Question about Dishwashers
Hi, how do i install my dishwasher....i dont know where to connect the water supply pipe to as i dont seem to have a tap under the sink for it to be connected to, can anyone help please.
    President:
  • 1,489 Answers
You'll have to tap into the hot water supply for the sink to get a connection for the dishwasher. This is a moderatley difficult plumbing task. If you don't have plumbing experience, it's probably best to call a plumber.
If you want to do this yourself, let me know and I'll try to help.
Charlie
Posted on Oct 01, 2009
Want to remove present dishwasher for replacement with a new one. How do you do it.
Most dishwashers are housed in a cabinet next to your kitchen sink.
Not knowing how exactly your machine is set up I will just advise you on common setup features and removal.
First open the doors to kitchen cabinet under the sink. If you see two hoses connected under the sink, they most likely are from your dishwasher. One is an inlet hose which would be connected to a water tap. The other would be a drain hose which would be connected via a clamp to the drain under your sink.
Turn off water tap to remove inlet hose. Unscrew or undo the clamp fixing your drain hose to drain pipe. Note when you remove the drain hose the hole to the drain pipe is exposed. You need to block this off as it will leak water when ever the sink is running. I normally get a plastic bag and twist it inside the hole and tape it off.
Next you need to locate the power cord and plug for the dishwasher. This is normally under the sink cabinet as well. However, check either side of the dishwasher. Sometimes they are behind the dishwasher.
Once you have disconnected the hoses, open dishwasher door. Look on the inside walls of the dishwasher. Some models are screwed into the wall of the cabinet so you need to unscrew machine. The screws go in either from the side walls or from the inside roof of dishwaser to your benchtop.
You need to also remove the kitchen kickboard if one has been installed infront of the dishwasher.
When machine is free open the diswasher door and grab either side of door and gently pull machine out. Have someone help you feed the hoses through as you pull out.
If the machine does not easily pull out check again for hidden anchor screws around the edges of the machine or even clamps which fix the hoses to the cabinet.
If you have issues pulling it out see if you can take some pictures and I will help you.
ash
Sep 11, 2011 | Dishwashers
Don't understand the incomprehensible door and general installation instructions for the aqua star. Just uses pictures, anywhere available that uses WORDS?
  • 1 what you'll need
    Electric drill and hole cutting bit
    Screwdrivers
    Pliers
    Adjustable wrench
    Level
    Teflon pipe tape
    Drain pipe for dishwasher
    Dishwasher connection kit - available at your home store (should contain water supply line for dishwasher as well as necessary connectors and compression couplers).
    New dishwasher
  • 2Determine that you have access to the hot water supply line, the drainpipe and an electrical connection under the sink. Installing the dishwasher will require extending the hot water supply line to the dishwasher, connecting the dishwasher drain to the drainpipe under the sink, and plugging the dishwasher in. If your home was not plumbed in anticipation of a dishwasher, you will need to change some fittings under the sink to make these connections possible. (See below)
  • 3Read the instruction manual that comes with your new dishwasher. Installing a dishwasher is straightforward but you want to be sure you understand and are comfortable with the necessary steps.
  • 4
  • Thanks for using fixya.
  • Jul 19, 2011 | Bosch Dishwashers
    It says the faucet is closed, how do i open it? no water is coming out and everything is plugged in correctly.
    Under the sink or pantry counter, follow the hot water pipe or hose that supplies the unit, to the hot water pipe that supplies the sink's taps, you should find a valve, make sure it is opened.
    Jacques.
    Sep 04, 2010 | Whirlpool Dishwashers
    Miele dishwasher doesn't work.error F70
    When this problem happened to our machine, it was simply the pipes under the sink where the dishwasher drain pipe fits were blocked with muck. This was preventing the one way valve connecting the drain hose to the household waste from fully opening thus preventing the machine complete its drain cycle.
    Solution was to thoroughly clean the sink drain pipes - plunger, power plunger and then a dose of chemical cleaner. Dishwasher is as right as rain now:)
    Mar 29, 2010 | Dishwashers
    I have a dishwasher whirlpool DU945PWSQO I like to know if i have to used hot & cool water install to the dishwasher. Or i have to used hot water only
    You only need to hook your dishwasher up to the hot water only. You can run a separate pipe from any hot water pipe, but in most kitchens the dishwasher is next to the kitchen sink, so the hot water is just teed off of the piping under the sink...
    Heatman101
    Feb 22, 2010 | Dishwashers
    Connect water line and drain line
    The supply line connects to the brass screw in fitting on the bottom left corner under the washer.
    When you buy a dishwasher supply line kit, it will come with any adaptors needed. Unless you are using the steel braided line you will need to use teflon tape on the threads of the line. If you are using the SS line kit, you will only need tape on the adaptor.
    Here is a pick of the line and the adaptor.
    The drain line is attached with a typical hose clamp like this.
    It is attached to the stub out on the garbage disposal if a GD is installed. If not then it is attached to the stub out on the drain pipe for the sink, like this.
    Here is a pic of a drain line installed on a Garbage Disposal.
    Oct 03, 2009 | Dishwashers
    Removing a built in Asea Skandia cylinda 1200
    Its normal to have the water supply from under sink to dishwasher 3/8 soft copper. If there is a water stop under sink for dishwasher go ahead and shut it off. If not you will have to shut water off at main. Now you can unscrew supply at dishwasher, it's close to the front on left side. Its a 3/8 compression nut, you can use a small cresent wrench.
    Sep 30, 2009 | Dishwashers
    My dishwasher doesn't seem to be getting water in hence dishes not being washed. motor is on. checkedunder sink . what does 'valve on' mean exactly? i don't see an on off valve. please help!
    Follow the hot water fill pipe from where it connects to the dishwasher back to where it connects to the wall. (probably under the sink) Most of the time, you will find that pipe attaches to the same hot water (on/off) valve as the hot water side of the kitchen sink.
    Confirm that valve is open (righty - tighty, lefty - loosy (open)) If the valve is open at the wall end then:
    The next most common cause of no water entering the dishwasher is the solenoid valve on the dishwasher that is electronically opened when the dishwasher needs water to enter for wash or rinse. This valve is located just pass the connection where the fill pipe connects to the dishwasher and will have two wires connected to it.
    Please post back here what you find or have more questions, OK?
    Aug 10, 2009 | Dishwashers
    I have a newly installed Kitchenaide dishwasher. The copper pipe is secure under the sink and appears connected properly to the dishwasher. When I turn the shut off valve on, water begans to run from...
    You should be able to remove the panel below the door and see where water inlet hose is connected to the solenoid valve. I'd bet that's where it's leaking since you say it's newly installed.
    May 13, 2008 | Dishwashers
    How to install diswasher
    To get the water to the dishwasher, it depends on your plumbing setup. If you have shutoffs under your sink(1/2" X 3/8" compression angle stop), you will need to buy a 1/2" x 3/8" compression double stop. This will be easy to change.
    #1 Drill a 1 1/2" hole in the back bottom of the cabinet to run your water, drain line, and power cord through.
    #2 First turn off the water at the Hot Water Tank, or the House supply, and turn on the sink to relieve the pressure.
    #3 Next remove the Hot supply stop, and install the double stop.( The nut and ferrul do not have to be removed, as they will attach to the double stop. Reinstall the hot supply to the sink to one of the connections on the double stop.
    #4 Install a 3/8" x 3/8" x 48" braided flex with the 1/2" MIP
    x 3/8" compression ell at the dishwasher.
    #5 Install the drain hose supplied with your dishwasher at the bottom of the dishwasher.
    #6 Install a 6' pigtail power cord to the power box under your dishwasher.
    #7 Feed the drain line, power cord and water supply through the hole in the back of the cabinet at the bottom. As you push the dishwasher back into the enclosure, you will need to feed the 3 lines into the cabinet under the sink.
    #8 Attach the water line to the open connection on the double stop.
    #9 The drain line will attach to your garbage disposal.(If you have one) Be sure to knock the small piece of plastic out of the drain connection, and retrieve it out of the disposal, before connecting the dishwasher drain line.
    #11 Raise the middle of the drain line as high as possible under the cabinet under the sink, preferably attach it to a screw to the bottom of the counter top. This will keep the dishwasher from drawing a back siphonage and getting a bad odor.
    #12 Plug in the dishwasher. Assuming you have electrical under your sink. Otherwise an electrical outlet may need to be installed.
    #13 Balance the dishwasher using the front legs. After you adjust the depth of the dishwasher, and the level. Use the 2 mounting screws included with the dishwasher to fasten the 2 clips above the door to the bottom of the counter top.
    #14 Remove the installation manual and styrofoam from the tray, and turn the dishwasher on. Inspect for leaks as you run a cycle.
    #15 Attach the bottom kick panels
    You are done.
    If you have any questions, please let me know.
    Jan 20, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
    Dishwashers Logo
    122 people viewed this question
    Top Dishwashers Experts
