Question about Sony Ericsson P1i
Unlock button screen part won function.
It wont function unless i press its lower rightmost part of the screen.
    Problem Solver:
  • 11 Answers
I used to have one of these and i had the same problem. It is because you are supposed to use the little stick that comes with it and not your finger. Instead of locking it that way i found it a lot easier to hold down the back button on the right hand side of the phone to lock it and do the same to unlock it.
Cheers,
Toon.
Posted on Oct 01, 2009
Cant log into windows. screen black
If you have a function button try holding it down and pressing F2, possibly the screen has been accidentally switched off.
Apr 15, 2013 | HP Compaq Presario V2000 Notebook
Unlock apex tv model # AT2702
  • If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
  • If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels.
  • If you have a GT2011J or GT2011S Television, hold the (Display) button for 10 seconds, it will unlock the screen. If password or code is requested, try 3308 or 6688.
Hope that helps..........
Jul 20, 2008 | Apex Digital AT2702 27" TV
How do I remove the history or graph lines in a block on my screen
Repeatedly press the screen display switch button to cycle through the different views of your pictures. The Screen display switch button is the upper of the two rightmost buttons on the back of the camera.
Apr 21, 2011 | Sony Cyber-shot DSC-H5 Digital Camera
My tv wont come back on fpa lock on
Press Menu Button from any Remote control ( RC) by which could turn on your TV, press menu , menu drop down list will be visible on ur screen then wait 4 a minute or more till ur RC stop blinking , then go to Preference menu , go to FPA lock, turn it off. enjoy.
Deva
Apr 21, 2011 | RCA 20F420T 20" TV
How do i dim the screen brightness on a dell inspiron 1525 laptop
Look at your keyboard some of the keys have blue symbols on them, that's the second function. At the bottom left of your keyboard next to the control key there's a button that says Fn on it hold that down and then press one of the other buttons to use the second function. The brightness control is the up and down arrows. Hold Fn and press up or down to change the brightness.
Also if your laptop is set to a lower power setting the display wont be as bright. Click on the little battery symbol at the bottom right hand corner of the screen a little menu will pop up that says select a power plan if its set to power saver your screen wont be as bright.
Jan 19, 2011 | Dell Inspiron 1525 Notebook
I have a new Carrier HVAC system with a fancy EDGE thermostat. When I turn the system OFF at the thermostat, and set the fan to AUTO, hours later I will find that the fan is running and it's setting on the...
1. Open the door. 2. Press and hold the buttons underneath the heat and cool setpoints simultaneously (the two bottom buttons on the right) until the screen displays the reset reminders and 01 in the lower right corner. 3. Press the up arrow button until 01 changes to 07 with OF (fan mode) next to it. 4. To turn the fan on, press the rightmost lower button then press the up arrow button until the screen displays ON. To turn the fan off, press the rightmost lower button then press the down arrow button until the screen displays OF (off). 5. Press the done button. 6. Close the door.
Jun 06, 2010 | Carrier 36KCARMS Air Conditioner
My droid wont unlock
DO A HARD RESET ON IT
*Turn the Droid off. If it won’t turn off, take the battery out then place it back in.
*Open the keyboard and press the X key while pressing and holding Power. The device will power on. Keep holding the buttons down until a yellow triangle appears.
*Press the Camera and Volume Up buttons at the same time to get to the menu. (I had to press them several times).
*Use the direction pad to the right of the keyboard to select the Format option
www.usedcellphoneshop.com
May 24, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
How do I set time etc on a coleman sports watch, have manual but doesn't make sense, it's model 40-408
The watch has four buttons. The lower left button is labeled MODE on the face of the watch. There are four modes and pressing the MODE button will step through each mode until you return to the mode at the start of the process. Start at the "Normal" timekeeping mode and press the "MODE" button three times until the digital display rightmost two figures for seconds flash.
Press the lower right button labeled RESET until the item you want to change is flashing. Pressing RESET cycles through seconds, minutes, hours, day, month, day of the week in the top sub-dial and then back to seconds again.
When the item you want to change is flashing press the top right button labeled START to step the displayed item to the value you want. When you are satisfied all the settings are correct, press the lower left button marked MODE to return to normal operation.
Coleman 40-408 User's Guide
Nov 03, 2009 | Bulova Watch
I lock my cell phone and forgot the code how do i reset it the phone is a i 465
Unlock Code is a manual hard-lock on handsets which requires the correct pass code to allow access to the phone's functions.
Occasionally, people purchase used handsets. Previous owners may have locked the handset and are unreachable to get the new pass code
To unlock the phone using the factory default pass code, perform the following:
1. Confirm the phone shows, Enter Unlock Code.
2. Press the MENU button. The screen will show, Enter Security. Try both.
3. Enter last 4 of PTN, unless you have changed the lock code, and press OK. OR
Enter six zero's (000000) and press OK.
*If successful, the screen will display, Phone Unlocked.
*If unsuccessful, the screen will display "Security code is incorrect please try again."
If the you don't know the code, You will need to contact Motorola to have it re-flashed, which may incur a service charge from Motorola.
4. You now has access to use the phone’s functions.
5. Do not change the Unlock Code.
Oct 10, 2009 | Motorola Mobility Clutch i465 Cell Phone
Sony Ericsson P1i Logo
54 people viewed this question
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
