Question about Microsoft Xbox 360 Console
Bottom-right quad is red error message e70,Help!?
Asin title
  • 121 Answers
You should call MS support to get this fixed. Especially if youret console is less than one year old. I heard they even extended the warranty for the 360 to 3 years due to the problem with "Ring of death" (That's what people call those red lights around the power button)
The lower right quad usually means hardware error. If you have a hard drive on your 360, try to remove it and play without it. If ti works then your HD is causing the problem and must be replaced.
Posted on Dec 20, 2007
AEG Lavamat 60810 keeps stopping and displaying error E50 and some time E70. What is the problem and how do I fix it?
Family error code E50 means a problem with the washing motor. Family error code E70 means a problem with the NTC sensor. In my experience, E50 is most common fault in worn carbon brushes. But in any case family error code E50 is shown to the customer. In service mode could be: E51,52,53 and 54. The same applies to family E70 error code that will be displayed in service mode as error code E71 or E74.
E50 error code could be: motor winding, power board, tachymetric generator, motor relay on power board, wiring between motor and power board and wiring between tachymetric generator and electronic.
E70 error code could be: faulty NTC sensor, wrong position of NTC sensor or to much limescale on it and finaly wiring between NTC and electronic.
May 05, 2015 | AEG Washing Machines
Aeg lavamat 63613 error code E70
Family error code E70 is shown to the customer. In service mode could be: E71 or E74
May 04, 2015 | AEG Washing Machines
Frigidaire washer LTF7000ESO error code E70
Good Morning Jazy, this is JK. I see that you are receiving an error message E70. The E70 error means that the Main Control Board is not seeing the correct water supply. I would suggest swapping the hot and cold hoses. Hope this helps!
Mar 24, 2014 | Frigidaire Washing Machines
Compatability of PC components
They should provided you get all the right drivers, disable the onboard sound, get a decent hard drive, get a case with good airflow, and make double sure that the drivers for that sound card are the correct ones and that the sound card isn't a lemon. Sound Blaster has seriously slipped in it's quality control over the last few years.
Jun 19, 2012 | Computers & Internet
Copystar cs1510 showing error e70 please help
The E70 its a troubleshooting original placement and memory errors:
1. Remove originals and replace them in the original table when the "E70" or "E71" errors display.
2. Remove originals placed on the original tray and allow the copy job from the plate to complete when the "E72" error displays.
3. Remove originals remaining in the original table when the "E90" error displays, indicating that the memory is full. Press the button with a "%" sign on it, labeled recall, to print the copies of the originals that have already been scanned. When printing completes, place the remaining originals back into the original tray and press "Start" to continue copying.
Hope helps.
Apr 18, 2011 | Copystar CS-1510 Copier
Are you sure its a E70? If so, the hot and cold lines are reversed.
Apr 25, 2010 | Frigidaire GLTF2940ES Front Load Washer
Copystar 1810 error E70
E70 Before switching on, originals were found on the
document feeder
Mar 05, 2010 | Copystar CS-1810 Copier
Stops within cycle E70 is error message
E70 Means that the Hot and Cold water lines are backwards. Switch the lines and cancel out the cycle. Turn the dial to drain and spin and pump all the water out of the unit. Then restart the cycle and it should be fine.
Feb 26, 2010 | Frigidaire ATF6000ES Front Load Washer
E 70 error
You need to make sure all of wire harness connectors are firmly making contact.This is a loose connector issue.You can fix this if you have patience.You need to start by removing the front panel and starting with the main control board,located on right side at the bottom.Remove the plug in connectors 1 by 1 crimping down the point where the contact is made.Picture this, there is most likely just ONE wire that isn't making a positive touch,and you have to find it.Easy way is after you have checked the control board and tightened the connections,re-check the machine .
May 17, 2008 | Frigidaire ATF6000ES Front Load Washer
E70 error
May 15, 2009
I had this exact same problem with my Frigidaire washer (E70) as bubbles100. I called an appliance repairman on 5/14/09 and paid him $60 to tell me my hot and cold water hoses were reversed/not properly installed.
This repairman was the cheapest priced $60 and he would work till he found the problem. I had one appliance repair company wanting to charge me $90 for 30 min and another wanting to charge $120 for 30 min. Hopefully this information can help save the next person some money by trying this first.
Feb 16, 2008 | Frigidaire Affinity ATF7000E Front Load...
Microsoft Xbox 360 Console Logo
3,896 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
