Question about Konica Minolta DiALTA Di200 Copier
F-28-3 knoica error
I am getting the same error but i dont know which screws to take off becuaes my machine is the konica 7030, so please help
  • Konica Minolta Master
  • 1,294 Answers
F 28-03 The toner separation ON/OFF operation has been performed 5 consecutive times since the separation trouble detection signal was detected at start of toner separation.Please check the HV2 unit,the transfer/separation corona unit.If there is a paper in copiymg proces when this jam occurs the machine stops after completion of copied paper ejectiom.
Posted on Oct 01, 2009
F-28-1 curently appears on my screen
F 28-01 High voltage power supply abnormality.
Ihe charging ON/OFF operation has been performed five consecutive times since the charging trouble detection signal was detected at start of charging.If there is a paper in copying process when this jam occurs,the machine stops after completion of copied paper ejection.Verify the charge wire,change and the holders.Check the high voltage unit.
F - 28 -02 Toner transfer wire malfunction
F - 28 -03 Toner separation wire.malfunction
Feb 11, 2013 | Konica Minolta Konica 7020 7022 7025 7030...
Knoica minolta 250W printer cartridge jamed lever and mechanism cam off I cannot move it now thw whole machine has jammed what can I do please?
OK... YOU HAVE TWO POSSIBILITIES... EITHER THE LEVER ON THE TOP COVER BROKE OR THE ONE ON THE PRINTER CARTRIDGE...
IF ITS THE ONE ON THE TOP COVER THEN YOU NEED TO REMOVE THE LEVER HANDLE COMPLETELY AND GET A PLYERS AND USE IT TO TURN THE METAL THE LEVER IS ATTACHED TO OR FIGURE OUT WHERE THE THE LEVER GETS THE MACHINE TO LATCH AND USE A FLAT HEAD SCREW DRIVER AND SLIP THE LATCH... THEN CONTACT KONICA MINOLTA AND PURCHASE A NEW LEVER...
IF ITS THE TONER LEVER THATS BROKEN... YOU ARE GOING TO HAVE TO GET A PLYERS... TAKE A FIRM GRIP ON THE TONER AND REMOVE THE TONER IN THE SAME WAY THAT YOU WOULD IF THE LATCH WAS THERE... IF ITS BEEN PUT IN ODD THEN IT MIGHT BE STUCK... YOU MIGHT NEED TO USE A FLATHEAD SCREWDRIVER ON THE ENDS TO HELP THE PROCESS ALONG...
USER MANUAL
Feb 12, 2011 | Konica Minolta magicolor 2500W Laser...
SCANNING PROBLEM KNOICA 7165
contact whit the engineer probably u have to instal new firmware
Jun 23, 2009 | Konica Minolta Office Equipment & Supplies
Call factory code F-28-3
ts corona is shorted could be either the corona wire is broken or the terminal is arcing
Jun 15, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
F 35 7 on a Konica 7030
F35-7 is fuser error on a konica 7030. Resetting the fuser error might just fix your problem. First turn your copier on while holding down the 2 and 5 key. Next press 1 for soft switch setting, then press the left up arrow key to 3 and the right up arrow key to 1, now press the OFF key to change the data to 0 (it should read 3-1 :0)press return. Power the machine OFF/ON. If the problem persist then you most likely have a bad thermistor, however it can also be a bad heat lamp or thermistat.
May 11, 2009 | Office Equipment & Supplies
Konica minolta 7030 drum replacment
Is this a photocopier? If so then you will need a technician to fit this for you
Jan 02, 2009 | Office Equipment & Supplies
Konica 7030 copier/printer - service codes
Are you sure it's not 34-2.I don't see or know of a 32-4 in my service manual.If it's a 34-2 write back and I'll reset it for you.
Jul 24, 2008 | Office Equipment & Supplies
Konica 7030 F-34-1 code
try to change the thermistor, if u confirm both the heater lamps is working.
the fuser unit from 7022 is not compatible with the 7020 machine.
May 29, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Setting the IP address on Konica 7030 multi-function copier
if you don't have a netwok card in you Konica 7030 then you have to connect it to your computer over LPT cable or USB Cable then install the software from the Konica 7030 CD.
after that you can Share the installed Konica 7030 Printer and map it at the other computers.
Try and feed back...
Regards
May 03, 2008 | Office Equipment & Supplies
Konica 7020
Did you blow it up, probably not.
Click this link for the everything.
http://www.kmbs.konicaminolta.us/content/support/supporthome.html
  1. Choose the Category "Office Systems"
  2. Choose the model "7020"
  3. Click the error next to the Model dropdown box.
  4. Choose the 1876KB user manual called "User Manual for 7020, 7025, 7030 and 7035"
Or click on this link for the specific manual.
The error codes you seek are not in the manual, you'll have to call Konica to tell you what they are ... call Konica at (860) 683-2222.
Hope this helps. Rate a fixya!
Dec 10, 2007 | Konica Minolta DiALTA Di200 Copier
Konica Minolta DiALTA Di200 Copier Logo
246 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
