Question about Canon Office Equipment & Supplies
CANON CLC3220 COPIER ERROR CODE E0000001-0003
ERROR CODE ABOVE AFTER CHANGING WASTE TONER CARTRIDGE
DOESN'T CLEAR EVEN AFTER SWITCH ON/OFF
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 118 Answers
Although the waste container is empty still it show 'THE WASTE TONER IS FULL' cleaned the bottle neck of waste container see to it that the 2transparent round hole area is not clouded by toner .this is the sensor path it should be cleaned(remove one screw to remove transparent cap)
Posted on Oct 03, 2009
I have canon ir 6570 continueing errod code e0013 solution
This is the standard Canon code for waste toner feed screw is locked. Most likely someone reset the waste toner counter and the waste toner has backed up in the auger screw. You should first empy the waste toner bottle located on the right side lower right. Remove the two screws and empty the bottle you find. You may even have to remove all the associated covers motors and circuit boards to get to the waste toner system. You will have to either clear out the auger tube, or replace the whole assembly. Check for broken parts, bound up screw, fused toner, etc. I've done this a couple of times and it's not fun. I try to make sure that I empty the bottle at every 1 million copy mark just so this doesn't happen again. Good Luck.
Sep 07, 2012 | Canon IMAGERUNNER 6570 Copier
E000990-0000
E990 Error in the waste toner shutter
0000 When the output of the waste toner shutter opening and shutting detection
sensor doesn't become "H" when it WMUPR period after the sleep returns after
eight hours or more pass, the door opening and shutting is detected or main
power switch turns on.
- Check that the drum unit is properly installed
- Replace the waste toner shutter sensor
Aug 30, 2012 | Canon iRC2380i
Error code e013 displayed and a sound of cut cut is happened
I believe a E013 error code means that the waste toner feed screw is packed with toner and can not turn the feed screw. From what I remember, there is a switch on the drive gears for the waste toner on the back ofthe copier. It is not a Happy, happy,joy,joy job...... You will need to clear out the feed screw & empty out the waste toner bottle and possibly cln out the drum unit... Toner is packed there as well...... Good Luck
May 24, 2011 | Canon NP 6050 Copier
Error code E000013-0001
getfile.asp?rid=1258 February 2, 2005 getfile.asp?rid=3215 Product : imageRUNNER C5800 / C6800 Title : E013 code and Waste Toner Full message Question :
The copier shows an E013-0001 and "Waste Toner Full" message. The Waste Toner Bottle has been emptied and SW1 is operating properly but the code and the message are still appearing on the display.
Answer :
The counter for the Waste Toner Bottle needs to be reset back to zero in Service Mode.
Enter Service Mode level 1 by pressing * 2 8 *, select Copier > Counters > MISC, then highlight WST-TNR, press Clear - the counter will zero out.
Power off the copier, turn the copier back on, the Waste Toner Full message on the display should clear out.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
Dec 22, 2010 | Canon imageRUNNER C6800 Copier
Error code E000001-0003 canon clc2620n
it is a fusing/fixing error try this on the control panel press * with head 2&8 together *with head >copier>function>clear>err>ok turned off/on the machine hope this help
Oct 01, 2009 | Canon Office Equipment & Supplies
Gestetner DCS424 error message: replace used toner bottle
There are 2 waste toner cartridges, be sure to empty these 2 cartridges . If you remove the waste toner in both cartridge it will automatically clear the error message.
Feb 27, 2009 | Gestetner Copier
DCS424 error message replace used toner bottle
Canon 5070 - Error code E000013-0000
This is the error code for a clogged waste toner auger. If you heard a clicking sound coming from the rear of the copier before the error you have clogged waste toner . This may take a long time to clear. May have been caused by not emptying the waste toner bottle when it indicated to do so and the waste toner backed up on itself. You may have to remove most of the items at the rear of the copier to either replace the auger pipe assy or just the slip gears that drive the auger. I've never looked forward to doing this on any of the copiers that have an auger system. If you're not a tech a tech should be called and may take several hours depending on how serious it is to clear. Good Luck.
Oct 10, 2008 | Canon imageRUNNER 5000 Copier
Code no. is E0002-0001
e000019 is waste toner error , you have to empty the waste toner container. It is on your left side of the copier, just above first tray, remove one screw and you have the container
Error E00007 is fixing film error , it must have torn or displaced
Nov 16, 2007 | Canon imageRUNNER 3300 All-In-One Laser...
589 people viewed this question
old marine
old marine
