PLACE A CD IN DISC DOES NOT SPIN IE NOT WORKING
    Guru:
  • 597 Answers
The CD-rom drive is bad. if the door opens it means you have power. if it doesn't spin up then the drive is defective.
Posted on Oct 01, 2009
Pioneer cdj 400 unit turns on, takes cd, cd spins and then just ejects it.
There are two reasons for this fault. The first one is with its disc loading mechanism. If the mechanism do not place the disc properly on to the reading chasis, this fault can be. It will spin for some time and will ejected automatically
The second one is with its optical pickup unit. If optical pickup unit do not read the disc; due to some fault to it [dust or dirt over the optical lens]. But in this case, there will be only "No Disc" display will be there. No automatic ejection will take place.
With your player, the first sated might be the case. The disc loading mechanism might need replacement.
May 29, 2012 | Pioneer Audio Players & Recorders
The eject function is not working, the yellow led is blinking, as if the machin was reding a disk, but it never opens. I tried also to open it using the screen option but it does the same thing, the lead...
Take it apart and see if the laser is moving up and down (focusing). If not, then the laser focus servo is bad. After it focuses, the spindle motor should turn and the disc should spin. Remove the spindle lock from the top of the drive case and before it spins quickly place the lock on the disc before it spins to hold the disc in place. If all these processes occur and it still doesn't read, check the lens to see if it's dirty or foggy - clean the lens with "Q" tip and alcohol. if this doesn't work, remove the disk and see if a red beam shines through the lens - if no beam, the laser is bad.
Nov 01, 2010 | LG (GCR8525BK) Internal 52x CD-ROM Drive
The CD player will play some purchased CD-s but will not play others. The ones that it will not play do NOT iniate the disc motor but a click is heard and the display reads NO DISC. I have cleaned the...
If you can disassemble the CAP(disc holder) and place it on the disc while it is on the spindle and at the same time push the (hidden)lid switch you will see the lazer"s lens move up and down while trying to focus on the disc. If the lazer see's the disk it will tell the motor to turn. If it dosn't see the disc it will not turn the motor. Some model will kick the disc to spin a little while trying to see the disc. This type of player can be tricked into seeing the disc if you spin the disc a little by hand when the lazer's lens is moving up and down. At that point in time it might see the disc and take over the motor and spin up to normal speed. If the disc is an illeagal copy sold as a original the quality of the disc could be the cause. If the player is very clean (no small hairs stuck to the glue that holds the lens in place) (never clean with a cotton swab, use a shammie swab with rubbing alcohol or isopropal 99%) the problem could also be that the lazer is just not strong enough and the whole lazer-motor assemble should be replaced. Older units could use 1 drop of light motor oil on the motor shaft at the bearing to help start the motor when the system kicks the disc to spin. If the player reads the disc at the time you manually spin the disc maybe a good cleaning and oiling is all that is needed. The disc spins clockwise. if the disk spins counter clockwise replace the whole assemble. Maybe simpler, just give the disc a good clockwise spin and quickly close the door and push play while the disc is still spinning. if it starts, there you go. Don't use caned air on the lazer assemble. it will blow the dirt further into the lazer mechanism under the lens and make matters worse! Good luck!!
Oct 29, 2010 | Sony CFD-G50 Cassette/CD Boombox
CD Player won't play discs.
lens life is over .get it changed.
Jul 26, 2010 | Audio Players & Recorders
Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Mar 30, 2010 | Philips CDR775 2-Disc CD Recorder
My cd player D-FJ003 says "no disc" now whenever I put any disc in. It was working fine before.
I have two of these players now and i know what this is. It is because of the disc holder. It has been pressed down to the bottom and no longer lets the motor spin the disc. The fix is to carefully pry off the small disc holder that spins and find a place where it will spin freely then apply superglue to the center of it and very carefully sliding it back on making sure its not too far down as to not play. Let the glue dry for a long time and carefully put a disc on and see if it plays. This worked with mine but i kind of broke it in other ways and didnt let the glue dry fully so its still kind of scetchy so i bought another on on ebay for like $10.
Feb 17, 2010 | Sony Walkman D-FJ003 CD Player
The tray of cds does not work properly, does not allow the change of disc to disc and stuck
Try pressing repeatedly the eject button while you turn on the unit. If this doesnot work
then it is a mechanically problem in your player .
You need to manually open to take out the cd .
The rubber thread which should be connected to the motor inside the cd player might have moved from its place.
You need to place the rubber thread to proper place.
Also if the belt is slipping, the mech never gets the "drawer closed" signal, and the disk will not spin.
Mar 04, 2009 | Aiwa NSX-A505 CD Shelf System
My (second hand) CD/DVD drive will do everything BUT burn discs???
download free nero software
will it select what you want the disc to be
DVD or CD
May 01, 2017 | QPS Computers & Internet
Xbox 360
you need to send it off to get repaired
Aug 26, 2008 | Microsoft Xbox 360 Console
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
