Question about HP PSC 1315 All-In-One InkJet Printer
Print cartridge error
I changed my colour print cartidge to a new one and everytime i turn my printer on, a message pops up 'Print cartridge error'. I tried cleaning the printer but it still doesnt work. Please reply to me as soon as possible. Thank you.
    Novelist:
  • 208 Answers
Press either the menu or setup button.
There should be a maintenance section where you can do eletronic print cartridge cleaning and print head alignments and calabrations.
Some of them can be done at the computer if you access the driver properties.
You can clich the print queue and look around there also for print head cleaning and some other diagnostic procedures.
If those don't resolve the problem, remove the cartridge and take a fuzzless cloth dampened very slightly with alcohol and clean the contacts to the print cartridge.
PLEASE REMOVE THE POWER when cleaning though.
Posted on Dec 20, 2007
Cannon S330 Printer was operating correctly, print cartridges required new. cartridges changed, will not print, after a time then would print black only, after more time colour began to print for several...
Sounds like your print head may be faulty. If you can, get it replaced. This is caused by using recycled cartidges or faulty ink cartridge.
Thanks,
Lolita
Jun 12, 2008 | Office Equipment & Supplies
Epson printer will not print any copies. I get the message "change cartridges 98/99." I did change both cartidges and can't clear the message and print copies.
i assume that everytime you try to print you get the same message. i sometimes get cartridge unrecognised on my epsom. I have to remove the cartridge, wipe the chip on the cartridge and reinsert.
If this doesnt work please specify printer model and if using original epsom cartridges.
Nov 15, 2011 | Office Equipment & Supplies
It says check print cartridge
first of all turn off the printer ... remove the cartidge.... try to clean the slots where the cartidges gets installed as well you will find dotted bronze spots on the cartidges try to clean it... turn on the printer and inser the cartidge... if u still get the error the msg for both the cartidge try putting in a new cartidge id you can and if still there is the messag if might be th problem with printer.... replace the printer....
Apr 30, 2010 | HP PSC 1315 All-In-One InkJet Printer
HP Deskjet 5740 I have not used my printer in some time and both cartridges are half full. It printed with the black but came out with gaps in the printing so i took the cartridge out and put it back...
it is better to change the black cartige becaue there is the jam of the ink in black cartidge. or pick out the black cartidge and clean with soft paper in the place from where color is pour. then reinstall the cartidge. i hope it will ok. otherwise, change the cartidge.
byee
May 09, 2009 | Office Equipment & Supplies
I have a hp psc 2410 .the black is printing beautifully but the colour it printing doubled or blurry. changed colour cartridge and still the same. help please
Your inkjet nozzles may be clogged with old dried ink. Try removing your color cartridge and looking at the area on your print carraige where the inkjet cartridge mates up with the carriage. Use a Q-tip and warm distilled water to gently swab this area until all the old ink is dissolved and it wipes clean. You may need several Q-tips for this. Allow to air dry and reintall your print cartidge. Your printer should go into an automatic cleaning cycle. You may also need to gently clean the area on the cartidge itself using the Q-tip method. Good luck.
Feb 20, 2009 | HP PSC 2410 All-In-One InkJet Printer
Error says color ink not installed.
dear,
u have to clean the are with a soft, a little bit wet cotton, where the cartridge is installed. its not sensing that one. also clean the area inside the printer where catridges go for cleaning. there is a foam type material inside that. clean that dirty part.
regards,
Jul 29, 2008 | Canon PIXMA iP90 Mobile Printer
Cartridge problems
Clean the heads, printer is not reading new cartridge or refilled cartridge. You may also have a paper jam if alignment is affected. Check for little jams, post back if no go lilacgerry xxx
Dec 28, 2007 | Lexmark X4270 All-In-One InkJet Printer
Replace color cartridge
Access your printer properties and try preforming a print head or printer cartidge clean and on the machine try the print cartridge aligniment procedure.
If after you try both of those I suspect there is an issue with the print head.
If that is the case an ink jet printer is not worth repairing.
Dec 20, 2007 | HP PhotoSmart 7760 InkJet Printer
Lexmark x1180 printer all in one
Clean the contacts on the cartidge and printer ( open the replace ink door wait for the printhead to come to center and turn off power) if that does not work then replace cartridge, it might be a recycled one that they did not chane the chip.
Oct 11, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
HP PSC 1315 All-In-One InkJet Printer Logo
55 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
