Question about Canon FAXPHONE B640 Plain Paper Bubblejet
Black lines when i fax or copy
I have tried to clean my Canon FaxPhone b640 several times. since i do not use the machine very much i assume that everyday dust has settled into the machine.
I have been looking for a manual that would describe dissembling the machine so i can properly clean and reinstall a "O" ring that is damaged.
Is there anyplace on the "net" i can find such a manual ?
    Problem Solver:
  • 16 Answers
Sounds like a problem I had. When I sent or received faxes I would see vertical lines running down the entire length of the sheet. I cleaned and the problem persisted. I researched the problem and found that since I had removed and replaced the cartridge I needed to perform a "shading adjustment". This is a software alignment fix. You merely push a set of buttons on the front panel and the unit performs this alignment. I've lost my notes on this procedure, but I will continue looking for them. I hope this helps a little.
Posted on Nov 15, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 13 Answers
If you have lines only when you send or copy, i would check the scanner under the kboard for liquid paper or other stuff on the glass
Posted on Dec 21, 2007
When i send a fax my client gets a black copy
Your SCANNER UNIT has failed, very expensive to fix.
Apr 02, 2010 | Canon FAXPHONE B640 Plain Paper Bubblejet
your fax cartridge is BJC Bx/BC03/03
Jun 28, 2009 | Canon FAXPHONE B640 Plain Paper Bubblejet
I need the drivers to install my printer
Hi, You might want to read the bulletin below before using that machine.
Hope that helps.
Lbcoaster
An electrical component used in certain FAX PHONE B640 units manufactured between September 30, 1999, and January 26, 2000, may present a risk of fire.
This potential risk, and Canon's commitment to customer satisfaction and safety, have led us to implement a special Instant Exchange Program to replace, at no cost to customers, all FAX PHONE B640s bearing the following serial numbers:
  • UKK52923 to UKK55442
  • UKK60513 to UKK99999
  • YKK02001 to YKK20000
The serial number on your FAX PHONE B640 is printed on a silver sticker located on the back of your product, as shown below:
b640_serial.gif If your FAXPHONE B640 contains one of the above-listed serial numbers, simply call our special Instant Exchange Program toll-free number, (888) 280-7858, between 8:00 a.m. - midnight, Eastern Time, Monday through Friday, or between noon - 8:00 p.m., Eastern Time, on Saturday.* We will arrange to ship you a new FAXPHONE B640 or comparable model, complete with a one-year warranty, at no charge. We also will provide you with a toll-free telephone number to call to arrange pickup of your used FAXPHONE B640. There will be no charge to you for this pickup. Please DO NOT return your FAXPHONE B640 to the retailer from whom you purchased it.
If you have any questions concerning your FAXPHONE B640 or the special Instant Exchange Program, please call Canon at 888-280-7858 or email Canon at B640@va.cits.canon.com.
*If you cannot use the toll-free number because you live outside the United States, you may call (757) 413-2848, and receive additional directions for the replacement of your FAXPHONE B640.
Jun 02, 2009 | Canon FAXPHONE B640 Plain Paper Bubblejet
Scanner feed hangup
NEEDS A SEPARATION PAD AND A BUSHING.IT IS NOT A EASY FIX
Feb 11, 2009 | Canon FAXPHONE B640 Plain Paper Bubblejet
Canon B640 printing problem
The scanner lamp is not working. When making a copy, the lamp lights the source document, so if there is no light, the source document 'looks' black. Your machine will need to be serviced.
Jan 26, 2009 | Canon FAXPHONE B640 Plain Paper Bubblejet
Canon b640 problem
By cleaning the feed rollers you the fax will feed beter.Remove the dockfeeder and the paper tray.you will find the feed rollers in the bottom of the paper tray.Take a cloth and a stong soap selution and clean the 2 feed rubbers.
Jan 06, 2009 | Canon FAXPHONE B640 Plain Paper Bubblejet
Black marks only when faxing
check the Scan glass where you put the original to fax, there should be a door to open and see a small strip of glass, clean it.
Nov 17, 2008 | Canon FAXPHONE B640 Plain Paper Bubblejet
Drum? glass? on faxphone?
try this take out drum( toner) clean machine see if there is a thin strip of glass on bottom inside the machine. make sure it is clean, this will give you black lines if dirty.
here is the manualit can guide you better, look for the troubleshooting and maintenance section
http://www.retrevo.com/s/canon+b640++manual?rt=tr&p=http%3A%2F%2Fwww.usa.canon.com%2Fcpr%2Fpdf%2FManuals%2Fb640_ug.pdf
good luck
Dec 07, 2007 | Canon FAXPHONE B640 Plain Paper Bubblejet
Copies here and recipients faxes: dark, lined
How long has the drum been in there?
try this:
1-take out toner, look and see if it is ok. do you see stripes on it?
2- look at the drum are there any black rings on it? ( you did not specify white or black lines)
3- where the glass is on the opposite side ( the part you lifted to clean the glass, look at it standing from the back. you will see a white metal plate with some springs in it if you touch it. this is the reference that the fax has if there is/are a black dot on it it will give you a black line clean carefully. if it is scratched use white out to cover and make white again.
For the darkness try making a copy in photo mode if it is still too dark change drum.
Sent faxes and copies come out all black
The lamp in your scanner unit has gone out. Given the age of your unit it is not economically feasible to repair Sorry Ed
May 07, 2007 | Canon FAXPHONE B640 Plain Paper Bubblejet
Canon FAXPHONE B640 Plain Paper Bubblejet Logo
108 people viewed this question
old marine
old marine
