Question about Garden
Blower stopped working half way. Tried to start it again, not starting.
2 Suggested Answers
SOURCE: craftsman 32cc blower stalls
Your carb is leaning out, causing the thing to die. Try adjusting the mixture screw (out) to richen the mixture. If there is a cap, you can pull it off to go richer. If that doesn't work, either the filter/pickup is plugged, the fuel line is kinked/smashed, or the carb needs to come apart to be cleaned.
Posted on Jun 12, 2009
I have a 2004 grand cherokee jeep limited edition the back window was broken into, and maybe they tried to do somehting to shut down the alarm system, (we dont know)..battery had to be...
Continued blowing of fuses will normally indicate one of two things first is that a component/device is faulty ando second is that there is a short or intermittent short in the circuit(s) while I am not familiar with jeeps I find it unlikely however that both the blinkers and ac fan have the same circuit/fuse but it is possible they are shorting each other somewhere in or under the main console
Apr 27, 2017 | 2004 Jeep Grand Cherokee
Diagnosing an electrical issue is never easy or cheap, sorry. When fuses blow, it is due to an improper flow of electrons. When relays go bad, it is due to overheating(which is often due to an improper flow of electrons). The BCM(Body Control Module) could be to blame... let us know how it works out =D
Feb 01, 2014 | 2004 Jeep Grand Cherokee
1995 Pontiac Grand AM SE. Heater fan works for weeks then won't go, try a couple hours later then it goes.
It sounds like the brushes on armature for (blower motor ) are worn. Sometime a bad spot on the armature from not being used often and also by being in the engine compartment where it is exposed to condensation. When the brushes stop at that particular spot, the blower will not start spin process unless it draws alot of current that may be why the fuse blew. You can remove the blower and examine or just make the change.
Jan 28, 2013 | 1995 Pontiac Grand Am
Ignition / Electrical Problem? 1998 Volvo S90 Sedan
you may have lost the security code,bad switch,short in fuse box,bcm,imm module. you need a service manual and volvo scan tool to really diag.
Jul 15, 2012 | Volvo S90 Cars & Trucks
2-cycle blower starts up but wont run full power rpm
Have you tried choking it about half way and see if that helps? Does it do the same after it is warmed up?
Mar 11, 2010 | Homelite Consumer Products Backpack...
Chevy Blazer 2000- blower not working
this is what is wrong, its called the heater blower motor resister its what regulates blower speeds and also makes blower run. $20.00 at autozone. now sometimes the plug, and wires, going to it will burn if this is the case that plug will have to be chg.too you can get that at autozone also, but i don't know how much it is, i can't imagen its anymore than the resister. i don't know what labor rates are around your area. but it should not take any longer than1 to 2 hours maybe less, and maybe a half hour, if they have to chg. the plug. believe me its the resister i have changed a lot of them, very common problem. hope this help you out. OLD SCHOOL.
Jan 23, 2009 | 2000 Jeep Cherokee
Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Nov 12, 2008 | Kenmore 22422 Top Load Washer
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
