Question about Keyboards & Mice
Medion wireless mouse and keyboard connection.
I have recently changed my pc and now have only USB2 connection. I have tried a splitter connector to my PS/2 connector but can only get either mouse or keyboard and not both to connect. Any suggestions?
5 Suggested Answers
SOURCE: Belkin Wireless Mouse
Today I tried pressing the reset button on the bottom of the mouse, and at the same time pressed the button on the top of the remote reciever. I'd pressed both in the past, but never at the same time. This seems to have fixed this problem. I hope it's a solution for others also.
Posted on Dec 24, 2007
  • 51 Answers
SOURCE: re: wireless mouse doesn't work
Sounds like a bad ps2 port. Maybe your motherboard is going bad. I'd say its time to upgrade your computer.
Posted on Aug 18, 2007
SOURCE: wireless keyboard numbers on right not working and wireless mouse light not on
My Dell wireless keyboard doesn't work. I replaced the batteries in it and pressed the green button on the back of it then the button on the wireless thing plugged into the computer. That light blinks for a few seconds then stops but the keyboard still doesn't work. My wireless mouse works fine.
Posted on Oct 29, 2008
  • 1102 Answers
SOURCE: Logitech Wireless CE 0682 Keyboard won't work but mouse does
did this come with software
and you might need to do a uninstall reinstall
if it worked on same pc before it should work now.
if you have a reset button on transmitter try resetting it.
Posted on Jan 20, 2009
SOURCE: Wireless Keyboard not working
sensor are on but keyboard is not working
Posted on Oct 03, 2010
0 characters
1 Points
I just recently purchased the wireless keyboard and mouse. Thought I was following the instructions for installing them. The computer says they are installed properly, yet the keyboard won't work. Can't...
usually these have a tiny "Connect" Button on the bottom of the keyboard, mouse, and a button on the receiver. Have you followed the sync procedure with this ?
Is there another wireless device nearby that may be interfering ?
Is it one receiver for both devices ?
Does the mouse work ?
Have you tried a 2nd set of batteries on your keyboard ??
Hope this helps.
Jul 28, 2009 | Logitech 967437-0403 Keyboard
Volume up and down keys wont work
It sounds like one or more of the files may have been corrupted somehow. Updating the drivers should have fixed it but if they don't replace the file that is corrupted, you get your problem.
Go into control panel and first check under add/remove software and uninstall the keyboard control software. That will clean out any corrupted files. Then reinstall the drivers and set it up your keys again.
Jul 24, 2009 | Acer Keyboards & Mice
Everything ok with this keyboard except one thing. I can't manage the volume with the keyboard.
Are you trying the volume control at the media controls? See here.
Also check to see that your Operating system volume control is on and up.
good luck.
Jul 10, 2009 | Microsoft Wireless Desktop 3000 Keyboard
Sony VGP-WKB5 VAIO Wireless Keyboard unable to connect
Disconnect all devices from your PC including usb mouse and power adaptor.
Press power button and hold it for 20 seconds.
This will statically discharge teh PC. THen take out batteries from the keyboard and pres connect button to discharge keyboard.
When this is done connect pc to the mains and turn it on
Put batteries into keyboard and try to connect.
Press connect button on the pc first and then within few seconds press connect button on the keyboard.
Please leave your feedback if issue is solved or you need futher assistance
May 28, 2009 | Sony VAIO VGP-WKB1 Keyboard
Wireless Multimedia keyboard volume keys won't work.
Go to start and run then type services.msc or if using windows 7 just go to start and type services.msc in the search box. Once open find the service "Human Interface Device Access". Change it from manual to automatic and make sure that it is started.
Apr 04, 2009 | Microsoft Wireless Optical Desktop 1000...
Wireless Mouse a Problem
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
Dec 25, 2008 | Dell Wireless Keyboard Optical Mouse w0147
There's also a connect button on the USB connector. Plug the connector in and press the connect button underneath until the light flashes. Release the button and click the connect button on the mouse until the USB light is steady.
May 16, 2008 | Targus PAKP003U Keyboard
Microsoft Wireless Optical Comfort Desktop and Mouse combo Freezing Prob.'s
have you tried pressing the connect button on the reciever then on the mouse so it picks it back up again?
May 01, 2008 | Microsoft Multimedia Optical...
Instructions Please
open contorl panel disable wireless /link USB connector mouse and keyboard/chech device manager to confirm connection.
Jan 08, 2008 | Labtec Wireless Desktop 9673600403R
HP Wireless Optical Mouse Fading
Ref wireless mouse. Not sure if you have a solution yet but it seems there could be 2 sources to the problem. First a weak or decaying laser. Second, something you have introduced recently that could interfere with the wireless signal eg mobile phone, another wireless device, cordless phone, telephone wires close to receiver or maybe something else. Not sure what you do if the laser is failing other than clean the lens. You might have to get it checked or try a friends mouse to see if it is better. There s also a setting than can change the sensitivity of the mouse. Have you looked at those settings.
Dec 10, 2007 | HP Wireless Optical Mouse
Keyboards & Mice Logo
912 people viewed this question
Top Keyboards & Mice Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Keyboard and Mice Expert? Answer questions, earn points and help others
