Question about TREND for Kids Joggster III - Navy Stroller
How to remove the back wheels - TFK Joggster III
Could you please advice us, how to remove the back wheel of stroller TFK Joggster III. We didn't take it off longer time and now it got stuck :-( Thanks.
How do I tighten the wheel assembly on a 2005-07 Mountain Buggy Urban Jungle Double stroller?
This is a press or pound on type nut usually a one time use! But if you are carefull you can unscrew with a pair of plyers by turning both ways but pulling hard on them! Once you get it off you can put washers on the axle to take up the play. Then before you put the press nut back on make sure you didn't bend up the little pieces of the metal. They should be bairly slanting to the inside of the nut. If they are slanting to the out side bend them in gently. them tap the nut back on!
Mar 18, 2015 | Mountain Buggy Baby Gear
When pushing my quinny the back wheel starts to come of byitself
Hi Lisa - It could be that if there is dirt and debris on the wheel axel or inside the connection it would prevent the wheel clicking in properly. Remove both back wheels and give a wash in warm soapy water then dry thoroughly before putting back into place. Does the same side wheel fall off even if you swap the back wheels over? If this is the case it would indicate a chassis problem rather than a wheel problem. If it is the same wheel that always falls off it would suggest a wheel problem. Contact customer services on 01284 413 141 Mon-Fri 8.30-4.30 or e-mail to uk-customercare@dorel.eu for further advice
Nov 14, 2011 | Quinny Buzz 3 Stroller
I need a detailed instruction on how to fold a combi stroller
1. Lock both front swivel wheels. Not locking the swivel wheels before folding the stroller can damage the wheels 2. Empty the basket. 3. Fold the canopy by lifting the canopy levers. 4. Remove your player from the canopy. 5. Lift and hold the folding levers up on both sides of the handle. 6. Tilt the stroller onto its back wheels and roll it forward and then pull it back quickly and the front guardrail will fold inward. 7. Turn handle inward with an underhand hold to latch and lock.
Jun 02, 2011 | Combi Cosmo DX Stroller
How do you remove the back front & back wheels?
hi here are some videos
front wheel
http://www.youtube.com/user/Kiddicare#p/search/18/fFu3AJ04dbQ
rear wheel shown at 7 minutes
http://www.youtube.com/user/Kiddicare#p/search/24/-3niAfNKed8
if still unsure please get back to me
Mar 12, 2011 | Quinny Buzz Three Wheel Stroller
Evenflo Aura 3 co back wheels
I am looking for the back wheels can you help me please the model number is 1621854A.
Jul 30, 2010 | Evenflo Aura 3s Co Stroller
The back wheels
There is a cap you need to remove. There is a clip you should pull up on with a pair of pliers. This releases the wheel. Once the clip is lifted the wheel slides off
May 23, 2010 | Baby Trend Sit-N-Stand LX III Plus Twin...
I can't remove back wheels on a baby jogger 2 buggy HELP!
There are metal clips near the back wheels that go around the black plastic "axle" piece of the stroller. Squeeze the clip to the far side of the axle and the wheels will easily come off.
Apr 27, 2009 | Baby Jogger 2 Stroller
Macl;aren quest
Just got me new wheels form ebay, click on link below!. Please check wheel diameter, unworn is about 125mm, axle size ( size of metal rod that goes through both wheel, access by removing the end cap, just pry open slowly.. measure )..should be 6mm or 8mm. using the link below buy online on ebay. under maclaren wheels or click link below
http://shop.ebay.co.uk/12459ajs/m.html?_nkw=&_armrs=1&_from=&_ipg=&_trksid=p4340
They about £22 for set of 4 wheels normally you replace all 4 back ones! come with end clip. remove them with a good set of pliers, they can be a pain, get help! Replace with new once, get them back is easier but again if not sure ..get help! as your child is on it and you do not wanna them falling off while crossing the streets ... their safety lie in your hands now! good wheeling
Nov 24, 2008 | Maclaren Quest Sport Stroller
Graco quatro wheel removal
i have the graco quattro tour sport, i put it together & noticed the swivel lock was missing! I have to take the wheel back tonight but i had already put it on the pram! after reading 'Adorough's' comment i had good look at the wheel to figure out how to get it off. 1) fold the pram up and stand it so the front wheels are up. 2) if you look round the back of the front wheel you should see a round 'pin' which is set back, you well need a pen or something pointy to press the pin in & pull the wheel! That worked for me.
Sarah
Dec 31, 2007 | Graco Quattro Tour Travel System
TREND for Kids Joggster III - Navy Stroller Logo
233 people viewed this question
Top TREND Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a TREND Baby Gear Expert? Answer questions, earn points and help others
