Question about Refrigerators
My LG freezer is leaking water and things seem to be defrosting, fridge part is ok
  • rolando ingking May 11, 2010
    Check the freezer temperature setting. Set it up at a little over the medium, or higher depending on the
    volume of store food inside it.
  • 4,070 Answers
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Posted on Oct 01, 2009
Water is leaking from freezer compartment and running down back into the bottom area. Otherwise seems to be working OK.
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 02, 2011 | Whirlpool Refrigerators
LG Fridge Icebeam Door Cooling Refrigerator Freezer is leaking water into very bottom of fridge. Fridge is only 6 years old. What could be the cause of this problem ? Many thanks for feedback.
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
Jan 11, 2011 | LG LRTN22310 Top Freezer Refrigerator
Puddle underneath fridge on occasion--tube coming down seems ok
This happens when the water from the defrost cycle exceeds the capacity of the pan under the fridge. The amount of water depends upon the door traffic (how many times opened in the day) humidity, and believe it or not, the door seals. If the doors to not seal or close properly, it will allow air, and the humidity that it carries, into the box, and that means more defrost water. You might also check the pan for physical damage that may make it leak.
Feb 02, 2010 | LG Bottom Freezer Refrigerator w/ Swing...
Fridge freeze lg grb 207 keeps leaking
check your defrost drain hose and inspect defrost pan for cracks /holes
Sep 19, 2009 | LG Refrigerators
Water setteling on bottom of freezer side and freezing also leaking. 2 fridges both doing the same thing . leaking on the inside and freezing and underneath water is leaking.
Clean out the defrost drain. There is a drain in the freezer that lets all the defrost water run under the fridge. If that gets clogged then all the water runs into the freezer and can even leak onto the floor
Sep 13, 2009 | Refrigerators
Estate Fridge, replaced bi-metal..now what?
good u explain your prob beautifully, but i am thinking about how to reply you like u.
ok, 1st thing u say that u turn the thermostate down to a "Hair" level and there is no effect on the cooling it means that during the leakage of water to the friedge, thermostate is effected to that water n goes for sleep (i u have to replace it). and at the other side your overload is OK.
change your thermostate and enjoy....
good luck
shafky
Jun 20, 2009 | Whirlpool ER6AHKXPQ Top Freezer...
Bosch fridge leaking water
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I have the same problem,warranty just ran out but its been leaking on and off for ages,must be this model.This much Ive figured out,what happens is the drain hole gets blocked from ice freezing over the hole at the back of freezer, the drain water has to go somewhere, since it cant leak out of the drain hole where it suppose to it ends up pooling under the vege compartment before ending up on the kitchen floor.Now if this is your only problem,someone suggested to me to run a piece of copper wire from the defrost heater to the drain hole so no ice can build up there,hence no more leakage.To do this you'll have to take the back panel off and see for yourself,I did this and Im a novice.Make sure you turn off and unplug the fridge first and wait for it to defrost.
Now I think I have other things wrong with mine,after leakage problem the refrigeration compartment wont cool anymore but the freezer part remains working as usual.Ive nailed this down to one of the following not working... Thermostat / timer / defrost heater.So one or more of these needs replacing.Im just trying to look for a manual which shows the nuts and bolts or the refrigerator (not the "How to use" type manual which I have).
Feb 10, 2009 | Bosch KSU49630 Top Freezer Refrigerator
LG GR727RB Top Freezer ok but bottom fridge is not cool
Hi softwaredude with an LG GR-727R refrig. The occasional build up of water on the bottom of the fresh foods sections tells me that the refrig is going through it's defrost cycle, but that the defrost drain is plugged. If you take the back off the refrig. you will see a plastic tube about 1/2 inch diameter with a few ribs on it going from the top of the compressor compartment to the bottom, which is a defrost water holding / evaporating pan. Look to see if that tube is plugged. If not, it is plugged further up, most likely where the defrost water drains off the evaporator (that the coils behind the freezer wall that do all the cooling). Take that back panel off and use a hair dryer to melt all the frost off. The frost is blocking air flow from the freezer section to the fresh foods section, thus poor or no cooling in the FF section. You should be able to spot where the defrost water is suppose to drain. If the water is not draining out, use a turkey baster with hot water to flush out the drain.
Dec 04, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
Leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
Oct 28, 2007 | Refrigerators
Refrigerators Logo
827 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
