Question about Brand Remote Start/keyless/car Alarm Very Sleek
SPY GSM Car Alarm doesn't respond to GSM call.
I have SPY GSM Car Alarm LC609C. I can arm and disarm the system using the remote transmitter. However, the system doesn't respond to the GSM call. I tried SIM cards from O2 (Telefonica) and Vodafone providers. What may be the problem? Your help will be much appreciated.
Thank you.
Vladimir Belohlavek
vlad.vb@centrum.cz
  • vlad_vb Oct 01, 2009
    Sine the GSM signal is strong and there is no problem with the SIM card, the alarm system must be defected.
  • 691 Answers
It hard to say if your alarm is working properly beside using your transmitter which is working. 3 issue you have that you will have to try to narrow it down. 1st, I would try to contact your network provider base on GSM networks signal coverage checking does your area you live in can received the signal or how strong is the signal in your area. 2nd, does your network provider recognized the sim card or you may have to get new sim card if it defective, they may have to reset it with your network provider. 3rd, is your alarm working properly and is not defective. Have you try to activate the alarm system using it at different locations which has higher signal strength. If its still under the warranty, and you have try all the steps above, the next best thing is to send/take it back and have them bench test the unit or replace it. Being electronics, you have try and follow all steps and directions and it does not work, my only guess is the unit may have become faulty.
Posted on Oct 01, 2009
How do you turn off an alarm for a 2005 Saturn Ion
Disarming an Armed System/Silencing an Alarm
If system arming has been requested by the keyless entry transmitter, it must be disarmed.
Important: Using the power door unlock switch or manually unlocking the doors does not disable the CTD armed mode. Also, disconnecting the battery or pulling fuses does not disable the armed mode, since the BCM stores the CTD mode status in memory.
To disarm the CTD system in arm pending mode, SECURITY indicator flashing and doors open, perform 1 of the following:
Press the UNLOCK button on the keyless entry transmitter.
Insert a valid key into the ignition and start the vehicle.
To disarm the CTD system in the armed mode:
To disarm the CTD system when activated, alarming mode.
Jun 24, 2016 | 2005 Saturn ION
Replaced battery in my 1993 jeep grandcherokee limited now security system seems to cut fuel off seconds after engin fires
Here's some info as it sound like the theft deterrent is armed.
Reset Procedure
NOTE: This information applies to a Vehicle Theft Security System (VTSS) that was armed when the battery was disconnected and reconnected.
When the armed VTSS senses that the battery has been disconnected and reconnected, it enters its power-up mode. In the power-up mode the alarm system remains armed following a battery failure or disconnect. If the VTSS was armed prior to a battery disconnect or failure, the system will have to be actively or passively disarmed following a battery reconnection.
The power-up mode will also apply if the battery goes dead while the system is armed and battery jump-starting is attempted. The engine no-run feature will prevent the engine from starting until the alarm system has been actively or passively disarmed.
Passive disarming of the Vehicle Theft Security System (VTSS) occurs when the vehicle is unlocked using the key to unlock either front door or the liftgate. Active disarming of the VTSS occurs when the vehicle is unlocked by depressing the Unlock button of the Remote Keyless Entry (RKE) transmitter.
Once the alarm has been activated (horn sounding, lights flashing, and the engine no-run feature), either disarming method will deactivate the alarm.
Depressing the Panic button (if equipped) on the RKE transmitter will also disarm the VTSS, but the horn will sound and the lights will flash for about three minutes as part of the Panic feature. The horn and lights can be stopped by pressing any of the RKE transmitter's buttons or driving the vehicle above 15 mph.
Feb 11, 2013 | Dodge Stratus Cars & Trucks
Spy car alarm, remotes wont arm the alarm system after my car battery went flat?
for security reasons this is difficult to reset usually the car and remotes need to be set up again. it happens when the car loses power so if the car is stolen or imobilised the car forgets the key codes.
take the car to a dealer or Machanic shop. prove to them it is your car and they will set the remotes back up for you.
i hope this was useful
Oct 20, 2012 | Cars & Trucks
The alarm system has activated and we cannot disarm the system via the Remote Key Fob or by key at the doors or hatchback. Tried disconnecting battery same problem. When the doors open the system...
Hi Edward:
In dashboard, your THEFT warning light is blinking? If the answer is yes, your antotheft system is activated and will need restart and resynchonized. This occurs when battery is disconneting or other un-authorized key is used.
Vehicles equipped with Vehicle Theft Security System (VTSS) are protected from vehicle theft andunauthorized entry. VTSS system monitors vehicle doors, hood, liftgate and ignition. If an attempt is made toenter or operate vehicle without proper disarming of system, vehicle horn will sound, headlights, taillights andparking lights will flash, and engine will be prevented from running.
VTSS system arms when ignition is off, vehicle is exited, door is locked using power door locks and door isclosed. Alternatively a remote keyless entry transmitter can be used to arm system. A security light on panelwill flash for 15 seconds to indicate system is arming. At the end of 15 seconds, if no door, hood or tailgate isopened, system is armed.
If alarm is triggered, horn will sound for 3 minutes, and lights will flash for an additional 15 minutes. If hornsounds 3 times when either front door is unlocked, vehicle has been tampered with (tamper alert). If doors arelocked manually or with key, system will not arm (manual override). If an unauthorized entry does occur, VTSSsystem signals Powertrain Control Module (PCM) to prevent vehicle from being driven. PCM reduces injectorpulse width to zero, causing a start and stall condition.
System can be disarmed with the keyless entry transmitter, or by using key to enter vehicle. In both instances, if alarm was activated, vehicle alarm will be terminated. If battery is disconnected and reconnected, alarm will beactivated and it will be necessary to disarm system as indicated.
Please, send us some email account to send you this procedure in PDF format file.
Feb 08, 2012 | 1996 Jeep Grand Cherokee
How to take automate car alarm off silent mode
{: ) When armed, the content theft deterrent (CTD) system is designed to deter vehicle content theft by pulsing the horns and exterior lamps for approximately 30 seconds when an unauthorized vehicle entry is detected.
An unauthorized entry can be any of the following with the CTD system armed:
• When any door is opened without first being unlocked using the keyless entry transmitter • After a battery reconnect, if the battery was disconnected with the CTD system armed
If system arming has been requested by the power door lock switch or the keyless entry transmitter, it must be disarmed.
Important: Using the power door unlock switch or manually unlocking the doors does not disable the content theft deterrent (CTD) arm mode. Also, disconnecting the battery or pulling fuses does not disable the arm mode, since the BCM stores the CTD mode status in memory.
• To disarm the CTD system in standby mode, perform one of the following: - Press the UNLOCK button on the keyless entry transmitter. - Insert a valid key into the ignition and switch to the ON position. • To disarm the CTD system in the armed mode (non-event) or when activated (during an alarm event): - Press the UNLOCK button on the keyless entry transmitter. - Insert a valid key into the ignition and switch to the ON position Locking the Vehicle Without Arming the CTD System Locking the vehicle may be accomplished without arming the content theft deterrent (CTD) system. Use of the manual door locks or using the key to lock the doors will lock the vehicle, but will not arm the CTD system.
Apr 23, 2011 | 2007 Chevrolet Tahoe
Car won't start.Theft light blinks,clicking sound under hood and thumping like horn wants to go off.Seems like it's stuck in anti theft mode
anti theft light should blink every few seconds.
try disconnecting the battery for 15 minutes.
Anti-Theft-Perimeter The perimeter anti-theft system consists of the following components:
  • anti-theft indicator (THEFT)
  • remote anti-theft personality (RAP) module
  • hood switch
  • keyless entry remote transmitter
  • deck lid ajar switch
NOTE: The remote entry features will not function when the ignition switch is in the RUN or ACC position.
Up to four keyless entry remote transmitters (15K601) can be programmed at one time.
The keyless entry remote transmitters :
  • Are programmable.
  • Must be set at the same time.
  • House four buttons.
  • House three buttons (Mexico Anti-Theft System only).
Programming
Refer to Section 501-14B.
Inputs and Outputs
The remote anti-theft personality (RAP) module receives input from the following components for anti-theft operation:
  • Hood switch.
  • Deck lid ajar switch.
  • Keyless entry remote transmitter.
  • Power door lock switches (LH and RH).
  • Door courtesy input.
The RAP module distributes output to the following for the anti-theft system:
  • Power door unlock relay.
  • Power door lock relay.
  • Liftgate unlock relay (Wagon)
  • Park lamps relay.
  • HORN relay.
  • Dome lamp.
  • THEFT indicator.
  • Deck lid release.
Arming
The anti-theft system can be armed if:
  • The ignition switch is in the OFF position.
  • The panic alarm is off.
  • All doors are closed.
NOTE: If a door is open, the anti-theft system is prearmed and waiting for all the doors to be closed. The THEFT indicator will remain illuminated for up to 30 minutes waiting for all the doors to be closed. If a door remains open after 30 minutes, the THEFT indicator will turn off and the system will return to a disarmed state. After all doors are closed and the 30 second prearm (continuous THEFT indicator illumination) is complete, the system is armed.
NOTE: If the theft LED does not flash after 30 seconds, check the LED FLASH PID to see if the feature is enabled.
The anti-theft system will be armed when the lock button on the keyless entry remote transmitter is pressed, all doors are closed and 30 seconds have elapsed.
When the system is armed, the THEFT indicator will flash quickly until the system is triggered or disarmed.
Disarming
NOTE: Using a key in a door lock cylinder to unlock is not a valid method of disarming the anti-theft system.
Untriggered System
NOTE: If the driver arms the system and remains in the vehicle, an untriggered system can be disarmed by turning the ignition switch to the ON position.
An untriggered alarm system can be disarmed by pressing the unlock button on the keyless entry remote transmitter.
Triggered System
NOTE: If the hood or trunk are open when the system is armed, it must be closed and opened again before it can trigger an alarm.
An armed anti-theft system can be triggered by the following conditions:
The deck lid door, liftgate, hood or any door is opened using a key, inside door handle, hood release, etc.
  • The keyless entry remote transmitter can activate a panic alarm which is similar to the anti-theft alarm, but does not cause the THEFT indicator to flash.
A triggered alarm system can be disarmed by:
  • Pressing the unlock or panic button on the keyless entry remote transmitter.
  • Turning the ignition switch to the ON position.
Alarm State When Battery Power Is Cycled
When the RAP module is supplied power the first time at the vehicle assembly plant, the system will be in the disarmed state. The RAP module will remember whether it is armed, disarmed or triggered in its non-volatile memory. When the battery positive cable is removed and then reconnected, the system will return to the state it was in just before the battery was disconnected. If the system is in any prearm state, then the system will return to a disarmed state when the battery is disconnected and then reconnected.
Nov 06, 2010 | 1999 Mercury Tracer
Spy 5000m remote start issues
You need to adjust the tachometer sensing wire, it usually wraps around a spark plug wire so I can sense when the car starts. On my spy alarm, the wire was grey. Hope this helps.
May 05, 2010 | Brand Remote Start/keyless/car Alarm Very...
Replaced the alternator, now anti theft won't disable
The ignition lock anti-theft switch (19A438) detects if the ignition key cylinder is broken or "slam pulled" during a theft. The ignition lock anti-theft switch is always monitored by the remote anti-theft personality (RAP) module. This allows the alarm system to be triggered in the case that the ignition lock anti-theft switch detects tampering of the ignition key cylinder (even in the event that the alarm is not active at the time).
Refer to the Section 501-14B for more details on the keyless entry remote transmitter (15K601).
The door open warning lamp switch (14018) communicates to the RAP module through the generic electronic module (GEM). This input to the RAP will cause the anti-theft alarm to be sounded if the anti-theft alarm was armed.
The door disarm switches are assembled into both LH and RH lock sets. The door disarm switch must be triggered before the mechanical lock unlocks. This is to prevent the anti-theft alarm from activating when it should have been disarmed.
The RAP module controls the anti-theft system and is the brains of the keyless entry system. The RAP module communicates with the GEM to request that the interior lights be turned ON/OFF with use of the keyless entry remote transmitter, and the GEM communicates to the RAP to inform when the door is opened. Refer to Section 418-00 for inter-module communication.
The RAP module has three wire connectors attached to it:
  • The antenna for the keyless entry remote transmitter.
  • 26 circuit connector (C256).
  • 22 circuit connector (C257).
In addition to the perimeter alarm that uses the door open warning lamp switch, the RAP module also uses the ignition lock anti-theft switch and the autolock/relock feature to prevent theft of the vehicle. For a full description of the autolock/relock system, refer to Section 501-14B .
The THEFT LED is found on the instrument panel between the tachometer scale and the needle pivot point. The LED is illuminated during prearming and flashes when armed or triggered.
Prearming and Arming the System
The system can be armed if:
  • The ignition is OFF.
  • The PANIC alarm is OFF.
There are two ways to prearm the system:
  • Press the LOCK button on the transmitter.
  • Open a door, press the power door lock button and close the door.
After 30 seconds the system will be armed and the theft indicator in the cluster will flash every two seconds.
Disarming an Untriggered System
An armed system will be disarmed with one of these valid actions:
  1. Pressing the UNLOCK button on the transmitter.
  1. Placing a key in the door and turning to UNLOCK.
  1. Turning the key to RUN or ACC.
The anti-theft alarm can be triggered by the following conditions:
  • The ignition cylinder is damaged with or without the RAP being armed.
  • A door is opened without disarming the armed RAP module.
The remote transmitter can activate a panic alarm which is similar to an anti-theft alarm, but does not deactivate the starter or cause the theft indicator to flash.
Disarming a Triggered System
If the system has been triggered, (the horn honks, the lights flash, and an external starter interrupt relay is engaged), the system can be disarmed by:
  1. Pressing the UNLOCK or PANIC button on the transmitter.
  1. Putting a key in the door and unlocking the door.
  1. Turning the ignition to RUN/ACC (Turning the key to RUN/ACC will not disarm an alarm that has been triggered by the ignition lock anti-theft switch.).
Apr 10, 2009 | 1997 Ford F150 Regular Cab
VEHICLE WONT START
Section 13-11: Anti-Theft System, Active 1998 Windstar Workshop Manual DESCRIPTION AND OPERATION Anti-Theft Alarm System NOTE: The system immediately monitors the ignition key lock cylinder upon removal of the key from the ignition. It is not necessary to arm the system for ignition key lock monitoring.
The anti-theft alarm system:
  • protects the vehicle from unauthorized entry into the passenger compartment, engine compartment and cargo area.
  • monitors the status of the ignition key lock cylinder.
  • is controlled by a remote anti-theft personality (RAP) module. The remote anti-theft personality module also controls the electronic door lock functions. Refer to Section 01-14B for more details.
  • when armed, detects unauthorized entry into the passenger compartment by using an input from the GEM module regarding the state of the door or liftgate (open or closed).
  • protects the engine compartment with a hood switch which is located on the LH cowl vent panel and is part of windshield wiper motor wiring (17A477) .
  • triggers an alarm if the ignition lock cylinder is forcibly removed from the steering column.
Once triggered, the system responds by:
  • flashing the low beam headlamps, the parklamps, rear lamps and the alarm indicator warning light emitting diode (LED).
  • sounding the horn (13832).
  • disabling the starter circuit until the system is disarmed.
Remote Anti-Theft Personality Module
  • The remote anti-theft personality module is located behind the instrument panel (04320).
  • It contains a radio receiver that receives the RF signal from the keyless entry remote transmitter (15K601) through the alarm and lock system antenna (15603) and sends the appropriate command to the power door locks, the horn relay, or the generic electronic module.
  • The remote anti-theft personality module is equipped with an internal backup power supply which holds the programmed code in memory in the event the vehicle battery is disconnected.
Remote Anti-Theft Personality Module Removal
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Remove radio. Refer to Section 15-01 .
  1. Remove lower instrument panel center finish panel. Refer to Section 01-12 .
  1. Lower glove box.
  1. Remove two remote anti-theft personality module bracket retaining screws.
  1. Disconnect electrical connectors and alarm and lock system antenna (15603).
  1. Remove remote anti-theft personality module and bracket.
  1. Remove remote anti-theft personality module from mounting bracket.
Installation
  1. To install, follow removal procedure in reverse order.
  1. Tighten remote anti-theft personality module bracket retaining screws to 6-8 Nm (54-70 lb-in).
Components The system is composed of the following components:
  • remote anti-theft personality (RAP) module with integral antenna
  • alarm indicator LED
  • door lock cylinder switch RH, door lock cylinder switch LH
  • liftgate door lock cylinder switch (220A40)
  • hood switch (part of windshield wiper motor wiring (17A477))
  • ignition lock anti-theft switch (19A438)
The following vehicle components are also used by the anti-theft alarm system:
  • generic electronic module
  • power door lock switch (14028)
  • door open warning lamp switch (14018)
  • autolamp relay (14N089)
  • horn relay and bracket (13853) and horn (13832)
  • low beam headlamps
  • rear lamps (13404) and parking lamps (13200)
  • starter relay
  • door lock relays
  • keyless entry remote transmitter (15K601)
Disarming an Untriggered System NOTE: A perimeter alarm will "shut off" after 165 seconds, but the system is still triggered and is not disarmed.
An armed but untriggered perimeter anti-theft system can be disarmed by one of the following four events:
  1. Unlock the doors by pressing the keyless entry remote transmitter (15K601) UNLOCK button once.
  2. Unlock any door with a key.
  3. Turn ignition switch to RUN or ACC.
  4. The remote entry PANIC button will disarm the anti-theft system only when the perimeter alarm is triggered and sounding.
System Triggering NOTE: Although the remote entry PANIC alarm is not associated with the monitoring of the vehicle, the user will frequently say that the theft system was triggered when actually the keyless entry remote transmitter PANIC button was inadvertently pressed. A panic alarm will not flash the THEFT indicator.
The alarm can be triggered by the following events if the system has been armed and has not been disarmed first:
  • Open any door or liftgate.
  • Open the hood (16612) (if the hood was open when the system was armed, it must be closed before it can trigger the alarm).
  • Dislodge the ignition key lock cylinder.
  • The anti-theft system may be triggered inadvertently when the module is disconnected and then reconnected. To avoid inadvertent alarm triggering, disconnect the smaller 22-way connector first.
When the system is triggered the perimeter alarm will operate as follows: The remote anti-theft personality module will pulse the following outputs at approximately 1.3 Hz, 50 percent duty cycle for two minutes 45 seconds for North America. NOTE: Other perimeter alarms can be programmed for the system.
  • parking lamps
  • horn
  • THEFT indicator
The perimeter alarm can be retriggered, after a perimeter alarm has sounded for 165 seconds. After a perimeter alarm has timed out, if any trigger input is first seen as normal and is then seen in its trigger state, the perimeter alarm will be retriggered. The perimeter alarm can be triggered a total of three times between an arming sequence and a disarm event. An active panic alarm will be deactivated when a perimeter alarm is triggered (a perimeter alarm overrides a panic alarm).
Mar 02, 2009 | 1998 Ford Windstar
How can I reset my Factory Alarm on my Jeep it wont run
Alarm Module Reset Procedure
Passive disarming of the Vehicle Theft Security System (VTSS) occurs when the vehicle is unlocked using the key to unlock either front door or the lift gate. Active disarming of the VTSS occurs when the vehicle is unlocked by depressing the Unlock button of the Remote Keyless Entry (RKE) transmitter.
Jan 28, 2009 | 1999 Jeep Grand Cherokee
Brand Remote Start/keyless/car Alarm Very Sleek Logo
1,107 people viewed this question
Top Spy Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Spy Vehicle Part and Accessory Expert? Answer questions, earn points and help others
