Hi, I have dishnet satellite upset in 3 rooms,but as of now,because of financial problems I have been cutoff from all basic channels like cbs,nbc, abc,and upn,cw. can I use my vcrs to veiw and record shows?
  • cookie_1955 Oct 01, 2009
    Hi again,
    I appreciate your e-mail,but I am still not sure what to do. I am sorry but not real intune with electronics very well, First,which remote, the dishnetwork remote will only allow to display the channels, that are not the ones I want to watch or record. Do I need to unplug the dishnet,and start from the basic hookup? I know this is a problem.
    Thanks,for your help,but right now I just can not afford the cable or a converter box.
    Thanks,
    cookie.1955
  • cookie_1955 Oct 02, 2009
    Thank you for your help. I was not sure if I
    would be able to watch any basic channels.
    Sincerely,
    cookie_1955
  • 19,396 Answers
You do not need to connect anything more than a digital receiver. Connect a digital receiver to view and record all programs on the air.
If you use the VCR it wont work, as the VCR (and many DVD players) have only analog receiver. You will need to connect an aerial to the VCR to receive few analog channels , instead of getting all the basic channels that you had on satellite for free on a digital terrestrial receiver.
Posted on Oct 01, 2009
  • 3,230 Answers
Well YES you can record the programs to your VCR/DVR..... note. only few VCR provide the facility to record TV shows, so check them first......
Follow the below steps to record TV shows -
1. Press the "Guide" button on the remote control then find the program you wish to record on the DVR system. When you finally found the show, you can either press "Select" or the "Record" button.
2. You will see a another screen where it says "Create Timer." On the right side, press "Create Timer"-- it will take only a few seconds for the DVR to locate the program on the guide.
3. The "Create Timer" page will automatically close and you will see a small green or blue button indicating that the show is either recording at the moment or set to record at a specific time.
4. If you want confirmation that your program is set to record, press the "DVR" button three times. You will see the "My Daily Schedule" screen, so scroll down and find the program of your choice.
Good Luck!!
Thanks
I am plugging in a cable from the dishnet satellite in to the antenna port in back and i can't get it to work. But my other tv's work fine doing the same thing
you usually cant go directly from the dishnet sat antenna to the tv without convert (dish box) i would try put it in the cable port and run from the menu options channel scan. do tht as well with the antenna port.
Mar 22, 2011 | Vizio VW37L 37 in. LCD HDTV
Appears to be recording but is not. The player
Hi
Does your dishnet box have two tuners or one, if only one then only the program being watch on the tv can be recordered , this will have to be connected to the av input on the recorder and one of the av (line input) selected with the remote control for the recorder, If the dishnet box as two tuners then the output from one tuner can be used to feed the tv and the other one will go to the recorder connected through the av input. hope this will help regards windyhouse
May 11, 2010 | Toshiba DR410 DVD Recorder
Philips flat tv. Can't get it to hook up to dish network. The room where the tv is there isn't a dish box. We have to watch what is on in the other room. It only has one coax cable to hook up. Don't know...
I should be channel 3 or 4. This assumes that this coax cable is coming out as a TV R.F. connection of a Dish Network Box (Satellite Receiver) intended for direct connection to an old fashioned NTSC (channels 2-13, 14-83, possibly even has cable channels depending on how old?) TV.
If this coax is the output of a coax going directly to the Satellite Dish or through what might might look to you like some kind of fancy splitter (called a Multi-Switch) the you WOULD NOT want to hook that to your old NTSC tv. The frequency is too high ... etc. etc... you would need Dish Box (as you call it) a.k.a. a Satellite receiver - with a good and active satellite card from your provider.
Jul 07, 2009 | Televison & Video
Programming my DishNet remote for my Sony AV System
Hi, the manual for the vip622 (the model I have... not sure what you have) says to use the following codes for Sony Tuners / Amplifiers.
639 645 650 687 728 729 730
(located in the Appendix)
See Chapter 10 here:
http://www.dishnetwork.com/support/documents/receivers/vip622/default.aspx
for instructions on how to program the AUX setting on your remote and how to set your remote to adjust the receiver volume while controlling the Dish receiver.
Mar 28, 2009 | Sony STR-DE597 Receiver
Switching from Comcast to Dish Net and back again
Press the unput button and select the location.
Feb 25, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Have dish net work
That pixelation is caused by weak transponders or bad weather.
Wait for a nice clear day and see if you continue to have the problem.
If you do, you need to call your service provider. (assuming this is a legit Dishnet Satellite)
Feb 13, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
My pansat3500 does not work on directv
Hi there you can go to this link http://www.pansat3500sd.com/ then contact them it is the official website of pansat3500sd..
Please rate thanks God bless
Nov 10, 2008 | Panasonic DMR-ES10 DVD Recorder
Toshiba 36a41 television
You should be able to use your remote control to do this.Your channel 73 is more than likely UHF 73 so you need to put your tv in the antenna setting rather than cable setting. Once you do this just input 73 with your remote. Hope this helps! Stargazer
Jan 21, 2007 | Sony KV-36XBR250 TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
