
Apr 21, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Paper jam (e3) BUT no paper jam
make sure you open all check points, if yours has a rear feed through, look in there also. it only takes a tiny piece of paper to cause it to say that. use a flash light, have had to use one to find several that way.
Feb 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
E2 flash error
Make sure that you have to pressed the "feed switch" bottom and make sure the light that appears is compatible with the place to puts the paper in.
Good luck, I faced the same problem the first time I bought my canon.
Aug 10, 2009 | Canon PIXMA MP150 All-In-One InkJet...
WONT PRINT
Error 2,3 indicates an issues with the paper feed system. It can either be the timing sensor, the feed rollers, platen, logic board or feed motor. I'd recommend taking the printer into your local canon authorized service facility and having it fully diagnosed and repaired.
May 27, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Alarm/error and paper jam when not jammed
Power up printer,then press & hold (STOP/RESET)button for 5 sec. Then restart printer.I think it fix your problem.
May 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Problem on a canon 3100
The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
Two orange flashes: Out of paper, paper jam, or paper feed error
If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly
Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed
Seven orange flashes: BJ cartridge (printhead) is defective
Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error
A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
PIXMA MP150 => it says E-2-3... Please HELP!!
E23 is a paper feed error. Check the rollers and the paper feed mechanism. Following are the various error codes for your printer: CANNON Printers MP150/MP160 ERROR CODE E9 The connected digital camera / video camera does not support Camera Direct Printing E14 The Ink cartridges whose destination are wrong E15 Ink cartridge is not installed E16 - Ink remaining is unknown E16 -E19 Failed to scan head alignment sheet E22 Carriage error E23 Paper feed error E24 Purge unit error E25 ASF(cam) sensor error E26 Internal temperature rise error E27 Waste ink absorber full or platen waste ink absorber full E28 Ink cartridge temperature rise error - E29 EEPROM error E33 Paper feed position error E35 15 USB Host VBUD overcurrent error - USB E37 17 Abnormal motor driver error E40 20 Other hardware error E42 22 Scanner error
Oct 09, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
109 people viewed this question
old marine
old marine
