Back to:
Tags:
Refrigerators
Generic problem for all Refrigerators
HOTPOINT FRIDGEFREEZER (by 2 users)
posted by BREEKO on Dec 20, 2007
THE FRIDGE TEMPERATURE IS TOO LOW WHILE THE FREEZER TEMPERATURE IS TOO HIGH
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Feb 16, 2008
freezer is cold bottomof refridger isworm what causes this
Best Solution
posted on Dec 21, 2007
Helpful (85)
saal
Rank:Guru Guru
Rating: 88%, 53 votes
ck the fan that is woking or working slow
Rating Locked! (?) BREEKO has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on HOTPOINT FRIDGEFREEZER:
I don't want to Accept this solution
Solution #2
posted on Dec 23, 2007
Helpful (85)
murdozzz2
Rank:Guru Guru
Rating: 87%, 79 votes
i i you will need to replace your defrost sensor and thermal fuse
this is how to do the repair and not have to defrost and leave doors open for 48hrs time after time
Thank You!
Solution #3
Helpful (85)
Bob from LI
Rank:Guru Guru
Rating: 85%, 440 votes
Sounds like frosting up. Defrost completely...that can take 2 days. Restart. Also, clean the condenser. Check door gaskets, clean and replace as necessary. Don't keep door open longer than necessary.
Thank You!
Solution #4
posted on Feb 02, 2008
Not Rated (0)
weeanne
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Hotpoint rfa 80 fridge freezer red high temp light on for freezer and a buzzing noise when compressor diue to start any ideas
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Can you Help with these Refrigerators problems?
Frigidaire FRT15B3A Top Freezer...
After moving my fridge to a different location in my...
Sub-Zero 661/F Side by Side Refrigerator
I have a 8 year old side by side sub zero refrigerator and...
GE Profile Arctica Stainless Steel Top...
The Icemaker in the fridge keeps going on and on. The ice...
Hotpoint HSS25GFP Side by Side Refrigerator
hotpoint refrigetor makes noise, it goes off and gain...
Refrigerators
My Maytag refridgerator / freezer has a problem. The...
Loading problems.
Repair Service
Find Refrigerator Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
