Question about Garden
Need help replacing fuel lines MS1838AV - Garden
  • dontbother10
    dontbother10 May 11, 2010
    We want very much to help you! Help us! Who made your saw? The model number from the makers tag not what is on the operator's manual. With some manufacturer's the serial number must be used to find the correct exploded parts list (the only known fuel line routing detail). A couple more thing that help. Is your saw American? Its approxamate age. Generic fuel line routing: Tank to carberator. Carberator to purge pump (if equipped) Purge pump to tank (if equipped).
  • obwhon May 11, 2010
    I don't understand what kind of help you need. Take the old one out and put in a new one. Follow the same path as the old one.
2 Suggested Answers
  • 4088 Answers
SOURCE: where are the gas lines located ,model ms1838av
On Macs, remove the rear engine case. This exposes both tanks, and the attendant lines. Hope this helps!
Posted on May 05, 2010
I have a mcculloch ms1838av. Looking for the primer ball
Primer bulb? I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Mar 27, 2017 | McCulloch Garden
I need the fuel line routing for an 07 chevy avalanche with 5.3L engine. Which line on the fuel pump is the pressure line? where does it go from pump?
Bruce, look for the fuel line running along frame rail with the gas filter attached, this will be the high pressure fuel line that feeds the engines fuel rail/injectors. searched the net and could not find a lot on the fuel lines for Avalanche. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CK159 259 359 for Chevrolet Avalanche
Pt 1 2007 Chevy Pickup Fuel Pump Replacement At Ray Shop
Pt 2 2007 Chevy Pickup Fuel Pump Replacement At Ray Shop
Aug 19, 2016 | Fuel Pump With Sending Unit Chevy...
Location for fuel line on a 2006 ford explorer xlt 4.0 shoc
Geronimo, Normally the fuel lines run from gas tank, along frame rail, then up to fuel rail into injectors.
2006 ford explorer xlt fuel line routing Google Search
Ford Fuel Filter Replacement Change How to Do it yourself
Fuel Filter Replacement 2006 Explorer
Fuel pump replacement Ford Explorer 2005 2010 Install Remove Replace...
Mar 04, 2016 | 2006 Ford Explorer XLT
Whats is the fuel ratio for a McCulloch MS1838AV chain saw?
(25:1)
25 parts fuel to 1 part quality 2-stroke oil.
Hope that helps!
Oct 03, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have a 16" McCulloch MAC 3516 chainsaw, and I need to replace the spark plug. Ideally, I need a complete instruction manual, but for now I just need to know what size spark plug to get, and what gap it...
This will be a good place for you to look:
http://carburetor-manual.com/mcculloch-chain-parts-manual-ms1635av-ms1838av-p-1078.html
Copy and paste the URL into your browser and check out the downloadable instructions for the saw.
Paul
Sep 18, 2010 | Garden
Need a manual for a McCullock chainsaw. Model Mac 3214
I could not find that particular model number, but if you go to this URL you might have some success:
Paul
Looking for parts list for ms1838av /140295 need pull starting assembly.
Check with your nearest servicing saw dealer who can order the parts needed and help with the restringing of the cord if needed. Good luck!
Jun 21, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Where are the gas lines located ,model ms1838av
Apr 28, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
I need a mamual for McCuloch chain saw CS 38EM
A more common model number is MS1838AV. Your IPL follows:
Chainsaws 32cc-35cc-38cc Anti-Vibe
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered (I did not get any hits).
http://www.arboristsite.com/showthread.php?t=72322 HTH
Lou
Feb 17, 2010 | McCulloch Garden
My McCulloch MS1838AV 38cc chainsaw has a broken crankshaft. I found a crankshaft for the similar model MS1432 32cc.Are the crankshafts the same?
only way is to "mike" out the bearing areas and connecting rod journal. compare the original to the replacement. close is not good enough exact is what you want.
Oct 24, 2009 | McCulloch Garden
Garden Logo
79 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
