Question about Vacuums
Poor suction in electrolux theboss power 1300W and LG HEPA filter 1500W vaccum cleaner. have checked bags no problem. It doesn't pick up any dirt.
  • 41 Answers
If the motor is truning perfectly without any strange noise,please their be an obstruction suction side
Posted on Oct 01, 2009
No suction in vaccum cleaner
Look for a clog somehere in the intake path, perhaps right at the top of the canister.
Feb 13, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Electrolux VACUMM CLEANER LITE II
get new bag filter , empty dirt out to garbage bag , clean hose .
Dec 26, 2013 | Vacuums
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
Would a clogged hepa filter cause the vacuum to stop picking up dirt? There's suction on the hose when I checked it.
Generally the Hepa filter is a bypass filter in which there is another filter on the unit. Check to ensure that the belt is allowing the rollers to turn the brush. Just suction on the line won't pick up deep dirt unless you allow to sit in place.
Oct 05, 2010 | GE 106585 Upright Vacuum
My Electrolux guardian C135 vac has lost suction. replacing the bag does nothing. removing the HEPA filter has no effect - what do you suggest? Will a replacement HEPA filter make any significant...
No you have a clog in the hose, wand or at the power head. Remove the hose wand and power head from the the vacuum. Turn on the vacuum, put the palm of your hand over the hole in front, you should feel plunty of suction. Then replace just the hose and put the palm of your hand over the end of the hose. If you do not have suction the clog is in the hose. You can try putting the hose on the blower port to blow out the clog or use the wire from a coat hanger. If you have suction, then add just the wand and repeat. If you have suction, then the clog is in the neck of power head, you will have to use a coat hanger to clear it.
May 08, 2010 | Electrolux Guardian Bagged Canister Vacuum
Brush doesn't spin and there is no suction there either, the brushes move freely when manipulated manually
Check for clog in the hose or what ever connects the nozzel to the collection device. I pick up vaccum cleaners all summer, most new, all clogged, all from the trash.
If possible, take the machine outside, open the collection device, run the motor. Is there suction you can detect anywhere?
Sep 07, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dirt devil swivel glide - no suction
check the filter gauze on the unsud of vack where bag is if this is blocke you will not have vacuum as there will not be ventilation thro this filter should be able to feel blow of air from this vent when vacuuming up hope this helps good luck from uk !
Nov 02, 2008 | Vacuums
Dirt devil 12amp,Patent No.6571425
Either it needs a new belt, they stretch and break, then won't turn the brush roll. The dirt inlet by the brush roll is clogged, the hose may have a clog in it, filters are bad. If the hose comes off on one end, is there suction there, is so then the clog is farther down. If no suction, then the clog is in the hose or filter.
Mar 02, 2008 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Vacuums Logo
95 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
