Will not spin
My machine will still aggitate the clothes but will not drain and spin out the water. What maybe the problem?
  • 38 Answers
Check the drainage filter or pipe to see if it is not bent or gloged
Posted on Oct 01, 2009
    Genius:
  • Washing Mach... Master
  • 1,466 Answers
Blocked filter pump
Washer won't aggitate. Drum will not spin.
Here is a tip that will help you with the not spinning or agitating problems....
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
May 14, 2010 | GE WBSR3140DW Top Load Washer
Our washing machine fills with water, aggitates,
dont know what washer you have but follow hoses to find pump as it will be blocked,may be able to drain by lowering drain hose into bucket
Mar 16, 2010 | Washing Machines
I have a Sears Kenmore washer that sometimes does not spin in the spin cycle and sometimes it does. The timer progresses to stop, but clothes are still dripping wet. Resetting timer from spin usually...
The transmission in this machine is worn and is not shifting correctly. Understand that after the aggitate cycle, this machine should go into drain cycle without spinning and it should drain for about 1 minute. Then it should kick into spin cycle after it has emptied all the water. What is happening is it is (like skipping) the drain cycle and going directly into spin with water still in it,,, so the spin is slow as it is trying to empty and spin at the same time,,, thus the clothes do not spin out correctly,,, when you reset the spin, you actually spin all the water out the second time around.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine will not aggitate.
if it fills with water then stops check you lid or door switch. will the unit drain or spin if so the the timer may be bad
Sep 16, 2009 | Washing Machines
My kenmore clothes washer won't empty water
some models reverse the moter to activate the pump .. some have a solonoid to engage the pump .. depends on what model you have ... if the motor runs but still it doesnt pump then look for a broken belt that drives the pump .. on some there is a little universal joint that sometimes breaks .. often the pump becomes clogged with coins and other debree .. you didnt say if the spin cycle started or not .. if it doesnt then you could have a bad door switch .. if that doesnt operate then the spin cycle wont start and it wont drain as well .. you can test for clogs by taking the drain hose out and placing it on the floor .. if a lot of water comes out then its not clogged .. if no water comes out then you have a clog .. (be prepaired for lots of water) .. even if water comes out there still could be a coin stoping rotation of the pump .. there is no reset on the pump, it is almost always run by the main motor ..
Sep 12, 2009 | Kenmore Washing Machines
Water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
Aggitator won't work and won't spin/ drains ok
Coupling is bad.
There is a coupling between the motor and the transmission. When this part breaks then it will pump the water out but won't spin or aggitate.
Jan 18, 2009 | Kenmore 15944 Top Load Washer
Aggitator or tub not spinning after move from detroit to LA
IT SOUNDS LIKE YOUR DRAIN HOSE IS LOWER THAN YOUR TUB WATER LEVEL BE SURE THAT YOUR DRAIN HOSE IS ABOVE THE TUB LEVEL.GLAD TO BE OF SERVICE
Jan 06, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
