Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Ge profile gas oven grates rusted badly. just got new replacement grates. how can I avoid the same problem? thanks.
  • 832 Answers
Be sure to clean the oven grates after using. You'll
find it effective to prolong it's useful life. But not with
water, just clean it free from residues and dirt.
Posted on Oct 01, 2009
Can I place metal grates from gas ge profile range in the dish washer?
You should be able to place them in the dishwasher, just remove them promptly to prevent rusting.
Sep 21, 2014 | Kitchen Ranges
Broiler works but oven does not ge xl 44 model JJBP24BEA2WH serial LV201917P Is this worth fixing?
Hello-  Yes if it's the igniter for the oven burner. The lower burner may light, but if igniter is bad, gas flow will not increase, causing under-temp condition. The part is available for 40-75$, and is fairly easy to install. Part is accessed by removing drip pan at bottom of oven. Gas ranges last longer than electric if the self-clean 'function' is avoided. Go ahead and fix it!  Let me know if this info helps-- have more if needed.   Thanks-  Ed
Mar 17, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Cast iron grey grates are hard to clean
Don't use oven cleaner! It isn't recommended by GE. Their book explicitly says to put the grates in a plastic garbage bag and pour a some ammonia into the bag. Tie the bag tightly so all the gas stays inside. Put in a garage in case it leaks because it can smell bad. Wait 24 hours and the stains will come off with a hose and some light rubbing. I didn't believe it at first but it works great! My wife loves our 'like new' oven.
Sep 09, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Stained gas range burner grates
Hey y'all. I have the same lame GE profile gas cooktop with the gray grates and burner covers. I know this is the expensive way to go, but I use Easy-Off "self-cleaning oven" oven cleaning spray. For about $5, you get 3 cleanings. It is a pain to do, but I have better things to do than scrub these grates all the time. I don't know why, but the baked on crud just drives me crazy. I tried everything to clean them completely. I even tried to scrub the darn things with a kitchen pumice stone(sold at walmart)but it is impossible to get the curvy areas clean. Now the paint has started to wear off on the burner covers.
I do not use the oven cleaner on the cooktop itself. I use soft-scrub with baking soda, then cover the cooktop with a sheet of heavy duty aluminum foil and cut out holes for the burners. This keeps most of the spills contained, and helps with cleanup.
I visited to the GE parts web page, and they only sell gray grates and covers. I am going to buy black BBQ grill paint(spray can)from Home Depot and try it on the burner covers first. They are the least expensive to replace if it fails, and if it works, I will paint the grates with this high temperature paint. I will keep you posted on the results.
Regards,
Laura D.
Feb 14, 2009 | GE 30 in. JGP337 Gas Cooktop
Our GE Profile Oven is not heating up (stove works)
Please check here for possible troubleshooting steps:
http://www.repairclinic.com/0088_13_1.asp#Level1_2
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 04, 2008 | GE Spectra JGBP35 Gas Kitchen Range
Cleaning grates of GE profile gas stove
Sounds crazy, but this works. Soak the grates in warm to hot water with 2 dryer sheets (Bounce), let them soak for an hour or two. Unbeliveable how they came clean. I did have to use a Scotch Brite pad on the two that I use most, but it sure beats replacing them.
Jul 02, 2008 | GE Profile JGP636 Gas Cooktop
GE Profile JGBP86WEA2WW Won't get hot...
Sure. If you go to my profile and look under "Tips and Tricks" section. I have a complete write up on how to replace an igniter in an electric oven. If you can't find it, let me know and I will forward the instructions to you.
PS Yes, this is a simple job that anyone can do. The igniter will cost you about $30 - $60 depending on where you get it. It will save you big $$ in the long run, if you avoid the labor charges :).
Apr 06, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
GE Profile Gas oven igniters
  If it is also a round ignitor it's the same.
Oct 24, 2007 | GE Spectra JGBP30 Gas Kitchen Range
Cleaning and care for my GE Profile stovetop
The one thing I don't suggest is using the Ceramabryte product the dealer left with us. It leaves a greasy film. When I get ready to clean my black GE Profile, I pull off the controls to wash separately. Then I lift off the grates, take a single-edge razor blade to scrape anything stuck on (it doesn't scratch), then I use baking soda and scrub and scrub with lots of paper towels. Then I start cleaning off the baking soda with lots and lots more paper towels. There is still a film, but at least it's not greasy. At this point I grab some more dry paper towels, pour on a 3' puddle of rubbing alcohol and wipe it all over the stove top and front. You may have to do this twice. Then, if I don't turn on the hood light's brightest setting, it really doesn't look too bad. I have to do this at least once a week, as I have never had a stove that got so dirty so fast and was such a pain to clean.
FYI, I would never buy another of these stoves. Besides the cleaning issue, there is the fact of having to replace the igniter (glow plug?) twice in the first four years. My old, bottom-of-the line Magic Chef went 25 years with the first replacement not coming until it was about 15 years old. Also, the broiler is unimpressive and steaks, etc., just sort of steam. Can't get a really good crust going. It's a slide-in and the top is very narrow, front to back, because of the slanted control panel on the front, and so you really can't put two large pots or pans on one side. Let's see....oh yes, I ordered the unglazed grates for safety reasons and it came with the procelain glaze. Those were replaced free of charge, though I had to go pick them up. Then the first set of unglazed grates began to rust about six months into use, so had to be replaced (again, no charge at least). Recently I noticed that the inside walls of the oven, where the racks slide, are starting to rust. Finally, the burners are difficult to calibrate, which I really notice when I try to cook rice, which comes out right about 50% of the time.
Now, on top of all this, I have to worry about the glass door exploding?!?! Should I ban my grandchildren from the kitchen? Has anyone from Consumer Reports seen this website?
Feb 01, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
135 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
