Question about HP Photosmart 733 Digital Camera
Size and type batteries - HP Photosmart 733 Digital Camera
Type of battery for the remote of a logic3 mip 108k
Hello, James -
I see the instruction manual for the Logic3 i-Station Concert MIP 108 does not state the battery type and size for the remote control.
The manual does include the email address for the company support, however:
support@logic3.com
I suggest you send an email message asking about the battery type and size for the machine's remote control.
Best wishes.
Mar 09, 2018 | Televison & Video
Need battery for A Bulova B0409 Miniature Gas Pump clock. What size battery does this item take?
It is a question of type, rather than size. You could peek inside the battery compartment and identify the type, then go shopping for a replacement.
Dec 29, 2017 | Home
Ativa tax calculator battery--What size???
You really want to know type, not size, sooo...open the battery compartment and look. The type is identified with tiny letters/numerals.
Nov 01, 2016 | Office Equipment & Supplies
What size battery do i use for a salter lithium electronic scale 9037
Size is irrelevant. What you need to know is the type. The information may be marked on or near the battery compartment.
Jul 27, 2016 | Salter Housewares 9037 Lithium Scale
The rechargeable batteries that came with the units wouldn't stay charged more that an hour. I want to replace the rechargeable batteries. Are there any special rechargeable batteries that I should...
You will have to use the same size and type of battery made for those radios; they are all different. Open the radio, get the size and type of battery and you can do a search on the internet for them; you will find a wide range of prices with rechargeable batteries.
Mar 16, 2015 | Radio Communications
Lens size of a SVP DC- 1251
This is fixed lens camera.
Key Features Digital Zoom
8x Camera Type
Compact LCD Screen Size
2 in. Resolution
5 Megapixel Optical Zoom
Without Optical Zoom Image Quality Camera Resolution
5 Megapixel Image Sensor Type
CMOS Video Video Resolutions
640 x 480 (VGA) Lens Interchangeable Lens
Not Interchangeable Lenses Optical Zoom
Without Optical Zoom Exposure Control White Balance
Underwater (Preset) Storage Memory Type
Built-in • SD Card Built-in Memory Size
16 MB Included Features Self Timer
2 Sec. • 10 Sec. • 12 Sec. Tripod Mount
With Tripod Mount Interfaces Interface Type
USB 1.1 Power Supply Battery Type
2 x AAA Batteries Dimensions Depth
0.83 in. Height
2.3 in. Width
3.5 in. Miscellaneous UPC
859108008797 Product ID
77004823 Included Accessories
2 x AAA Batteries • USB Cable • Strap • AV Cable
Aug 04, 2012 | VuPoint Cameras
ULT31502 battery replacement
Battery replacement is simple. Getting the right battery is going to be the challenge. Original batteries, as there are two of them in my Ultra 1000va UPS. Replacement batteries need to be searched for. You must accurately measure the physical size of them for Height, Length and Width. There is not a lot of extra room, so look for ones that are higher capacity amp/hour wise but still the same physical size. Pay attention to the position of the battery terminals when looking at the specifications. Also you will need to know which type the spade terminals are and measuring their width will assist you in getting the correct type. I searched a lot of sites before finding what I needed and then shopped e-Bay for a good deal on two of them that was slightly larger capacity yet still the same physical size, terminal size the same between two available types, and they worked great. Original batteries were both split open, but the gel cell type saved me any damage as nothing leaked out. Easy to remove as there is just a mount plate that needed to be removed by removing a screw or two as I recall. Physical size is the key to an easy installation in the limited space in which they lay on their side. Pay attention to the location of the positive and negative on each of the two batteries as they were connected in series! Draw a diagram and label each of the terminals on each battery before disconnecting them. Be patient on the search and the time it takes to check the dimension of the battery for each battery you click onto and you will be OK with getting a suitable replacement!
Jul 02, 2012 | Ultra (ULT31502) UPS System
Where can I buy a cmos battery and how much does one cost?
At any walmart, grocery or drug store. They cost less than $5.00
It's only a watch type battery and the most popular is the CR2032, but take the one inside of your computer out and make sure you buy the same .
Laptops:
Most laptopsrequire you to take the laptop apart to get to the CMOS Battery. It willbe a silver battery about the of a nickel on the motherboard. Themost common is CR2032. Also sometimes the battery will be in a vinylcovering and have a cable that attaches to a port on the motherboard. Whichever type you have you'll need to either remove the battery or unplug the cableand let the laptop sit for an hour or two. Then put it back, reassemblethe laptop and reboot the laptop. With the CMOS battery out the computerwill lose the date, time and password.Desktops:Remove the Power Cord, Remove the Case, sit the computer on it's side and look inside with a flashlight. You should see the cmos battery sitting somewhere on the motherboard. It will be a shiny silver watch type battery about the of a nickel Just use a small flat head screw driver and pop it out.
Apr 25, 2012 | Computers & Internet
What size batteries do i need for 96 canter fe211
GO TO ANY AUTO PARTS PLACE TELL THEM YEAR MODEL TYPE OF CAR.WHAT ENGINE SIZE AND TYPE FUEL INJECTION SYSTEM.THEY WILL LOOK UP WHAT BATTERY SIZE YOU NEED.
May 15, 2010 | 1996 Mitsubishi Eclipse
I have a la scala tonneau women watch, the watch type is 0310702, i need to change a battery, but so many type and size of battery, which type and size watch battery is the right one?
The battery has its identification number on it, so if you remove the back of the watch you should be able to read the type without stopping the watch.
Or you could take it to a watch shop, who will have a stock of batteries. Removing and replacing the back of a watch sometimes takes some practice and I advise you to give the job to an expert, especially if it is a water resistant type.
Jan 13, 2010 | Concord Industries Concord, La Scala...
HP Photosmart 733 Digital Camera Logo
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
