Question about JVC Televison & Video
Jvc 52 inch tv. the picture on the upper left corner drops and is discolored
  • 336 Answers
Hi if your tv is a Dlp or Lcd it will be a problem with the light engine.Basically there's 3 chips green,blue,red that create the image and colors.When they start to go bad or melt you will get color discoloration on corners on the center.You will need to replace the optical block ,you can find it on www.discount-merchant.com www.shopjimmy.com or ebay .Have a blessed day!
Posted on Oct 01, 2009
I have a 52 inch samsung with blinking and jumping picture LN52A650A
The problem must be to its T'Con board. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 800 posts to different brand TVs now. Pull up older posts there..
Sep 22, 2012 | Samsung LN52B550 52 in. LCD TV
A vitamin bottle was thrown at the tv and now its discolored on the corner. it's 2 years old. can this tv be fixed? it's 52 inch tv
Sounds like the screen was broken from the impact.
They can be replaced but are very expensive. Between labor and the cost of the screen it may not pay to replace it
Apr 05, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
I have a jvc av-56wp74 56 in rear projection tv it has a lil purplehalf moon on upper left corner about 1 ft wide and 2 inches down and the tpo lefthand corner is lil blurry the rest of tv is fine any help...
Well David, it sounds like you need to unplug and open back and try to stick your head up in set and look down into CRT's tubes, you may have phopser damage on one of the tubes, you will need to turn on to see it just be careful not to touch anything electrical
Feb 02, 2011 | JVC AV-56WP74 56" Rear Projection...
Problem with JVC CRT TV (slim) with screen to have red color at the lower left (facing the TV) corner and a green color on the upper right corner of the screen. Sometimes while watching TV shows, the upper...
There is strong magnetic field around the TV. This may be due to the tower speakers or any portable radio kept close by.
Re orient the TV try switching OFF / ON at the intervals of 30 minutes. The built in auto de-gauser will correct the problem. In cable TV program if the picture is OK, nothing wrong in the TV.
Check with a different CD.
May 19, 2010 | JVC AV-21QMG3 21" TV
Picture vertical output has reduced
TV has no cathode 200 volts supply.
If you have experience of CRT TV repair then let me know to guide you further or get help of near by TV tech person.
Nov 30, 2008 | Sony FD Trinitron WEGA KV-24FV300 24" TV
Blue light and lamp light flashing, no picture.
Look in the owners manual for the directions on how to remove the lamp. Your model the lamp goes in from the front on the left looking at the TV. There is a thumb screw in the back on the corner holding the left front speaker on. Under the panel there is another thumb screw holding the lamp door on. You will need a Phillips screw driver to remove the lamp. You will most likely find that the lamp is bad. You will either have to order a lamp directly from JVC, a service center or a parts distributor.
Apr 21, 2008 | JVC HD-52Z575 52" Rear Projection...
Jvc tv
It may be lamp, Look at the lamp and see if there is any discoloration inside, but do not touch the lamp glass. The oils from your hand will heat up and blow the lamp. The lamp part# for your model is TS-CL110u. Hope this helps.
Dec 15, 2007 | JVC HD-52G886 52" Rear Projection HDTV
Discolored edges on my 36"wega sony t.v.
This is not the right model number for this TV set.
Jul 24, 2007 | Sony Part 996804671 Service Manual for...
Televison & Video Logo
104 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
