Question about Texas Instruments TI-89 Calculator
Definition what is the definition of "down scroll arrow"?
  • Texas Instru... Master
  • 7,993 Answers
The calculator has a set of navigation arrows, that allow you to move the cursor, UP, DOWN, LEFT, RIGHT. To the purists we may not be using the correct terminolgy and we may have a tendency to use inappropriate language, but in all communications there are inaccuracies that the listener or reader automatically corrects (or is expected to correct.)
Hope it clears the misunderstanding.
Posted on Oct 03, 2009
HOW TO GET FULL SCREEN ON KONKA TV
Change the aspect settings to fit your TV:
  1. Press MENU on your remote control.
  2. Use the down arrow button to highlight Settings, press OK.
  3. Use the down arrow button to highlight Television, press OK.
  4. Select Screen Aspect ratio and high definition, press OK.
  5. Use the arrow buttons to select 4:3 standard definition, widescreen standard definition, 720p on high-definition screens, or 1080i on high-definition screens.
  6. Press OK.
Apr 24, 2017 | Miscellaneous
Tip
How to reset Canon MP600 printer to the factory settings?
1. Press the HOME button.2. Use the Easy-Scroll Wheel or the right / left arrow to select [Settings], then press the button.
3. Use the Easy-Scroll Wheel or the right / left arrow to select [Device settings], then press the button.
4. Use the Easy-Scroll Wheel (B) or the up / down arrow to select [Reset settings], then press the button.
5. Use the Easy-Scroll wheel or the up / down arrow to select [Yes] on the confirmation screen and then press .
6. Press the button to return to the HOME menu.
This will help.Good Luck
on Mar 10, 2010 | Office Equipment & Supplies
No live view nikon d90 camera
Push your camera's settings button (next to top button to left of LCD) and, using the left, right, up, down arrow keys, scroll down to the "Custom Setting Menu". Scroll down to "(d)Shooting/Display". Push the right arrow key and scroll down to "( c4)Monitor Off Delay". Push the right arrow key again and you will be able to choose set the delay between 4 seconds and 10 minutes.
Mar 28, 2014 | Nikon Cameras
The LED touch Pad underneath the stand does not slide out when touching the Pad. Happened after doing TV reset ( Pressed Remote " Exit" Key for15 secs). Samsung Model: UN46C9000
With your remote, go into Menu. Then scroll down to setup and press the right arrow. Scroll down with the down arrow until you reach General and press the right arrow again. Scroll down once on Slide Key and press the right arrow. Now turn this feature on if not already. If the slide key does not slide out then consult Samsung for repair.
Mar 23, 2011 | Samsung UN46C9000 46 in LCD TV
Scroll isn't working
Like when you are on a webpage, you can't scroll? You can do it by clicking on the down arrow,or clicking on the area of the scroll thing and hit the down arrow on your keyboard.... Pleas be more specific so I can narrow down the problem....
Jan 11, 2011 | HP Compaq nx6110 PC Laptop
Reset instructions on lexmark pro705
Press SETUP.
Using up or down arrow button to scroll to DEFAULTS.
Press OK
Using up or down arrow button to scroll to SET DEFAULTS.
Press OK
Press up or down arrow button to scroll to USE FACTORY.
Press OK
Dec 06, 2010 | Lexmark Prevail Pro705 Wireless All-In-One...
How do I change IP address settings for my HP Laserjet 4650dn printer
Changing the printer's IP address
If the TCP/IP address needs to be changed, the HP Jetdirect can be reset to factory defaults so that it can receive a DHCP configuration from a server (see below). Another method is to use the printer's control panel:
1.Press the green check mark (Select) button.
2.Press the Up or Down arrow to scroll to CONFIGURE DEVICE menu and press the check mark button.
3.Press the Up or Down arrow to scroll to I/O , then press the check mark button.
4.Press the Up or Down arrow to scroll to EIO 1, 2, or 3 (depending on which EIO slot is in), then press the check mark button.
5.Press the Up or Down arrow to scroll to TCP/IP , press the check mark button.
6.Choose Config Method , then press the check mark button.
7.Choose Manual , then press the check mark button. Wait for the display to return to the Config Method screen. A Manual Settings option should now be available.
8.Press the Up or Down arrow to select Manual Settings , then press the check mark button.
9.Press the Up or Down arrow to scroll to IP address , then press the check mark button.
10.Use the Up or Down arrows to choose first byte of IP address. Press the check mark button to save the IP byte.
Repeat for the second, third, and fourth octets.
11.Continue using the Up or Down arrows and the check mark button to enter the Subnet address and the Gateway address.
Aug 18, 2010 | HP LaserJet 4650 Color Printer Manual...
Print sent fax confirmation sheet
perform the steps below:
1. Press Setup on the front panel of the All-in-One.
2. Press 5 or scroll down or use arrows to enter in to Print Report.
3. Press 4 or scroll down or use arrows to enter in to Fax Confirmation.
Now scroll down or use arrows to find print after send fax and click on.
Jan 02, 2009 | HP OfficeJet J4580 All-In-One Laser...
Olympus
Without opening the lens cover, press the quick view button then the OK button.  Scroll down to setup and press the right arrow.  Scroll down to the clock symbol and click the right arrow key.
Scroll along the date side to side and use the up and down arrows to change the date month and year.
HOPE THIS HELPS
Jul 20, 2008 | Olympus MJU 400 Digital Camera
Color calibration
You may first want to replace the magenta, but then do this.
  1. Press the Down Arrow and scroll to Troubleshooting.
  2. Press OK.
  3. Press the Down Arrow and scroll to Print Quality Problems.
  4. Press OK.
  5. Press the Down Arrow and scroll to Calibrate Colors.
  6. Press OK.
  7. Scroll to the Tutorial Page using the Down Arrow or Up Arrow key.
  8. Press OK to print this page.
Dec 07, 2007 | Xerox Phaser 6250DP Laser Printer
Texas Instruments TI-89 Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
