Question about OpSwiss 8-32x50B Riflescope
Im looking to purchase the opswiss 8 x 32x50. Are
Im looking to purchase the opswiss 8 x 32x50. Are the crosshairs all blue illuminated? Amazon has it for 113.96 but doesnt specify illumination color and ebay has blue illuminated for 150.00. Is there only one type from opswiss 8x32x50 and amazon failed to indicate the color or are there different types from OPSWISS.
ty
Yes the crosshairs are blue illuminated.
Posted on Apr 12, 2010
What are the marks below the crosshairs
They are used to indicate elevation needed to hit your target at various ranges. The distances should be indicated in your owner's manual. For instance, if calibrated for .223 remington, and sighted in at 100 yards, the first might be 200 yards, the 2nd 300 yards, etc.
Dec 01, 2013 | NcStar 3-12x50e Rifle Scope Illuminated...
Convergence crosshair
For more details about the convergence for projection TVs, check this link. Surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and five hundred posts. All are related to television and other domestic electronic equipment service help. More than Ten Lakh viewers cannot be wrong.
May 21, 2013 | Zenith Televison & Video
How to repalce the crosshairs
I would send it to them to be checked.
Bushnell
Attn repair
9200 cody
overland park KS 66214
make sure to put your name, address, telephone number, and a detailed description of the issue in the package.
Jan 23, 2013 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
Crosshair dont move
Bushnell
Attn repair
9200 cody
Aug 09, 2012 | Bushnell Banner Rifle Scope 3-9X 50...
Speaker wiring
Here' s the colors to look for in the dash:
1994 Ford Probe Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/White
Car Radio Ground Wire: Black/Pink
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Light Green/Yellow
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): Blue/Black
Right Front Speaker Negative Wire (-): Blue/Orange
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Green/Orange
Right Rear Speaker Positive Wire (+): Green/Yellow
Right Rear Speaker Negative Wire (-): Green/Blue
Jun 03, 2009 | 1994 Ford Probe
Green convergance wont adjust, bowed screen
Green really shouldn't be adjusted, you adjust red and blue to the green. When a color is bowed that indicates that a part or two are bad, probably the convergence output IC's and possibly a fuse or fusible resister. You may need a tech to come adjust it for you because after replacing IC's the adjustments should be done in the servicers menus not just in the consumers menus.
Mar 13, 2009 | RCA P52937 52" Rear Projection Television
The BLUE crosshair will not focus,
go here
this is for sony but your should be close enough. you want to manually focus the blue gun.
please mark post fixya!
Feb 11, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Blue Convergence
Blue convergence IC is bad, but change both as red wont be far behind they are cheap about 10.00 ea at the following link.
http://electronix.com/
Jan 14, 2008 | Toshiba TN55X81 55" Rear Projection...
Fine tuning grid on my Samsung HDTV with remote.(BP59-00048)
To adjust manual convergence on your projection TV, follow theses steps:
  1. Turn your TV on.
  2. Let it warm up for 30 minutes.
  3. Press the Menu button on your remote. The Main menu appears.
  4. Use your remote to select Function, and then press the joystick.
  5. Select Convergence, and then press the joystick. The Manual Convergence screen appears.
  6. Select Red, and then press the joystick. A series of crosshairs appears on the screen.
  7. Select one of the outside crosshairs by moving the joystick up/down/right/left or by pressing the 2 (up), 4 (left), 6 (right), or 8 (down) buttons on your remote. The method you use depends on the model of remote you have. Note: You must do the outside crosshairs first.
  1. In the crosshair you selected, if you can see a horizontal red line, use the CH up or CH down buttons to move the line so that it is superimposed on the horizontal center line of the crosshair. Note: Make the single horizontal line as white as possible.
  1. In the crosshair you selected, if you can see a vertical red line, use the Vol + or Vol - buttons to move the line so that it is superimposed on the vertical center line of the crosshair. Note: Make the single vertical line as white as possible.
  1. Repeat for all outside crosshairs, and then for the inside crosshair.
  2. Return to the Manual Convergence Screen, and select Blue, and then press the joystick.
  3. Repeat Steps 7 through 10 for Blue.
  4. Press the Menu button on your remote to exit.
Important: The directions above work for most Samsung Rear Projection TVs. Yours may be different. For exact directions to perform manual convergence, see your user's manual. If you don't have your user's manual on hand, click HERE to view your manual on line.
If you cannot get your Projection TV to converge, it may need to be serviced. To arrange a service appointment, call Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your TV's model number and serial number on hand when you call.
Jan 05, 2008 | Samsung BP59-00016A Remote Control
OpSwiss 8-32x50B Riflescope Logo
305 people viewed this question
Top OpSwiss Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an OpSwiss Optic Expert? Answer questions, earn points and help others
