Question about HP 4 Bays StorageWorks Disk System 2120 SCSI Ultra 160 Storage Cabinet
Laptop screen I dropped my laptop and the screen is cracked. can it be repaired?
0 characters
1 Points
Hard disk capacity dropped from 1tb to just 32 gb
Windows must have created a partition that is 32G for the recovery media. You can go into disk manager and see the empty space.
Jan 19, 2014 | Western Digital Hard Drive Accessories
Dropped on hard surface, makes a sound but computer not reading
ya they're not meant to be dropped. If you have important data you can contact data recovery specialists, but that can be expensive
Jun 08, 2013 | Hard Drive Accessories
I have a Fanner SPIRE Aluminium Gigapod External 3.5" external hard drive linked to my Windows XP laptop but the link up between the two has recently become increasingly slower as has the response of the...
The hard disk inside that Spire case has died - running the free space clean from CCleaner (a very intensive procedure) has been the death blow to an already sick disk.. Nothing more can be done to save it and the data on it. Replace it with a new one.
Jul 17, 2010 | Fanner SPIRE Aluminium GigaPod External...
Dropped my Seagate while
You really need to take your drive to a service center. You cannot do the repair procedure on your own if you are not a qualified to do the work. I suggest this option so that there will be no more further complications will be generated with your drive.
Dec 19, 2009 | Seagate USB 2.0 External Enclosure + 400GB...
Lcd screen flickers
More than likely it is a back light or inverter board. Usually a inverter board is fairly cheap. Either way your going to need to bring it in to your local repair shop and get an estimate. If this is for a laptop don't spend more than $200 if for a desktop don't spend more than $100
Oct 13, 2009 | Intelligent Computer 5 Bays Image MASSter...
NexStar hard drive doesn't recognize its size
It may be crashed....use [Nucleus Kernel for FAT and NTFS ] software...
Oct 11, 2008 | Vantec NexStar-3 External 3.5inch...
I've drop my laptop.
Man buddy, if that's all that failed, you sure are lucky. Anyway, I don't think that you could have damaged your memory before damaging the hard drive or anything else. The machine should be able to run anyway without any RAM, but does the system actually boot to windows, or does it just say this in the bios? If it boots to windows, that I would just go down to your neighborhood computer repair shop and have them re-connect your RAM cards, or if you're still feeling lucky, then you can open up your laptop with a micro screwdriver set and tighten them yourself. If you wish to do so, let me know, and I'll give you a tutorial.
Jan 06, 2008 | Adaptec 3.5" USB 2.0/Firewire Combo Hard...
Lightly Dropped Seagate 100GB External Hard Drive
Unfortunately, this probably means the read/write heads were jarred and can no longer function properly. That's usually fixable, but it's a very expensive fix because the parts are inside the hard drive and the data surfaces are very delicate... Most people are better off simply replacing the hard drive unless the data is absolutely vital.
Dec 06, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Dell inspiron 1100 booting problem
Motherboard or power supply is toast. A factory authorized repair center should look at it. Good lUck
Sep 09, 2007 | NEC Versa (808-895500-001A) Drive Case
Rock Mobile external hard drive was accidentaly dropped
Well it has been cause a mischief that's for sure. Try dismantling the case to check the connectors but that is about all you can do - if the drive is done then it stays done there is no repair option
Jun 02, 2007 | Ultra 1 Bay USB 2.0 External Drive Case
HP 4 Bays StorageWorks Disk System 2120 SCSI Ultra 160 Storage Cabinet Logo
Top HP Hard Drive Accessories Experts
Are you a HP Hard Drive Accessory Expert? Answer questions, earn points and help others
