How to use an RF scanner? I have never used one of these devices and I need to learn how to use one for my job assisgment.
You are on the wrong site. you need to find out what kind of RF scanner you will be working with and find the tutorial for that device on the mannufacruer's website. If you for some reason can't find out what kind it is you may recognize it hear: http://www.barcodesinc.com/cats/barcode-scanners/cordless.htm good luck.
Posted on Jan 30, 2010
Does the AquaLink RF channel have to be specific to the IO jumpers?
check the AP radio frecuency and channel, mey be the antenna is not compatible
Oct 13, 2014 | Jandy iAquaLink Kit with RS PCB Upgrade
Program remote to replace all remotes
Hi, yes of course it is possible! First off, you have to make sure that your Dish device it set on remote address 1 in order for it to be controlled by the Harmony. Then, once you add the device to your Harmony account, if there are any functions that are missing, you can learn them right from the original remote .
Adding a device:
1. In the software, clcik 'Add Device'
2. Follow the on screen instructions.
Learning a command:
1. In the software, click 'Learn IR' next to the icon for your Dish device.
2. Go down to the bottom of the page where it says 'Learn a new command'
3. Type in a name for your command, and click 'Learn'
4. Follow the on-screen instructions.
Hope that helps you get this set up right!
Mar 17, 2010 | Logitech Harmony 700 LCD Remote Control
How do I use rf barcode scanner ls4278?
Hello, if you download the user guide or product ref guide, these will walk you throught the steps you need to configure your scanner
Mar 08, 2010 | Symbol LS 4278 Barcode Scanner
How to change the display settings for MC9090-G RF Scanners
Hello, if you go to support.symbol.com and download the mc9090-g users guide, it will walk you through changing your display settings
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=7221506apdf&sliceId=&dialogID=165472011&stateId=0%200%2019451184
if you need assistance please let me know
Kim Ganoe
800.933.2839 x251
Jan 31, 2010 | Zebra Symbol Technologies MC909X-G Series...
Harmony 890 Pro will not pair with Xbox360
The RF signal is on the XBOX is used for the controllers only.
When using the Harmony 890 with a 360, you will have to use it as an IR (infrared) device. That is the only way to use a remote with the 360. If you have an extra port on your RF extender, you can place the end on the remote senor on the 360 (located under the eject button).
I set these remotes up weekly, it is a product I recommend to people all the time!
But again, the only way to setup a remote with the 360, is to use the IR port as a standard IR remote. Since the controllers run off RF, the learn function will not work, unless you already have 360 remote control to use to do the learn function.
Hope that offers some insight. This information can also be verifies at Microsoft XBOX 360's FAQ page.
Oct 21, 2009 | Logitech Harmony 890 LCD Remote Control
Harmony One remote won't input channels very well
Most DirecTV receivers are able to be controlled with IR (infrared) or RF (Radio Frequency) signals. DirecTV receivers are usually set to be controlled by RF.
To control a DirecTV PVR / Satellite, it needs to be set to respond to an IR Remote:
1. On the original DirecTV remote press the Menu button
2. From the Menu press Select on Settings
3. Select Remote from the left menu
4. Press Select on the IR/RF Setup button
5. Use the Up or Down arrows to change from RF to IR
6. Press Select to save
Note: Some models of DirecTV may have different steps to enable IR. You may need to refer to your user manual
Harmony Remotes only control IR signals. so this is not the issue. The Harmony Remote should control the tv. the original remotr needs to be tested for IR or RF.
The device we are working on that is not being controlled by the Harmony Remote could be operating on RF (Radio Frequency) signals. Harmony Remote can only control the devices that operate on IR (Infrared) signals. Most devices that work on RF signals can be changed to operate on IR signals, and this usually could be done by changing the remote control command mode to IR from RF.
Please follow the steps listed below to test to see if the device is being operated on RF or IR signal:
1- We need to use the original remote for that device to complete this task
2- Using your hand or a thick and wide object (wall, pillow, book...), cover the top part of the original remote. In other words block the direct positioning between the original remote and the device.
3- After you cover the top part of the original remote (or used an alternate way to block the direct communication of the original remote and the device), try pressing the buttons on the original remote to see if it can still send commands that can be received by the original remote. You can try powering on/off your device using the original remote when the original remote is being blocked by your hand or another object.
4- If you still can control the device using the original remote without a point of sight, your device is being operated on RF signals. If you cannot control the device without a point of sight, then it is IR operated.
5- If the device is RF operated, please change the command receiving mode to IR rather than RF and test the Harmony Remote.
6- If the device is IR operated, please contact us again by replying to this email and let us know if none of the commands or some certain commands are not working for that device.
You can usually find the information on how to switch the device to be operated on IR signals rather than RF signals, through the user manual for your device, or by contacting technical support of the manufacturer for that device, or even sometimes reaching the information simply by doing a basic research over the internet.
Mar 31, 2009 | Logitech Harmony One LCD Touchscreen...
We have an industrial setting. We're using RF devices, scanners on lift trucks that move through our warehouse. We are losing connection when the device gets out of range of one access point and tries to...
Plz check for 3 things:
1. All of your AP should given access to roaming devices, for this all of your AP are should connected with each other.
2. WiFi chennal for your device should be same for all AP.
3. Configure 802.11b or 11Mbps speed on devices.
Plz revert in case
Thanks for contacting Fixya
Mar 23, 2009 | 3Com Wireless LAN Managed Access Point...
6,490 people viewed this question
jasbo
jasbo
