I had removed my pc to another room but after installed and checked all the cables connection the cpu was on but monitor and keyboard was not working
    Guru:
  • 597 Answers
You might have bounced the video card out of the motherboard. Open the case on the computer (with power off) and push down on all the cards and make sure they're seated in the motherboard then try starting the computer again.
Posted on Oct 01, 2009
Testimonial: "very helpful...i`ll give a try..hopefully this time it works..tq"
    Problem Solver:
  • 19 Answers
Disconnect it all and plug all the components back in one by one. Remove power cord and press in power button for 20 to 40 seconds to discharge power supply. Plug in power cord again.
With the computer turned off, just plug in the keyboard, mouse and monitor. Power on your computer. If everything is working, turn of your computer and plug all other cables/accessories/peripherals in and power on again.
2 Suggested Answers
muntejaya
  • 10421 Answers
SOURCE: i had removed my pc
Please check and fix your VGA cable for loose connection.
Regards, Jay
Posted on Feb 10, 2011
No signal to monitor
Check all conections between the tower and the screen, make sure all are secure, if no joy, unplug the tower and remove the side panel to see if the graphics card is in securely, maybe take the graphics card out and put it back in again to be sure. If you have another monitor or monitor cable try replacing to see if the situation improves.
May 05, 2011 | Acer Aspire M1641-U1521A PC Desktop
My dell moniter shows purple light at the power button instead of blue/orange.... and its not workin.. wat could be the problem
First of all you need to check you keyboard light it may be the issue with your CPU. So check you keyboard light and press Num lock key if it's getting on/off when you are pressing the key. If it's working or not. It must be blink when you press the num key. If it's constent or not getting on then check with you CPU first ....may be there is some issue with you CPU. Second you can remove the cable from CPU which is connecting to monitor to check ....when you remove it from cpu it will give you some message on the monitor screen that check you vga cable etc. If it give's such message then it will be for sure then you need to your CPU fixed up.
So please comment back with your troubleshooting details , hope it will help out you.
Thanks Sanjay Kumar
Apr 26, 2011 | Dell SE198WFP LCD Monitor
I just bought Logitech Clearchat Premium PC, how do I get it to work?
Assemble it: connect the data cable from the monitor to the CPU, Connect the mouse and keyboard to the CPU, connect the power cables for the CPU and for the monitor, press the CPU power button, and the monitor power button. If the computer doesn't work, then it came without an operating system.Get the operating system disk and insert it into the DVD or CD ROM/RW drive. Turn the computer off, and turn it on again. Check the monitor carefully and when it prompts for pressing any key to boot from the cd, do so very fast. The process of operating system installation will start. Follow the procedures and instructions it gives you till the end. If you are not sure of any step, ask or consult any person who can assist.
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 12, 2011 | Computers & Internet
When i plug to the cpu monitor cut off the power and green light is blinc
Do one think just plug out Monitor to CPU cable , just on monitor only if so can you able to see one small icon go top to bottom its like keyboard, if you can see that, you don't have any problem on your monitor.
step 1 - just remove ram slot and insert again try to ON your system now
step 2 - take your cpu and connect to other monitor and check where it getting on or not , if monitor get ON and work good mean you don't have problem with your CPU , problem was in monitor to cpu cable ,so change your monitor cable its just cost of 4 to 5 $.
step 3 - take your monitor connect to another CPU , check weather you getting same problem if it work good mean, your CPU motherboard have problem just call your hardware engr to solve it,
GOOD LUCK ! if your problem solved don't forget to rate
Dec 31, 2010 | Samsung SyncMaster 913V 19" Flat Panel LCD...
I have a new pc but i donot know how to install it this is a new pc. I want to start up it
Please connect it through Power supply via power cables and connect CPU with Monitor via VGA cable and connect Mouse and Keyboard with CPU .And press Start button .
Oct 05, 2010 | Computers & Internet
Desktop screen is blank even when the cpu and monitor indicator a
It looks like issue with either mother board or processor.
open the box and remove all memey and power it on. if it makes a beep sound, there is no issue with processor, else we suscpect processor. If it make beep sound, it might be mother board issue. And for checking monitor working condition, remove monitor data cable and see no cable connected messages comes in monitor or not
Oct 13, 2009 | Dell Computers & Internet
Install dvd rom and remove one of the cd rom's
hi! replacing cd room,open your cpu cover by two quick lock bolt at back side of your pc right side,show on figure w/ arrow where the quick lock bolt.c1c13bc.gifthen pull out cover and you'll cd rack inside your cpu as shown on figureba392e9.jpg release 2 lock screw,and pull out i.d.e cable on cd room terminal also the audio cable next to leftside if have one,next the front cover of cpu thats locking your cd room theres a cliff lock on side opposit of the fron cover lift it by flat screw driver slowly and careful it might broke,after cover was detouched,don't remove any wire connection on front cover,pull out your cd room replace by dvd rom and connect all what has been disconnect on cd room put back front cover,and connect pwer,audio and ide cable again then try to switch on your dvd rom is a plug and play you can install your dvd installer and follow wizard instruction and click finish...regards
Mar 27, 2009 | Dell Dimension 2350 PC Desktop
No display
check if all cables are connected.
turn on pc...observe all lights
test the monitor to other pc...
if monitor is good
check if everything inside the CPU are connected.
Mar 13, 2009 | Mercury P4VM800M7 Motherboard
I have a pavillon a6421 uk hp computer when i turn it on the monitor comes up with no vga signal (i have changed the graphics card and it is still the same) have done all the trouble shooting options...
Hi
First Check the power cable of ur monitor whether power is coming or not..
Then remove signal cable (which is connect the cpu) and then switch one the power, check whether any msg is coming in screen.(like no signal or no connection) if it comes means u want to check the cpu or else their is problem in ur monitor..
Connect the another monitor with ur cpu.Whether ur cpu is working properly..
Sep 19, 2008 | Computers & Internet
Computers & Internet Logo
204 people viewed this question
David Payne
David Payne
