Question about Muratec Office Equipment & Supplies
The machine says to open the door and remove paper but there is no paper there. I have even turned the machine off and still the same problem.
Open the side door and close it. Remove paper trays and reinsert plus remove toner cartridge and reinsert. Good to go!!
Posted on Oct 02, 2009
I had a paper jam. Got the paper out, but now
Some printers won't reset the jam condition until you open a specific door or cover -- even if you've gotten the jam out, they think it's still there until you open that cover. Try opening and closing all of the machines doors and access points, and even pull out the paper tray and push it back in.
If the jam condition still isn't cleared, turn the machine off and back on with the main power switch.
Jul 05, 2010 | Canon PC-940 Black and White Copier
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Paper jam
The way you describe your error, it seems that there is still some residual paper stuck inside the printer that may cause subsequent paper to be mis-aligned.
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 07, 2010 | Lexmark X5150 All-In-One InkJet Printer
Paper jam
Jan 05, 2010 | Brother IntelliFAX 1820C Plain Paper...
It say paper jam and ther is no paper jam
Dec 31, 2009 | Samsung SF-335T Plain Paper Inkjet Fax
It says paper jam, but there is no jam
Dec 17, 2009 | HP 1010 Plain Paper Inkjet Fax
Machine says there is a paper jam when there is no jam. Shows jam in exit but the paper never even starts to get picked up from the main paper cassette but it will feed fine frome the mp tray. any...
Dec 08, 2009 | Samsung SCX-6320F All-In-One Laser Printer
A paper jammed during a fax. i removed it. now,
When you removed the paper jam did the paper tear? mit have left piece of the orgnial document. Also open document feeder where you place the orginal check to see fot any problem. As for the cover does it look like something on the the door is broke, The actuator on the door Slab of plastic , that goes into a slot on the machine to accurate the door close sensor, if the sensor is not activated then the copier thinks the door is open even if it closed
Aug 26, 2009 | Office Equipment & Supplies
Jammed paper...
Try removing the Toner/drum unit and see if paper is there. Also check the rear access door to see if paper is stuck in the fuser.
Sometimes you will get a jam where the paper has not even left the paper tray. Try removing the paper tray and cleaning the paper feed roller with and cloth dampened with a little water. The roller is located just above the center of the tray.
Apr 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Panasonic printer dp4520 error code j40
This indicates there is a paper in the fuser area(very Hot section be cautious).1. open the front door.2, open the left side door. look inside for a green plastic handle & lift up he metal guide plate sometimes the paper gets wrapped around the upper heat roller or curled up and around the separator claws. if so be very careful not to scratch the rollers or break the sep claws. there is a green handle/knob located in the machine that can be turned, this turns the fuser rollers and makes it a little easier to remove a fuser paper jam. After you remove the paper jam close all the doors/panels you first opened. the copier should reset itself. I have seen the pj errors change to a new one indicating another pj still exists. if so look again and remove as indicate by the Lcd screen. Please leave positive feedback if this helps
Jun 07, 2008 | Office Equipment & Supplies
64 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Ben
Ben
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
