Question about Fuji FinePix 2800 Zoom Digital Camera
My Fuji Finepix 2800 works fine but has a battery problem.
My Finepix 2800 works fine but has a battery problem. If I leave the camera for more than about a week the batteries go flat. I have two brand-new sets of Duracell 2000mAh NiMh batteries, and whichever set I leave in the camera goes flat, whereas the other set stay charged, so the camera seems to be discharging the batteries even when it's switched off.
PyroMan6x9x9
  • 150 Answers
SOURCE: fuji finepix a330 digital camera says "low battery"
To help rule out if the battery, camera, or even your charger I would suggest to first clean all the contacts. This can be done with some rubbing alchol and a q-tip, make sure you get the contacts in the camera, directly on the battery, and your charger. Wipe off any excess alchol and let it sit for a minute or two so the alchol can evaporate. Give the battery a good charge and see what happens. Where did you purchase that replament battery? If what was under 10bucks I would suspect it's the battery, there are a ton of crap battery's hitting the market, always stick with name brand. Another possibility is that the charger could be sending the wrong voltage to the battery causing inproper charging, or even the chargers power cord could be sending the wrong voltage to the charger. Anyway I'm done rambling, It's 12:15am and I have a 70hour week starting in 6 hours so i'm outta here. Hope this helps. And here's a link to your manual if you need it: http://www.fujifilmusa.com/JSP/fuji/epartners/bin/A330A340Manual_1.pdf L8R Good Luck
Posted on Sep 16, 2007
SOURCE: fuji finepix 2800
I have the same camera and Vista and it works fine. Just plugged in USB and it worked. Also fine with taking out flash card and plugging that into PC.
Posted on Dec 27, 2007
SOURCE: Fuji FinePix A900 Digital Zoom error
Same problem with me. Got a zoom error. I thought "it's still under warranty, so Fuji will help me out." WRONG! Fuji repair claims it has impact damage, but that's not true. The product is just defective. Fuji charges $113 to get it repaired. It cost me $140 from Dell only 7 months ago. Defective.
Posted on May 28, 2008
SOURCE: what color should LED be when charged on duracell NIMH charger
When the batteries are charged fully the light should be green.
Posted on Mar 01, 2009
t00nz
  • 4738 Answers
SOURCE: fujifilm battery fully charged but camera says no
Well you mentioned that it worked fine yesterday with the battery out of the box. That should tell you that the camera and the battery are both fine. The issue is likely the charger itself. Try recharging it again, and double check that you inserted the batteries correctly, and that any switches (such as for 2 or 4 battery charge) are set in the correct position on the charger. If this doesn't work, take the charger back to the store for exchange/refund as defective.
Posted on Jun 11, 2011
My Fuji finepix 2800z uses batteries up in seconds. Works fine otherwise and is ok with DC. Shame as it is such a good camera. Any ideas why and if it can be fixed? Thanks
Wow, these cameras work the best with rechargeable type batteries the Alkaline batteries will just die before you get 50 pictures. If you are using the LCD screen all the time it's a power hungry hog and will kill the best of batteries quickly.
You should program the camera to auto shut off in 2 minutes, review time should be about 1 minute and the camera should be in sleep mode or turned off between pictures to conserve as much power as possible.
I use a Fuji S100fs camera a lot for a walk about, documentary, time laps and generally shooting and can get about an hour of continues use from one battery and about 190 frames.
Apr 19, 2011 | Fuji FinePix 2800 Zoom Digital Camera
Zoom Error on FinePix 2800
try resetting the camera by removing the batteries
Jun 24, 2008 | Fuji FinePix 2800 Zoom Digital Camera
I copied pix to laptop using Nikon Transfer. I
Try formatting the memory card in the FujiPix 2800 camera. See if that helps..
Oct 01, 2009 | Fuji FinePix 2800 Zoom Digital Camera
Wont work on any batteries
What kind of Nihm batteries you have? I bought mine 6 years ago and they still run this camera awesome :) Purchased mine from radio shack. I lost my cd to have the software on my computer and I can't seem to download it from the fuji site and get it to work :(
Sep 02, 2008 | Fuji FinePix 2800 Zoom Digital Camera
Fuji finepix 2800
If there is solution out there please post it. I have the same problem
Dec 02, 2007 | Fuji FinePix 2800 Zoom Digital Camera
Missing Download Disk, Thrown away with Camera wrapping
software for 2800: go to fuji site for download. also, you can remove the memory card and insert into a reader avail for about $8.00. your computer should not need special software to read a memory card from a reader. if your computer has a usb 2 port, use a usb 2 reader to save time. mark
Nov 24, 2007 | Fuji FinePix 2800 Zoom Digital Camera
Fuji Finepix 3800
The date time problem ist he internal battery[ A watch type button inside the camera body]
has worn out- replacing it will be a workshop job.
The other problem seems like wear and tear on the switch any repair will be costly.
Just live with[out]it- or buy a new camera
Nov 20, 2007 | Fuji FinePix 2800 Zoom Digital Camera
Color wrong and red spots
Sounds like CCD sensor problem . It starts with 'noisy' pictures ( colors not true and resolution deteriorates )but eventually the sensor stops outputting anything and you end up with blank screen. Have the sensor replaced and camera will work fine.
Sep 11, 2007 | Fuji FinePix 2800 Zoom Digital Camera
My computer will no longer recognize the camera
Maybe you need to add a software driver for your FinePix 2800, got a disk with the camera? Try loading (reloading?) the driver.
Jun 11, 2007 | Fuji FinePix 2800 Zoom Digital Camera
Fuji FinePix 2800 Zoom Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
