Question about Panasonic NV-GS27 Mini DV Digital Camcorder
Dirty mark on inside of camera lens. Need info on how to dismantle so i can clean it.
  • 126 Answers
If you are not familiar don't even think about it.I recommend if this is a piece of dust try to blow it away with a blower through open cas. compartment,but if it is a mark on glass give it to service personnel.
Posted on Oct 14, 2009
White substance inside lens
It is highly unlikely that anything has entered the lens.
You would not need to dismantle to clean.
Wipe clear with the lens from outside.
Wipe clear the eye piece as well.
Otherwise is the recording head that needs to be cleaned.
Apr 27, 2014 | Panasonic NV-GS17 Mini DV Digital...
Dirty marks on samsung pictures not the view finder ES73
You need to realize that the screen has 1 million pixels max, while the camera sensor has 12 million pixels. On the LCD you can barely tell whether something is in focus, right?
So if there is dirt or a smudge on the lens, or inside the camera on the sensor itself, you'll be much more likely to see it when you look at the final picture on the monitor.
Clean lens with a microfibre cleaning cloth (similar to eyeglasses or monitor glass) and see if that helped. Cleaning the sensor is probably a job for a camera repair shop. Good luck!
Jan 07, 2014 | Samsung Cameras
Need to get inside to remove dirty mark from inner lens
Is it really in your lens? Not in your camera?
Lenses are made in conditioned rooms, so it's hard to get dirt in your lens. If you have a (D)SLR or EVIL than you can take your lens of the camera (see your manual) and then clean the lens. Or clean the image chip. Be carefull and read the manual!
Aug 17, 2011 | Cameras
Fell into water, still can used, but got watermark inside lens.
You can use some absorbents to dry off the residual moisture but the marks might remain due to stain of the water. So try to use a hair dryer to warm the camera very carefully. Once there is no trace of water, but the marks remain on the lens , then it is important to remove the lens assembly after dismantling the camera so as to clean the lens using proper lens cleaner.
Attempt only if technically inclined and with proper tools.
May 04, 2011 | Cameras
Hi, I have a canon eos rebel xs. the mirror is kind a dirty, can it be cleaned by me or need to have it cleaned at canon service centers?s I also have a Tamron Telephoto lens, when I do a full zoom in...
This is a digital camera and I suspect it's not the mirror that's showing dirt it's the sensor. If you are seeing small bits of dirt on your pictures then it's dirt on the sensor. I would suggest having it cleaned at a camera store or repair facility if you are not comfortable with doing it yourself. Cleaned improperly can damage the sensor and renter the camera pretty well useless. The dirt inside the Tamron lens I would also suggest cleaning and if you are getting an error message you may as well send the camera in for a complete cleaning. There are kits on the marked to clean the sensors but again if you are not confident that you can do this then sent it to people that can and do it on a regular bases.
Sep 25, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Pentax SMC D 16-45 Lens How to clean inside? Pictures are showing spots and all the outside lens have been cleaned along with the inside of the camera itself. Can not see the spots when taking pics only...
Your lens would need to be absolutely filthy with enormous dirt specks to cause the fault you describe. Dust, fingerprints, and regular minor debris simply doesn't show in the final image. In any case, you cannot clean inside the lens without dismantling it and that is a job for experienced specialists only.
Your fault is a dirty image sensor. You can buy sensor cleaning kits, but if you're inexperienced with them or trying to clean the sensor in a dusty environment you'll just make matters worse. Many camera shops offer sensor cleaning while you wait at relatively low cost. The reason you don't see the dirt when taking the picture is either because you're looking through the optical viewfinder or because the LCD screen simply doesn't magnify the image enough to show the marks which are present in the image.
You can prevent the dirt from reoccurring by never leaving the camera with the lens throat open for more than strictly necessary, and by always trying to keep the open lens throat pointing slightly down when swapping lenses.
I hope that I've helped, please take a moment to rate my answer.
Sep 16, 2010 | Pentax *ist DL Digital Camera
Clean dust inside the lenz
Don't. Unless there are some really big specks of dirt inside the lens then they will have no effect at all on picture taking. To prevent the problem getting worse always store your lens with it's front and rear caps on and inside a lens bag. Also make sure that your camera bag is clean and isn't shedding fibres from the inner linings.
Dismantling your lens to clean it is really a job best left to a professional who will then additionally check and clean/lubricate the moving parts inside the lens.
Jul 03, 2009 | Tamron 28-300mm f/3.5-6.3 DI XR for Canon
The inside of the viewing screen on my Ricoh kr 10. is dirty
hi, i don have the solution, however i also face the same problem.. and worse, i used the lens cleaning solution to wipe it and now its worse.. did you manage to get it off or replace without fully dismantle it ??
Feb 22, 2009 | Ricoh KR-5 SUPER II 35mm SLR Camera
Panasonic NV-GS27 Mini DV Digital Camcorder Logo
95 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
