Home | Canon | PowerShotŪ SD850 IS Digital Camera | When zooming in for a c...
Canon PowerShot® SD850 IS Digital Camera
Problem for Canon PowerShot® SD850 IS Digital Camera
When zooming in for a close shot it will not focus
By tim_lakewood on Oct 01, 2009
Solution #1
posted on Oct 01, 2009
Not Rated)
Obertelli
Rank: Guru  Cameras & Camcorders  Expert
Rating: 94%, 290 votes
You don't say how close, but all cameras/lenses have a minimum focus distance which varies from model to model.
Your camera will have a macro mode for close ups. On the mode selector dial on most Canon digital cameras (and on many other brands) there will usually be a macro setting with a flower symbol next to it. If it's not on the dial then there's usually a button around the rear thumbpad with the marking. Selecting macro mode will allow your camera to focus closer than normal but stops it from being able to focus on distant objects. To remind you, the camera display will show a small flower symbol when macro mode is active.
Even macro mode has it's limitations though and on some cameras it allows focus to within a few centimetres of the lens and on others only to within about 30cm or so.
Was this helpful?
Yes
No
Solution #2
Not Rated)
pschroeder
Rank: Master  Cameras & Camcorders  Expert
Rating: 81%, 13 votes
When using the tele, the closest you can be to a object is probably more that one meter. If you need to get closer you should switch to macro mode.
Was this helpful?
Yes
No
Popular Solutions for Canon PowerShotŪ SD850 IS
Questions and Unsolved Problems for Canon PowerShotŪ SD850 IS
Do you recommend Canon PowerShotŪ SD850 IS Digital Camera?
Answer
Answer
I know the Display is working because the camera setting show up, but point the camera at a person... (More)
Answer
Lens error showing up on screen. The lens won't retract back in the camera
Answer
I have a problem with Canon SD850 in zoom mode and low light. Outside in less than sunny weather, if... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PowerShotŪ SD850 IS...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
